Old 09-30-2012, 02:50 AM   #1
Thalios
Default New Prôtos 700 pictures!
Here's more pictures.
From what we can see, the servo placement is identical to the actual Prôtos range.
edit: Ooops, looks like I linked a site I wasn't supposed to.
Here's the actual pics:
Lynx Heli Team Pilot
Prôtos CF, 130X and many others.
CarbonCore H6 650mm Wookong-M
All on DX18!
Thalios is offline        Reply With Quote
Old 09-30-2012, 04:06 AM   #2
crf69
do want!!!
Sent from my phone using Tapatalk2...otherwise i would of sent it from my home PC.
Buy good stuff then you never have to apologize to yourself for being an idiot....
Stay Inverted My Friends. Ryan Robinson 7hvGob7GauiX5Warp360SYNE5
"How high does it go?" Love that question.....
crf69 is online now        Reply With Quote
Old 09-30-2012, 05:43 AM   #3
mahbouni
Do we still have to wait until 2013?
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos
mahbouni is offline        Reply With Quote
Old 09-30-2012, 06:40 AM   #4
crickr1
Wow, that tail gear is huge! Can't wait for a purple Ptotos!
can you say,,Purple, Protos, Prototype, 3x fast?
Keep it in the air!
Lovin MSH!
hybrid Gaz/otos fbl,stretched 6s MiniP Stretched PROTOS 500 ,EC135 Era/Protos500,Compass 6HV, Gaui NX4 all MSH-Brain/Futaba8FG Compass 3D+ CGY750
crickr1 is online now        Reply With Quote
Old 09-30-2012, 10:40 AM   #5
kavic5150
Post
I like the belt guides on the main gear.
But I'm going to go and cry cause there is no FB option. Maybe RC-tek will make me a 700 size i2 flybar head if I ask nicely.
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T.
Save the flybar !!
kavic5150 is offline        Reply With Quote
Old 09-30-2012, 11:08 AM   #6
x3mperformance
It looks awsome.
I like it, but have way to many projects now, to "need" a Protos 700.
Align T-Rex 450 Pro DFC BeastX, trainer.- Align T-Rex 600E Pro. SAB Goblin 700 - Maxed out Blade mCP X V.2. 4x Nine Eagles Solo Pro's.
Spectrum DX8. x3mheli.dk
Any landing where you only need to bend once, to pick up your bird, was a good one...
x3mperformance is offline        Reply With Quote
Old 09-30-2012, 11:14 AM   #7
wespen
Looks nice...
I guess they couldnt make the tail speed high enough without second stage on main gear... so big tail gear.
Any other info?
Motor on top or bottom? 3rd bearing for motor shaft?
Battery loading? Tray? Front, Bottom or side by side?
I see they are in line with Protos design. Very light frame.
Same as smaller Protos, this will leave nothing when crashed
Well at least metal servo holders come as standard
- Croatian RC forum
wespen is offline        Reply With Quote
Old 09-30-2012, 11:26 AM   #8
x3mperformance
Originally Posted by wespen View Post
Looks nice...
That might be due to some noise surpressing...
Old 09-30-2012, 01:00 PM   #9
kjoer
Pic from Fast Lad, supposedly taken after Tareq took it for a spin:
Fast Lad also has a vid of the Tareq flight on their facebook page, the quality of the vid is terrible though.
http://www.xs4all.nl/~rzavelli/rc_heli.txt
kjoer is offline        Reply With Quote
Old 09-30-2012, 01:19 PM   #10
banditpowdercoat
Looks nice...
Any other info?
Bigger tail gear SLOWS the tail....
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote
Old 09-30-2012, 01:59 PM   #11
kavic5150
Post
Can someone post that vid for those of us that dont do facecrook?
Save the flybar !!
Old 09-30-2012, 02:02 PM   #12
wespen
Yeah, I meant they couldnt get right tail speed
- Croatian RC forum
Old 09-30-2012, 03:11 PM   #13
Toeh
Cyclic servos? Savöx yeah but model?
Toeh is offline        Reply With Quote
Old 09-30-2012, 03:16 PM   #14
d.porte
Why is the tail servo still on the boom ???
d.porte is offline        Reply With Quote
Old 09-30-2012, 04:03 PM   #15
SAMUELPINONFLORES
Here is a nice video by Stefano Cattaneo
FUSION 50 /CGY750
PROTOS 500 /SKOOKUM SK540BELT CP V2,CYPHER 3D
BIG NAZA QUADCOPTER
SAMUELPINONFLORES is online now        Reply With Quote
Old 09-30-2012, 06:32 PM   #16
whisperdancer
Looks like it will be possible to take the belt off without disassembling tail case. Very nice indeed.
MSH Prôtos CF FBL Stretch - Scorpion 880KV, YGE 60A, 3x s9650, BLS251, VBar 5.1
E-flite HABU 32
Ikarus EXTRemA 330S
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote
Old 09-30-2012, 06:40 PM   #17
desertstalker
Because its simple and it works, why not put it there?
-DX8
desertstalker is online now        Reply With Quote
Old 09-30-2012, 07:47 PM   #18
mahbouni
+1 easier to access and adjust
Old 09-30-2012, 09:53 PM   #19
corrosionate
I hate boom mounted servos because you have to fiddle with them so much and just when you get it exactly right...... you tighten the clamps and it moves so you start all over. Then if you bump the thing it moves.... and you start all over. Then if you have a boom strike or slight boom bend you have to undo it all and start over on the new boom
Drives me nuts, but someone pointed out to me that on a belt driven tail you move the boom in and out to tighten the tension on the belt, so if the servo were frame mounted, you'd have to readjust the tail pushrod every time you change or tension the belt, so boom mount actually makes more sense. Still a pain, but slightly less of a pain than the alternative. On torque tube driven tails the frame mounted servo is definitely the only way to go IMO because you usually only have to adjust it once, and don't have to mess with it again.
I'd like to see a sliding frame mount for belt tail helis. Wouldn't have to add any more weight than another carbon fiber rectangle and a couple more screws, but that would only eliminate alignment issues in one axis. Would still have to be fiddled with a little every time. Oh well, boom mount does work once you get it lined up straight. It won't bother me enough to boycott a maxi-Protos.... It didn't bother me enough to boycott a 500 Protos.
I would also like to know what model Savox servos those are in the pics. I just might begin collecting electronics for a Protos 700 so that when it comes out I'll have all the stuff to start the build right away. If I can figure out what all is being used on the prototypes It might help to be sure what I choose will fit.
Align: 250, 450 Pro v2, 550 v1, Chaos: 600
MSH: Mini Protos 6s stretch, Protos 500 plastic
Compass: Warp 360
B:130x, 300x, 450 FBL
corrosionate is online now        Reply With Quote
Old 09-30-2012, 10:58 PM   #20
alexf1852
Not sure what you are referring to. But I have two Protos 500 with tail boom mounted servos. Never had any problem lining up the servo and tightening. Just don't loosen the screws too much so that some friction remains as you turn/move the servo on the tail boom. Seriously, I've changed belts/boom dozens of times on my two Protos and it's easy.
MSH Protos * 2, SAB 630
alexf1852 is online now        Reply With Quote
