Old 10-03-2012, 05:53 AM   #1
jmdanna
Default Does anyone know the difference between all of these parts?
http://www.heliproz.com/MA128-114-13...nfo/MA128-114/
http://www.heliproz.com/MA128-112-Cl...nfo/MA128-112/
http://www.heliproz.com/MA128-110-Cl...nfo/MA128-110/
I have the whole unit, the one that is 68 bucks, and the pinion does not screw out. Are the first two links new parts? Are they a drop in replacement?
Jake
Team AleeS RC, Team A Main Hobbies
AleeS RC Rush 700, MA Fury 55, Trex 450fbl pro, Blade 130X
jmdanna is offline        Reply With Quote
Old 10-03-2012, 06:08 AM   #2
Peter
The pinion WILL screw out ......
Peter
Furion 6 FBL ; E,N and G Whiplash FBL ; 3 Spectra G FBL ;3 Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: Aeolus KME 60 , 2 Velocity 50's FBL; few 500's.. All BeastX ; guided by XPS .
Peter is offline        Reply With Quote
Old 10-03-2012, 09:33 AM   #3
Rudy
Yep it does unscrew, it may be tight but it will come out.
Rudy - Bend OR/Houston TX
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote
Old 10-15-2012, 07:32 PM   #4
jmdanna
okay thanks. I was looking in my manual for something else and noticed that the clutch bell is two parts, pre-assembled at the factory. cool
Jake
