Old 10-28-2012, 10:38 PM   #81
kavic5150
Post
So anyone know what the motor kv will be? Any guesses?
I'd like to see more motor options but it might be wishful thinking on my part. Guessing it will be rather low compared to other 700s.
kavic5150 is offline        Reply With Quote
Old 10-28-2012, 10:45 PM   #82
banditpowdercoat
I'm guessin it will be like the 500 and the motor will just plain work. No need to switch
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS, T-700N
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote
Old 10-29-2012, 03:28 AM   #83
desertstalker
Judging by the colossal main and tail pulleys, I would guess its going to be standard for a 700, perhaps the low end (450-500Kv).
-DX8
Old 10-29-2012, 03:49 AM   #84
mahbouni
I believe Corrado said the prototype was being flown with a 4525-520 Ultimate. If this is the recommended motor then I have no intention of changing it
Oxy3+ | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | JR Forza 700 | VControl
mahbouni is online now        Reply With Quote
Old 10-29-2012, 04:55 AM   #85
rossk
I thought it was going to one of the lightest 700's, so a massive power system was not going to be needed.
Having said that, I will still stick the biggest motor I can fit into it for extreme performance
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote
Old 10-29-2012, 05:24 AM   #86
mahbouni
I'm sure there will be a barebones kit so you can choose what ever motor you like for it. A Pyro 700 with 4000mAh packs would probably make the lightest setup. Or if you want you could use up the weight allowance on bigger packs, say 6000mAh and get longer flight times. No setup is ideal for everyone but if the airframe is very light then there is flexibility for everyone. Unlike some machines that are so heavy they need an overkill powersystem, which make it even more heavy and flight times even shorter.
Old 10-30-2012, 01:21 PM   #87
puttekula
And where is it...? Must have one soon....
puttekula is offline        Reply With Quote
Old 12-20-2012, 11:02 PM   #88
Freeskiken
Looks Great. Can't Wait.
Logo 600SE, 500SE, Rave Ballistic 635, Synergy E7SE, E5, Diabolo 550, V Control, Neo
Freeskiken is online now        Reply With Quote
Old 12-25-2012, 10:39 AM   #89
Dray1972
I just want to know if a 160Amp esc is needed since the belt creates excessive drag.
Dray1972 is offline        Reply With Quote
Old 12-25-2012, 11:45 AM   #90
mahbouni
No you will probably find that overall the Protos 700 uses less power than most other 700's. The biggest problem to solve is gear ratios. To use the same KV motors in an all belt system you need a massive main gear.
Old 12-25-2012, 11:58 AM   #91
banditpowdercoat
Belts don't make extra drag
Dan Pesonen
"Tri-Flow"
Old 12-25-2012, 06:07 PM   #92
kjoer
No sir, it does not.
Though gears feel like they create far less drag, their drag actually is dependent on the load, especially with bevel gears. Whereas, with a belt, this is not the case.
http://www.xs4all.nl/~rzavelli/rc_heli.txt
Mini Protos (350) / Protos (425) / Goblin 570 Carbon / 2x Goblin 700 Competition Carbon - all V-Bar
kjoer is offline        Reply With Quote
Old 12-25-2012, 11:06 PM   #93
desertstalker
In fact, a belt actually has less drag at high speed, since the belt is pulled away from the pulley by the rotation.
-DX8
Old 12-26-2012, 03:21 AM   #94
Dr. M
+1. The centrifugal force on the belt reduced the friction against the cogged pulleys to almost nothing, while at the same time throwing the belt against the idler pulleys, securing it in place. The system is beautiful in its simplicity.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote
