Old 09-28-2012, 10:17 PM   #1
Mercuriell
Default NEW - Kasama Dune 600 Build
We first saw the world premier of the Dune 600 at the Helifreak FunFly last year. It caused a lot of favourable comment so we have been waiting patiently for the Faifa's little brother ever since. The latest incarnation includes a lot of thought and redesign by Kasama as a result of extensive field trials by pilot Gavin Broadbent. A lot of thought and sweat has gone into the frames evaluating different thicknesses, sources and designs - the latest has a novel two piece design whereby the front piece is isolated by the main frame by bridging CNC/O-ring dampers.
The main gear and pinion is the first for Kasama with an oblique gear cut to quieten down the typical ringing of a linear cut gear of an electric. Although the protoype featured a helical crown gear and tail pinion, robust field testing showed it was not as strong as the original design and this has been adopted - ongoing development of the helical gears continues but this is hampered by a very slow turnaround to the specialist outsourced gear cutter - until Kasama is perfectly happy with the gear profiles and materials he is not happy to release it as a beta test to the consumer!
The canopy has caused some comment - it has already been likened to a submarine conning tower - I think it looks great, especially in the air ! The cowling elegantly covers up the swash and must contribute to aerodynamics.
Why the Dune name you ask ?? This is a tribute to the long-standing support of UAE Heli who helped translate dreams sketched out on a napkin into the reality of Kasama Helicopters
Index to Build Videos
Video - Kasama Dune 600 - What's In The Box? - mp4 - 137MB
Video - Kasama Dune 600 - Frame & Skid Assembly - mp4 - 93MB
Video - Kasama Dune 600 - Frame Bearing Blocks - mp4 - 123MB
Video - Kasama Dune 600 - Mast gears - mp4 - 69MB
Video - Kasama Dune 600 - Rotor Head - mp4 - 101MB
Video - Kasama Dune 600 - Servos & Linkages - mp4 - 183MB
Video - Kasama Dune 600 - Motor Installation - mp4 - 103MB
Video - Kasama Dune 600 - Tail Assembly - mp4 - 138MB
Video - Kasama Dune 600 - Boom Assembly - mp4 - 113MB
Video - Kasasama Dune 600 - Maiden Test FLight - mp4 - 83MB
Video - Kasama Dune 600 - Gear backlash setup - mp4 - 160MB
Index to Build Posts
Bags 1-2 - Undercart
Bag 3 - Front Frame Assembly
Bag 4 & 5 & 6 - Tail Boom Case & Pinion Block
Bags 7 & 8 & 9 - Frame Bearing Blocks
Bag 10 - Main Gear Assembly
Bag 11 - Rotor Head
Bag 13 - Elevator Servo Linkage
Bag 14 - Lateral Cyclic Servo Linkages
Bag 15 - Motor Mount
Bag 16 - Lower Battery Tray
Bag 17 - Tail Assembly
ID:	353389   Click image for larger version
Name:	Dun82 [800x600].jpg
John
Mercuriell is offline        Reply With Quote
Old 09-28-2012, 11:00 PM   #2
Mercuriell
Default Frame Assembly
Well with a totally different design to the Faifa (and no manual!) it took a bit of figuring out but the build has started very quickly and straightforward - all bits fit perfectly and nothing missing so far - I'll run through the build in sequence of bags.
Bags 1-1 1-2 2
The skids are precisely punched with the location of the grub screws so that they can be mounted up on the struts without mounting to the frame.
Make sure you put the front strut on first and align the tabs on the struts facing outwards
The front carbon frames are mounted up on the front strut - the piece with the large cutout for the ESC is placed on the left
ID:	353396   Click image for larger version
ID:	353397   Click image for larger version
ID:	353398   Click image for larger version
John
Old 09-28-2012, 11:02 PM   #3
DominicD
The Capi - HF Support
Two builds at the same time !! Did the wife kick you out ?
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is online now        Reply With Quote
Old 09-28-2012, 11:07 PM   #4
Mercuriell
I thought my wife was on holiday with you
Back in the cage Capi
John
Old 09-28-2012, 11:16 PM   #5
DominicD
I don't think anyone would consider time with me a vacation. Glad to see you doing a build series. Been awhile since I watched one of these things.
Team KBDD
Old 09-29-2012, 01:24 AM   #6
Mercuriell
Bags 3-1 & 3-2
Front frame and frame joining hardware
Carbon plate for bottom of ESC compartment fixed onto damper joining block and front cross-member
Damped cross-member at the rear, non-damped at the front, with screw holes for ESC CF plate
Same cross members fixed on top for battery plate
Bottom damped cross-member, forward hole takes M3 stud for canopy mount
Battery tray and canopy mounts fixed in position
ID:	353414   Click image for larger version
ID:	353415   Click image for larger version
ID:	353416   Click image for larger version
ID:	353417   Click image for larger version
John
Old 09-29-2012, 01:35 AM   #7
gelatmi1
John,
i'm not able to see the first video (format file unknown !!!!)
I can see your other mp4 videos without problems (Impaction videos).
Could you check if the file is ok ?
