| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#41 | |
Little things like this, and the attention to detail that Kasama incorparates is what makes these machines such a pleasure to build and work on. Last edited by Mercuriell; 10-02-2012 at 04:16 AM.. Reason: Change pic |
#42 |
Hi John.
DUNEBOOM video doesn't work. Could you please check it ? Thanks for your great effort on doing these videos |
#43 |
I second that :-( I also second the thanks, what a star you are.
Ben - UK's sole stockist of Kasama Helicopters - www.kasama.co.uk |
#44 |
Wow! That's one nice looking heli. Very high-tech
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6 |
#45 |
Thanks - fixed !
John |
#46 | |
With the tail rotor being matched and checked, does it still need to be pulled apart, checked and reassembled with loctite, or is it pre assembled ready to go?
Blade 400, Trex 550 Vbar BLS251, Trex 500 Scorp Vbar mini, Gaui 330X Quad with GoPro, Blade MCP X, Trex 250 Microbeast MKS DS95i |
#47 |
No I'd leave it assembled - it shouldn't need Loctite anyway because of the Nyloc nuts - Kasama started putting Loctite on after years of production of the tail after a couple of reports of grips coming off - this was probably due to uneven bases of the M3 locknuts acting as an impact driver. The nuts now are all machined flat and matched to the rotor hub.
John Last edited by Mercuriell; 10-03-2012 at 09:07 AM.. |
#48 |
#49 |
On mine i will use Castle ice2 120A and Scorpion 4035-530.
I tried to set up my ESC in the castle link program (governor) giving main gear 104 and pinion 11 teeth and i saw that on 94.3% or ESC power i get 2200 RPM. How you can get that 2400 RPM? Unless you will run it without governor. Is that right? |
#50 | |
Throttle 55%: 2078 Throttle 60%: 2186 Throttle 63%: 2251 Throttle 67%: 2337 Throttle 70%: 2402 Throttle 73%: 2467 Throttle 76%: 2532 Throttle 80%: 2618 I'd certainly try out your CC and see if you like it - the Dune, like all other Kasama helis, is very effiicient and doesn't need blindingly high HS. I don't understand why the different ESC give such different results ![]()
John |
#51 |
Yours run with the half ESC power on 2000 RPM!
![]() As you said i have to bay Jive and maybe and motor if that make deferent instead my Scorpion! The 80+ HV Is the one? |
#52 |
Loving the tell-tale bath robe sleeve on the motor video.
Glad it's not just me at all hours. Was out in the man shed at 5am yesterday morning, sometimes it's the only time I can have peace. ![]()
#53 |
slick i love it Kasama helis look great shame parts support is bad in the US the Faifa was on my short list
DX8 mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades AMA#948801 |
#54 |
John Last edited by Mercuriell; 10-14-2012 at 02:57 AM.. |
#55 | |
Esprit seem very well stocked
#56 |
last i checked they where out of stock as was every one else guess they got more in
#57 | |
No one has them yet afaik, just shop models landing initially.
#58 | |
seems hard to find Faifa parts in the US
#59 |
I saw the Kasama Dune flying today at our local club,thanks John.My non technical comments are,It looks great in the air,that canopy is growing on me.Its so damn quiet,Its the quietest 600 size heli Ive heard.It also had some legs when needed and that was at a fairly low HS.
#60 | |
