| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
Hi Folks
I have worked all night long and could not get R7008SB to run. I have the SK SBUS wire contented. I have all the servo wires attached to the SK. I have the BEC contected to the SK at the IO B port it lights up the SK system. I have up load that it is a SBUS receiver. What else do I have to do to make it work. Thanks |
what do you mean it's not working? Please explain in a bit more detail.
If this is a 720 you have the Rx attached to the 720 with special lead? Try the other port next door.
If this is 540 then this should be connected to IO-B! with ordinary servo lead. Is there power to the Rx? is the light on? Have you bound the Rx to your radio?
SimStream wireless from your transmitter to simulator http://www.modelguard.com |
You have the sbus lead connected like the one on the left in the picture?
Don't forget to use a power lead from the Rx to the SK (a servo lead with only + and -, no signal).
#6 |
Yeah. As Frog just said you will need to run a lead like the Sk ones that go from Sk to power bus and take out the signal wire. This will now give enough power to the rx.
Sent from my iPhone 4s using tapatalk
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep |
#7 |
that wont stop the system working on the bench though, it just prevents brownouts
#8 |
Mine did, when using the 720 with the s-bus adapter cable the rx wouldn't get a green light, instead i got a red/green flashing power warning. Used the lead without signal and all was well
#9 |
I take my comment back then!
#10 |
It was something to do with the output voltage through the s-bus adapter lead being just under the futaba's required voltage. It was just under. Lucky the futaba Rx's are high voltage as i'm pumping 8.4v into mine..
#11 |
Hi Folks
I have the SBUS going to the SK unit the way the photo shows. I have the power from BEC going the SK unit only. How should the power be getting to the RX. I have the SK power connected to the IO-B port only. Thnaks |
#12 |
Take servo lead, remove the signal wire (white/orange) and plug one side of the remaining lead (with a + and - wire) an open port on the SK and the other into an open port/ power port in the Rx.
#13 |
Thanks for the info I will give it a try.
#14 |
=] yes an open port, but not the ex-led!
georgi UK |
#15 |
This thread has got me concerned. I've got an SK-540 connected to a 6208 SBUS rx. I've only got one cable going to that RX: the SBUS lead to IO-B. I'm running a 2S lipo into the SK540. No problems so far, 7 flights in.
How much power does the RX need? Why isn't one servo lead good enough? I'm missing something here...
* Outrage Fusion 50 FBL, Torq HV BL servos, SK-540, Quantum 4125-560, ICE2 HV80, 12S, Edge 623 * Align T-Rex 500E, DFC Head, SK-540, ICE 75, Mavrikk G5 Pro * Blade Nano CPX / mCPX / 120SR / mSR * Futaba 8FG Super & Spektrum DX7 dsm2 |
#16 |
As you can see the power is contented to the receiver. Then I contented a cable from the receiver to the SK unit for power. Then I contented the SBUS wire. When plug the power in the receiver works. Then I contented the power to the SK the red light stays on till i move the throttle up to full then it turns green but dose not pump
The servo start to chatter. When I move the sk unit it tries to move the servos that are contented. What is the problem. |
#17 | |
Sent from my GT-I9300 using Tapatalk 2
#18 |
=] throttle reversed in the Tx?
georgi UK |
#19 |
Georgi got there 1st!
Ps. The lead that you've used to take power from a spare port to the rx should be plugged in all the time. It's only when you make your normal connection that it all becomes live. Sent from my iPhone 4s using tapatalk
#20 |
Got it, thanks