EDIT:
now the file name is wrong (.mp40) in the link
http://video.helifreak.com/?subpath=...sinthebox.mp40
PS: Thanks - all fixed up - faulty render - 0 added to file name to stop wasting people's bandwidth - John
EDIT:
Great…thanks a lot !!!
gelatmi1 is offline        Reply With Quote
Old 09-29-2012, 01:42 AM   #8
Mercuriell
Default Bags 4 & 5 & 6 - Boom Support Case & Pinion Block
Front frames joined with battery and ESC tray in situ
Pinion drive for torque tube - make sure pinion flush with drive shaft and tighten up the 4 grub screws evenly and sequentially - red Loctite here not a bad idea.The rear TT coupling is snugged up on the shaft to the rear bearing and secured with a pinch collar. The cam adjusted is lubed with some grease and then located in the block which in turn is mounted in the frames
The tail boom mounting block is mounted in the frames with an M4 bolt and locknut on the bottom and an M4 threaded stud on top - the pointy end of the stud goes to the right and is red Loctited in. The spacer is inserted wider end towards the CF and the gyro sensor plate is mounted on top of the block.
ID:	353424   Click image for larger version
ID:	353425   Click image for larger version
ID:	353426   Click image for larger version
ID:	353427   Click image for larger version
ID:	353566   Click image for larger version
John
Last edited by Mercuriell; 10-02-2012 at 05:40 AM.. Reason: change location of rear canopy mount
Old 09-29-2012, 03:00 AM   #9
BenScoobert
Great thread, thanks John.
Now you have the frame in place, what are the size limitations for the motor and ESC?
Thanks, subscribed.
Ben - UK's sole stockist of Kasama Helicopters - www.kasama.co.uk
BenScoobert is offline        Reply With Quote
Old 09-29-2012, 03:03 AM   #10
Mercuriell
Thanks, subscribed.
PAtience Ben - all will be revealed - hard enough to photo - film - edit -- build - post
John
Old 09-29-2012, 03:09 AM   #11
Mercuriell
Default Bags 7 & 8 & 9 - Frame Bearing Blocks & Fittings
Motor pinion support block with dampers - mounts in front of frame above motor mount
Top and bottom bearing blocks with enclosed thrust bearings. Both are mounted with open, larger diameter sides facing towards each other. Smaller ID block is lower to accommodate step in mast
Motor and mast bearing blocks in situ
Boom support brace mounting and output lever for tail servo - red Loctite the balls in. Longer ball goes on the end and shorter on next hole in - shown with optional accessory for antenna mounting
ID:	353439   Click image for larger version
ID:	353440   Click image for larger version
ID:	353441   Click image for larger version
ID:	353442   Click image for larger version
ID:	353445   Click image for larger version
ID:	353446   Click image for larger version
John
Old 09-29-2012, 03:14 AM   #12
BenScoobert
Patience? Not sure what you mean, must be an Australian thing.
Old 09-29-2012, 04:52 AM   #13
Sage
Hi John,
Thanks for sharing your build with us.
It's great as usuall.
As expected it was worth to wait for this heli all this time.
Thanks to Kasama can't wait to put hands on my kit and take few pictures too.
BTW
2 builds at the same time, wow. Lucky you.
Piotr
Sage is offline        Reply With Quote
Old 09-29-2012, 05:01 AM   #14
jamin_00
Nice one Johnny boy
Looking forward to this as it progress's :
Sponsored by
Optipower
jamin_00 is offline        Reply With Quote
Old 09-29-2012, 06:44 AM   #15
chingie
Nice very nice build, and quality components too
chingie is offline        Reply With Quote
Old 09-29-2012, 06:47 AM   #16
Mercuriell
Originally Posted by Sage View Post
Hi John,
BTW
Look foprward to your build insights Piotr and great pics
John
Old 09-29-2012, 08:05 AM   #17
BenScoobert
Just talking to a friend about the build so far.
He mentioned he thought the front canopy mounts appear to have no spacer between them.
Now it is hard to see from the pics, and possibly an oversight due to lack of manual.
Can you enlighten us John?
Now I've watched the video I see it goes into the block
Last edited by BenScoobert; 09-29-2012 at 08:33 AM.. Reason: Watched the video now, forget it
Old 09-29-2012, 08:33 AM   #18
Mercuriell
Front canopy mounts screw into the lower damper block forward hole
John
Old 09-29-2012, 08:54 AM   #19
Gavin B
Hi John,
Looking good! The rear canopy mounts are positioned in the top hole of the tail boom clamp and you should have some purple coloured cnc doublers that are fitted to the elevator arm bearings on the frame KSM 10-50C08. Sorry about the no manual! We are going to email you a manual to help you out :-)
I'm looking forward to Piotr's build pics too!
Regards
Gavin
ID:	353469   Click image for larger version
ID:	353470   Click image for larger version
ID:	353471   Click image for larger version
Gavin B is offline        Reply With Quote
Old 09-29-2012, 10:16 AM   #20
jamin_00
Originally Posted by Gavin B View Post
Hi John,
Regards
Gavin
How long till a manual is available to download Gavin?
I do like to browse
Sponsored by
Optipower
