| Eagle Tree Systems Onboard data loggers, telemetry, and OSD support |
I am looking for a logging solution for power in a electric setup. The specs show that the Eagle tree solution is limited to reading only up to 150A. Is this a hard set limitation? Or will it actually graph readings above this?
Compass Atom 7HV, Scorp HK3 4035 hand wound by Mauro - 6x7x1.32 YY 430KV, CGY750 Beam E4, 6S, looking for a new FBL unit, BX is getting removed! Formerly owned - Blade mCP X V2 - Blade 400 FBL BeastX |
Not many people using Eagle Tree?
Looks like you can shunt half the current and have a 300A logger. I have not tested this myself.
http://forums.offshoreelectrics.com/...in-15-minutes& /Lars
T-Rex 450 Pro, T-Rex 500 CF, Goblin 500, Logo 500, T-Rex 600 Pro, T-Rex 700E, V-Bar, DX8 |
Thanks for the info
Mix
Maybe a bit late- sorry mate- That ACS7xx sensor has something like a 100uOhm resistance, and its alloy is pretty carefully engineered (and the electronics, calibrated for it). A standard 12AWG insulated copper wire is just not going to look anything like it at 150A bursts. It might actually be smartest to just buy another of the same sensor and parallel them, vs using some other shunt with different properties (if you care about accuracy > 50%). They retail for $10 or so last I checked. Cheers mate-
"The problem with quotes found on the internet is you have no way of confirming their authenticity." - Abraham Lincoln |
#6 |
Yeah, the Eagle Tree system doesn't seem that worthwhile. Modern heli power systems pull a lot more than 150A.
#7 | |
you will not not connect your e-logger to the esc just to the battery for power and use this sensor to log your current
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
