Go Back   HeliFreak > R/C Electronics Support > Hitec Radios > Hitec Gyro/Servos
Hitec Gyro/Servos Hitec Gyro and Servo Support
Old 10-02-2012, 03:56 PM   #1
PharmD
Default Hitec 5245MG bearings.
Does anyone know of anywhere other than TowerHobbies to get Hitec 5245MG servo bearings? They are OOS. I know that they are Universal. Is there another bearing out there that works just the same? Thanks in advance.
PharmD is offline        Reply With Quote
Old 10-06-2012, 05:58 AM   #2
wanderer56
Do you have the bearing size?
Trex 500-3226-1600, 13T, Koby 90LV, HS-5245MG, DS520, AR7200BX, DFC
Trex 450 Sport-450M, 13T, RCE-BL35X, HS-5065MG, HSG-5084MG, DS760
DX8
wanderer56 is offline        Reply With Quote
Old 10-08-2012, 10:23 PM   #3
PharmD
Yes. They are 10mm OD-6mm ID-2mm Thickness.
T-Rex 500E
Scorpion HK-3026
Phoenix ICE 75
Hitec 5245MG x3, Futaba S9257, Mavrikk G5 FBL Blades, Microbeast, RJX FBL500 Head
Old 10-10-2012, 07:52 AM   #4
wanderer56
Only place I can find them is here:
http://www.vxb.com/page/bearings/PROD/Kit8771
DX8
Old 10-10-2012, 12:18 PM   #5
PharmD
That's great! They have them in stock too. Thanks a bunch.
T-Rex 500E
Scorpion HK-3026
Phoenix ICE 75
Old 10-11-2012, 06:49 AM   #6
wanderer56
Kind of pricey, but your welcome.
A few other places for bearings for future reference:
http://www.bocabearings.com/default.aspx
http://helidirect.com/rc-bearings-c-1_95.hdx?
http://www.rcbearings.com
DX8
Old 10-30-2012, 10:10 PM   #7
RC-Bearings
Are you sure of those dimensions? VXB is the ONLY source I could find for a 2mm thick bearing like that. If it is actually 2.5, then it is an MR106. Those are cheap and used on some Futaba servos.
Paul McIntosh
Stainless, Ceramic and steel bearings
5% discount for the Freaks. Code: helifreak
RC-Bearings is offline        Reply With Quote
Old 10-31-2012, 01:12 AM   #8
A.T.
Hitec Micro Servo Ball Bearing e.g. HS-65 = MR85.
Hitec Universal Servo Ball Bearing = #58471 OD: 10mm ID: 6mm Width: 2.5mm = MR106
Hitec Big Ball Bearing for HS-805BB & 815BB = #58473
Much more under sub section
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
e.g.
. Servo - Horn Arm Spline Count and Inter Brand Compatibility
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline        Reply With Quote
Old 10-31-2012, 12:46 PM   #9
PharmD
That's what the specs on them say.
T-Rex 500E
Scorpion HK-3026
Phoenix ICE 75
Old 11-11-2012, 07:36 PM   #10
A.T.
Default HS-5245MG - Ball Bearing Size
e.g.
below
Alan T.
Hitec Korea QA have confirmed as follows:
HS-5245MG - 10mm OD x 6 mm ID x 2.5 mm width ( use MR-106 bearing).
Alan T.
