| 700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Anyone out there using this?
http://www.ebay.com/itm/ALIGN-T-Rex-...item20c803c70c Seems like a good idea, but I'm not a fan of Dean's connectors. |
#2 | |
or PRC6 connectors are recommended http://www.progressiverc.com/prc6-co...s-2-pairs.html Then you can use a series connection to power your motor ![]() ![]()
At the precipice, we change! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team GrandRC |
I don't use the battery serial connector either. I use ec5s with a serial configuration on the esc wires....
Trex 500esp fbl dfc 6s Trex 600cf fbl 5 blade Hughs 530f TT 6s x2 Trex 600efl Pro fbl 12s Trex 700e v2 12s Chaos 600e fbl 4 blade Blackhawk 12s Chaos 600e fbl Airwolf 12s BeastX DX8 DX18QQ TX |
That's the way I'm leaning, just looked like a cleaner solution, but as I stated before I don't like Dean's connectors.
I'm not a big fan of deans connectors either, but I like the clean look the adapter offers, and I have not had one come loose.
#6 |
Installed one on my DFC. Cool thing it looks like it came with the heli matching up with the side frame pattern. Very nice clean look. Also used 3m tape between the frame on connector.
☆☆☆T-REX 700 DFC v3, AR7200BX, ICE2 160HV,DC-UP MARK II ☆☆☆MKS HBL950 & MKS HBL980, GRYPHON EXTREME REGULATOR ☆☆☆POWERED BY THUNDER POWER LIPO'S |
#7 |
Wow , that looks really sleek.
Trex 700E V2 - Canomod Phantom V2 Canopy, AR7200BX, CC BEC PRO DX8! |
#8 |
That looks really good and simple. I have always used Deans and never had an issue to date. That is probably what i would go with.
#9 |
I use the EC5 connector cable as shown above,this is hidden under the canopy so you can't see any connections whatsoever and nothing bolted to the sideframe.
#10 |
If i wanted it hidden it would have been hidden...i have it out like that so it can be easily disconnected in a mishap without having to take the canopy off.
