| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
#21 |
OK guys I still need help. As the photos show I have the power going to the receiver then to the sk unit is that ok.
Should I be going throught the set up before pluging in the servos. |
#22 |
=] All 4 Wizards must be completed, they explain when to connect servo's....
georgi UK |
#23 | |
I am really at a lost here now. I checked to see if the receive is linked to the radio and it is working. I plug a servo and it works. But when I plug it into the SK nothing is happening. I went throught the set up wizard. I have the SBUS receiver and sent to the unit. Like the JR sat do I have to bind the sbus to the sk and how do i do it. One other thing is how do you tell if the Receiver is set to the right mode. I have followed the instructions with the radio and can not tell if it is set the sbus function. |
#24 | |
* Outrage Fusion 50 FBL, Torq HV BL servos, SK-540, Quantum 4125-560, ICE2 HV80, 12S, Edge 623 * Align T-Rex 500E, DFC Head, SK-540, ICE 75, Mavrikk G5 Pro * Blade Nano CPX / mCPX / 120SR / mSR * Futaba 8FG Super & Spektrum DX7 dsm2 |
#25 |
I am using 18MZ radio
#26 |
I take it you've pushed the little button in and made the rx led turn green?
No need to bind it with the Sk. Futaba doesn't need it Sent from my iPhone 4s using tapatalk
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep |
#27 |
I have pushed the mode button tell the led flash red / green. Then I push the button tell it flashs twice. Then I hold the mode button again tell the for aleast two seconds. Then I turn the power off and on again by the instructions. But not sure how to confirm if it is set.
#28 |
When the led goes steady green
#29 |
#30 |
Yes, no need to touch it again once pressed and got the green light! Not sure on modes as i didn't need to touch them. It was set right @ default.
#31 |
You have done the correct procedure for high speed mode. Now make sure your rx is showing green light when tx and rx are both on.
Plug a servo into an ordinary port on the rx and check for movement. In the past i have had a faulty sk spec sbus lead and an sk540 that would only communicate through the spec lead and not through the servo bus. Sent from my GT-I9300 using Tapatalk 2
SimStream wireless from your transmitter to simulator http://www.modelguard.com |
#32 |
Looks to me like the sk sbus lead is faulty.
I had one where one of the fets or resistors was missing. Take a look at each end if the circuit board through the shrink wrap and see if there us a blank space that looks like there was a tiny black box shaped fet there. Sent from my GT-I9300 using Tapatalk 2
#33 |
Good point. I've had one like that too.
#34 |
I will check the SBUS wire when I get home.
#35 |
Well I looked at the SBus wire and seemed to have all the parts. I has two black chips on it. I had order a second one for another chopper. I tried it with no luck on that one.
I phone Futaba to make sure I was doing everything right to set up the receiver and it seems everything on that end is working. When I attached the wires to the SK unit the light turn green. I move the SK unit and the servos try to move. But no input from the radio seems to work. I have selected the Futaba SBUS and sent it to the sk unit. I am at a total lost why it is not working. Could some take a pic of working setup and post it here. I must be doing something wrong. I have tried to contact Sk directly but have not got any replies to my emails. I wish they had a support number listed like all the other companies have. It could be a real help to talk to some one in person. ![]() ![]() ![]() |
#36 |
=] assuming you have the input side correct?, what is your low voltage alarm set to?
georgi UK |
#37 | |
What do you mean by input side correct. I have set the low voltage alarm by BEC is this what you mean. I have pics earlier in this thread at how I have this wired. Thanks for the help |
#38 |
=] the SK will fail to play if there is something out with the Tx settings, ie, a throttle signal on start up....
georgi UK |
#39 |
#40 |
=] honestly don't know where to start on the info given here, it needs to be methodical, usb connected, what happens? Tx on, what is the gui now showing? make use of the gui to help pinpoint your issue? it has to be on the input side?
georgi UK |
