Old 10-08-2012, 05:15 PM   #61
desertstalker
Originally Posted by mahbouni View Post
I do think the tail shaft bearings look a little small
The outer race is not shown there, its inside the CF from the look of things. Bearings look ok to me...
-DX8
desertstalker is online now        Reply With Quote
Old 10-08-2012, 06:28 PM   #62
mahbouni
You think the CF plates either side of the tail pulley are countersunk to fit a wider bearing than what you can actually see? You could be right as the bearing isn't flush with the outside of the plates. Then again there's not that much CF material around what you can see. Looking at the inside of the plate on the other side, it looks like a flange bearing. Hopefully we will have more pictures to clarify.
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos
mahbouni is offline        Reply With Quote
Old 10-08-2012, 08:12 PM   #63
trickybit
I zoomed in and what I see is a bearing not as deep as the CF plate, and I think I see the outer race just fine. Agree that it's a flange bearing.
I don't think there's any reason to worry about the bearing. It looks like a Logo bearing.
Logo 600: Jive, BLS, VBar "Hansen Built"
T-Rex 550E: ICE, BLS 251, VBar
Protos 500 (plastic): Jazz, Hyperion/Scorpion, VBar BLS 251
Tornado Coin-Op: Gray marble, XTremeSoft wraps
trickybit is offline        Reply With Quote
Old 10-08-2012, 08:55 PM   #64
banditpowdercoat
Im not worried about the bearings or the CF sideplate. Im really likin the open side tho. Loosen idler pulley off and can slide belt completely out of the tail without taking tail apart. Should make boom/belt changes a lot easier too!
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote
Old 10-08-2012, 09:09 PM   #65
trickybit
I thought perhaps you may be hallucinating. But on inspection, you seem to be right. Makes me a little nervous, but I'd like to see how beefy the part is. I guess they run motorcycles with the rear wheel suspended from one side. That definitely is radical.
Now I want to go find a photo from the right side, to see if I can see how beefy it is.
Looks like one might have to remove the vert fin in order to get the pulley bolt out.. but still a nice feature.
Old 10-08-2012, 09:14 PM   #66
trickybit
Photo of the right-hand side on facebook: http://www.facebook.com/pages/Tareq-...01255346637348
Old 10-24-2012, 08:44 AM   #67
puttekula
As I see it there is a bearing on both sides of the pulley. Anything else isnt possible for this kind of application.
puttekula is offline        Reply With Quote
Old 10-24-2012, 09:11 AM   #68
banditpowdercoat
What are you talking about?
Dan Pesonen
"Tri-Flow"
Old 10-24-2012, 09:55 AM   #69
trickybit
If you look closely.... the tail pulley shaft is indeed supported, by a bearing in a thick CF plate. The CF plate is bolted to an aluminum chunk of the tail case. But note that this part of the tail case is not attached to the left side of the tail case, only the right.
So the belt can be removed without first removing the tail pulley shaft and pulley or taking the case apart.
It's not 100% clear that you can sneak the belt out from under the idler pulley without removing that pulley first, but again, it's directly bolted into a member only on the right side of the tail case, so it would be pretty easy.
Pretty innovative.
Old 10-24-2012, 12:43 PM   #70
mkovalcson
I like the tail on this and think this will be a very unique 700 series heli.
So far it all looks really good.
Unfortunately I think my 130X, Protos 500, planned E5, and TDR seem like a well rounded fleet and I'm really not itchy to get anything in addition or to replace any of these in the near future.
I think I would be torn between a Protos 700 and a Diabolo if I were to add a new 700.
Henseleit TDR, Synergy E5, MSH PROTOS 500, 130X
Jeti DS-16, Skookum SK-GPS
mkovalcson is offline        Reply With Quote
Old 10-24-2012, 01:02 PM   #71
drvic
i still havent got answer ........does somebody know when are we going to get some of p700 on market ???
drvic is offline        Reply With Quote
Old 10-24-2012, 01:13 PM   #72
th0rg0d
Later. Maybe this time next year.
Mini Prôtos AR7200BX
Prôtos stretch AR7200BX Savöx 1250/1290MG SAB 470mm
ALeeS Rush 750 YGE 120HV/4035-530 AR7200BX Savöx 1258/1290MG Rail 696/116
mCPx stretch uHeli head DX18 AMA# 448427
th0rg0d is offline        Reply With Quote
Old 10-24-2012, 01:32 PM   #73
puttekula
Pretty innovative.
Ahh, now I see what u mean. Innovative yes, but whats the benefit of it? Is it that necessary to be able to swap the belt without losening 2 screws? And risking a flexy construction for that?
Old 10-25-2012, 12:18 AM   #74
trickybit
I doubt there will be flex in a big chunk of aluminum.
I like that you can get the tail all set up rolling smoothly, check the bearings, etc, and then slip on the belt.
Also, at the 700 size, with the tail servo on the boom, you could pop the tail off and throw the heli into a small car without much fuss.
Old 10-25-2012, 01:48 AM   #75
mahbouni
Now there's an idea
Old 10-25-2012, 03:12 AM   #76
rossk
I was just going to get a bigger car when I start with 700's, haha
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp
MA Whiplash - Kosmik 200, Pyro 700
Protos500Stretch-YGE90+3226-900 Protos500-YGE80+MVVS950 ProtosMiniStretch-YGE60+2025-1360
MSH Brain Spektrum DX8
rossk is offline        Reply With Quote
Old 10-25-2012, 04:59 PM   #77
mkovalcson
The TDR is actually designed to allow the boom to be unclamped and slide out.
Loosen two bolts and pop open the clevis pin attaching the tail rod to the tail servo arm and off it comes. In Europe where those itsy bitsy cars are more common this is an important feature
There are also the two struts to undo from the frame.
From the Henseleit website.
"For people who have not much space in their cars it is especially advantageous that the tail boom including the front pinion, the struts and the push rod can be removed from the helicopter within less than a minute. In order to do so, you only have to detach both struts as well as the push rod in the front area of the mechanics, loosen the two lower attachment screws of the tail boom holder and pull out the tail boom to the back. The tail boom is automatically fixed at the correct position in the front holder, so that it is always exactly aligned after having been pushed in. "
Old 10-25-2012, 05:31 PM   #78
andersn
my friend has a tiny electric car called buddy (its the mfg)
it can fit a funcub and 700, but wing on funcub has to be taken off fits only 1 person then.
honey bee king II
andersn is offline        Reply With Quote
Old 10-26-2012, 03:21 PM   #79
trickybit
Back to topic perhaps?
Sent On Fire
Old 10-26-2012, 10:50 PM   #80
Rob43
I don't (yet) own a Protos, as asked my MrDan. I just can't see enough detail here to confirm what design features secure the pulley to the shaft. If that is where set screws are used, then, I would think it should be okay, since the hubs are also secured (typically) by a single set screw. I have had these wiggle loose, but were found from some altered tail behavior, and not a loss of tail control. I can understand your points though...just can't judge what it's integrity is from these pics. I expect that testing will prove it's validity or problem before we see them shipped. MSH doesn't seem to rush their models out too quickly. I bet they will release an excellent machine. I am mainly wondering about disk loading...the 500 is quite light. A lighter 700 would be another unique attribute for the class.
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
