Old 11-02-2012, 08:13 PM   #61
jamin_00
Got any pics of your electronics placement John?
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote
Old 11-03-2012, 01:21 AM   #62
BenScoobert
The thing I found odd is all the spare write from the 2 rear servos, used to not having enough not too much and nowhere to put it
Ben - UK's sole stockist of Kasama Helicopters - www.kasama.co.uk - we ship worldwide
FREE WORLDWIDE SHIPPING ON KONTRONIK PYRO COMPETITION EDITION MOTORS, choose your KV and custom engraving - www.kontronik.co.uk
BenScoobert is offline        Reply With Quote
Old 11-03-2012, 05:37 AM   #63
Mercuriell
FWIW here's a couple of pics - most of the wire can be led internally which is nice. The ESC cable can be run aong the battery tray, I got some Biro plastic vacuum formed wrapper and used that to hold the wire in the battery slot but you could just tape it in place as shown on the Kasama web site.
Agree with Scooby-Doo there is a lot of redundant wire from the roll servos - gonna trim them down when I get the chance
Name:	_DSC0315 [800x600].jpg
ID:	363066   Click image for larger version
Name:	_DSC0313 [800x600].jpg
John
Mercuriell is offline        Reply With Quote
Old 11-04-2012, 08:07 AM   #64
Mercuriell
Here's a video I shot showing how to setup gear backlash on motor and TT pinion
John
Old 11-04-2012, 09:40 AM   #65
jamin_00
I put 451's in mine and the wires are shortened already so I had no issues there. Just got to find somewhere to put my sats
I had more of an issue with the tail servo wire but I just wrapped it up and added a cable tie.
Old 11-11-2012, 03:19 PM   #66
itf68
I have ESC question! I set mine mode 4 and it was dynamite with low throttle curves (about 40%)! Then i set and mode 9 for lipos and heli become very soft (idle1 60%). Should i reset it without mode 9 or just increase my curves! Both fly times i use the same butteries!
itf68 is offline        Reply With Quote
Old 11-12-2012, 02:17 AM   #67
Mercuriell
MOde 9 shouldn't affect flight performance - just voltage of cut off I think I'd reset - mode 1 - then do a mode 4 and mode 9 and adjust curves - 60% would be very soft with a motor in the low 500s kV - what motor are you running ?
John
Old 11-12-2012, 05:02 AM   #68
itf68
I am runing the scorpion 4035- 530kv
As you said John i will set it from the begining and see....
Old 11-26-2012, 08:31 AM   #69
DannyvG
Originally Posted by Mercuriell View Post
the latest has a novel two piece design whereby the front piece is isolated by the main frame by bridging CNC/O-ring dampers.
whats the idea behind this?
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote
Old 11-26-2012, 09:38 AM   #70
BenScoobert
2 reasons, firstly it makes a sacrificial front portion of the frame if you stack it on the nose, increasing the chance you won't have to rebuild the main frame. Secondly, in a hope that the any vibrations are dampened by the rubbers holding the frame portions.
Old 11-26-2012, 05:46 PM   #71
jamin_00
Also it will protect the ESC and front li-po more so by them being on this sacrifical part
Old 11-27-2012, 12:52 PM   #72
Mercuriell
It does actually work, I downed my Dune very heavily on its skids, enough to break bth sets of landing gear, and it broke the front CF mount attachment. Was a 3 minute job to swap outnthe front frame piece, and 1/3 the price!
John
Old 02-22-2013, 02:50 PM   #73
Arclight338
John, as usual your work and presentation is exemplary. As a direct result of your attention to detail, I will more than likely be $900 or so dollars LIGHTER in the wallet.
When I first saw the Dune, I was interested. NOW- I just HAVE to get one-ASAP
It really is a great time to be in this hobby!!
T-Rex 700 Nitro ,BLITZ AVRO 90, M.A. Fury 55FBL, SAB Goblin 700, T-Rex 500, T-Rex 250,T-Rex 600E DFC, Outrage Velocity 50V2
Arclight338 is offline        Reply With Quote
Old 02-23-2013, 05:11 PM   #74
Mercuriell
Thanks for the kind words, I really like this heli, put the rebuild, of my beloved Logo 600 on hold since building and flying this one
John
