Old 09-30-2012, 11:08 PM   #21
trickybit
Originally Posted by banditpowdercoat View Post
Bigger tail gear SLOWS the tail....
Yeah, unless they used the elevated tail shaft to put some extra long tail blades on, they tail will have to spin as fast as a comparable heli, in which case, that belt is going to be FLYING in the tube.
Logo 600: Jive, BLS, VBar "Hansen Built"
T-Rex 550E: ICE, BLS 251, VBar
Protos 500 (plastic): Jazz, Hyperion/Scorpion, VBar BLS 251
Tornado Coin-Op: Gray marble, XTremeSoft wraps
trickybit is online now        Reply With Quote
Old 10-01-2012, 01:39 AM   #22
banditpowdercoat
Not following you?? Longer tail blades would be slower for same force. And the belt only goes as fast as your HS dictates. Im pretty sure belt speed isnt an issue. Look at belt driven 450's spining 3500+RPM
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote
Old 10-01-2012, 02:09 AM   #23
trickybit
With, say, twice as many teeth on the tail gear, the belt has to move twice as fast, linearly, to spin the tail rotor at a given speed. So compared to other belted-tail 700s, this huge belt will be moving twice as fast as normal (assuming tail rotor speed is the same).
With longer blades (enabled perhaps by the tail being raised), they could maintain tail authority with slower tail RPM. This would mean they could gear the ratio between the headspeed and that tail shaft 'differently," to move less belt.
The headspeed only determines the belt "speed" by virtue of the belt drive gearing.
In a fast 450 @ 3500, the tail rotor gear is very small. Half as many teeth would rotate twice as fast for same belt speed. I don't know the ratios of a 450, and while interesting, it's not direct comparison to other 700s and large belt-drive helis.
Old 10-01-2012, 02:24 AM   #24
banditpowdercoat
Ya OK I get ya. But also know, the faster a belt moves around a pulley, the less friction it has. Its why Belt helis are really efficient when spooled up, yet don't spin as free as a TT when spun slow, like by hand. The faster a belt moves around the pulley, it gets thrown off it, so to speak, and acctually has less tension on the pulley, yet is tighter in the boom. That's why we need cogged belts, to ensure tooth engagement with the pulley. Larger pulley will also flex the belt less, resulting in even less rolling friction.
My B400 tail pulley was worn, teeth were almost smooth. At a 2700RPM, I could do tic tocs FBF, etc etc no issues, But ramp to 3200, and the belt was flying off the pulley and loosing contact. Tail blow outs everywhere, even on a lot lesser demanding moves. Small pulley, less teeth in contact and more centripital force pulling belt off pulley at speed
Dan Pesonen
"Tri-Flow"
Old 10-01-2012, 03:21 AM   #25
kavic5150
Post
If I get a P700 I want a hacker motor to go with it. Only makes sense, what with the purple canopy and all.
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T.
Save the flybar !!
kavic5150 is offline        Reply With Quote
Old 10-01-2012, 06:09 AM   #26
Dr. M
IMHO, the most efficient way to get more tail authority is to spin it faster. Bigger blades will sap too much power and tend to stall sooner. It would be relatively easy to bring up the tail gear ratio above 4.75 by making the tail drive pulley a few teeth smaller.
Fly first ask questions later.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0
Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion
Dr. M is offline        Reply With Quote
Old 10-01-2012, 06:16 AM   #27
vs0587
Alpine Heli Smack Down 2012
3 photos taken Sunday:
vs0587 is online now        Reply With Quote
Old 10-01-2012, 08:39 AM   #28
rossk
They are great looking photos, good job on the photography skills.
There is a vid coming from corrado in the brain forum..
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp
MA Whiplash - Kosmik 200, Pyro 700
Protos500Stretch-YGE90+3226-900 Protos500-YGE80+MVVS950 ProtosMiniStretch-YGE60+2025-1360
MSH Brain Spektrum DX8
rossk is online now        Reply With Quote
Old 10-01-2012, 08:42 AM   #29
vs0587
Thank you!
Old 10-01-2012, 08:56 AM   #30
rossk
Thank you!
So you are the photographer?
I have a hard enough time getting the heli in the shot, let alone looking as great as those!
I'm guessing there are a lot of shots on the cutting room floor?
Old 10-01-2012, 09:07 AM   #31
vs0587
Yes, i'm the photographer..
Yesterday i took about 700 photos.... many are out of focus and discarded, caused by very fast movement of heli..
What do you mean with "I'm guessing there are a lot of shots on the cutting room floor?"
i don't understand, my english isn't very good...
Old 10-01-2012, 09:29 AM   #32
kjoer
Vid recorded by Iwan, a Dutch guy, thanks dude!
http://www.xs4all.nl/~rzavelli/rc_heli.txt
kjoer is offline        Reply With Quote
Old 10-01-2012, 09:51 AM   #33
banditpowdercoat
It's a saying here in the west. Meaning the shots you discarded. Back form the days of film photography. After all the shots were developed, the ones that were no good, would end up on the floor. Discarded. Cutting room, was the room they would cut the photos to size, and discard the junk ones on the floor
Dan Pesonen
"Tri-Flow"
Old 10-01-2012, 10:35 AM   #34
vteknical
Not blown away as I had hoped to be. It's getting harder and harder to re-invent the wheel.
The bitterness of poor quality, lingers long after the cheap price is forgotten.
Buy the best and only cry once!
vteknical is offline        Reply With Quote
Old 10-01-2012, 10:50 AM   #35
HighFreq
That was Tareq 1st fly on the Protos 700, more "aggressive" flying from him and Dario are coming hopefully later tonight on the tube
Corrado
HighFreq is online now        Reply With Quote
Old 10-01-2012, 01:39 PM   #36
mahbouni
Sounded like about 2150rpm. Crank that up to 2300rpm and it will rip.
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos
mahbouni is online now        Reply With Quote
Old 10-01-2012, 01:56 PM   #37
puttekula
Never mind what HS in this movie. Speed it up like in BKs commersials and it will ripp ur ass of. Hands down ,I will buy it when its available...
BTW, when can I send my money to Italy?
puttekula is offline        Reply With Quote
Old 10-01-2012, 03:09 PM   #38
drvic
so if you are interested for some more video of P700 , we got some ....
http://www.flyfreak.net/helikopteri/...eli-smackdown/
looking forwerd for preodres....
drvic is offline        Reply With Quote
Old 10-01-2012, 03:43 PM   #39
meltdown
Default AHS 2012
I was yesterday in lodrino and here is small video of protos 700, I shot a little because I just had to watch it in live, heli is the beast is too good, fast, agile, and power,
helicopter going in my collection that's for sure, because when I heard only the sound, I was impressed, heli earned the highest grades in my opinion!
I hope I helped
meltdown is offline        Reply With Quote
Old 10-01-2012, 03:58 PM   #40
meltdown
