| nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help |
#21 |
Just got back from the field and a tiny bit disappointed, but only due to the weather changing and it getting very very breezy.
Managed to fly 5-6 packs (300mah) but then gave up as the wind just got far too strong, but when the wind dropped it flew awesome & I'm very impressed, even if I do say so myself. In flight you could feel the extra weight a bit so it maybe felt a little bit heavier/sluggish than the stock Nano (but not by much) but you could certainly feel the extra power when you need it & had really good power for a full 5+ mins, although the first 2-3 felt the best. Hopefully another Nano should arrive tomorrow which I intend to keep stock for practice inside and if the weathers improves then I can also fly them both to feel how they really compare outside. |
#22 |
Hello all,
Well, I finally finished my Brushless Nano CPx mod . Ran into a few problem with the esc set-up but was able to correct the problem thanks to all the help and tips from here. To give a few description of my project here all the parts I used:1. Nano CPx frame 2. MCPx frame 3. XP3A esc 4. HP03S 15800kv Outrunner (replaced with 1mm shaft from C05 motor) 5. MSRx Landing Skid 6. 8T pinion The final result was a BL Nano with a fully loaded weight of exactly 29 gram. I tested it this morning and it flew beautifully with much more power. I got 3.5 min of IDLE up flight from stock battery which is good but will also try a 7T pinion to see how it is. Anyway, I've attached some pictures and a digram I made for modifying the Nano frame using part of the MCPx frame. Enjoy. |
#23 |
Hey there forget the brushless what's that head spring mod about???
#24 | |
I like it. How long did it take you to mod the frame.
#25 | |
#26 |
#27 |
Update:
I noticed late yesterday that I had cracked one of the front canopy supports on my modified Mcpx/Nano frame. Now I don't want to go from having to replace nano motors every other week to now having to replace a Mcpx/Nano frame when I break a canopy pins (which I will) so thought I'd have another go at modding the frame but this time make the front canopy supports replaceable. Now after attaching the Nano 3-n-1 mount to the mcpx frame and removing the mcpx canopy supports completely I then used a soldering iron to melt away some of the plastic where the carbon tube would need to go & when I was happy with the placement I CA glued the entire thing solid. Also, I've now managed to remove about 2-3 grams weight from the rest of heli and it's starting to feel a little bit quicker, although the canopy still wieghts 2.3 grams just need to try to get that nearer to 1g if at all possible... Just now waiting for weather to improve so I can go outside and give it a blast. Last edited by Strangedaze; 10-11-2012 at 04:18 PM.. |
#28 |
Hi
What glue did you use to glue those frame parts together? |
#29 | |
The walkera esc only takes in neg (-) signal. You can get the negative signal at the soldered location shown above but the throttle is reversed. Just a curiosity, can you post a picture of the location that you use for your signal? I like to try this new location out since I have a 5A esc with converter that takes in neg(-) signal only. Thanks |
#30 |
Green arrows point to the negative PWM solder points. (both are the same)
#31 |
I'm pretty sure I used either medium of thick CA clue to attach the Nano 3-n-1 mount and the carbon tube to the mcpx frame. Once dried I then applied 2-3 light coats of thin CA glue over the whole section just to firm it all up & now it's rock solid.
QuESTion: ? I'm current using the following motor and ESC with this build. 1. Airbase Brushless Converter with 10A Built ESC for mCPx AIRMRXV2-10A http://www.fast-lad.co.uk/store/airb...a-p-17857.html 2. AEO M5 Brushless Main Motor for mCPX (11000KV, 1.0mm shaft) MM104-M http://www.fast-lad.co.uk/store/brus...m-p-19060.html 3. 8T pinion I currently know very little about Brushless motors and ESC'S so still got a fair bit of learning to do, but I bet I could reduce the weight by another 1g+ by using a lighter ESC, would I be able to use a 7A ESC or maybe Even a 3A ESC with the above motor and using the 300mah (MCPX) batteries? Thanks |
#32 | |
but does anyone notice that the signal (at the original location) from the 3in1 of the Nano CPx feels like it is not as consistent (like the motor might sometime spin really fast even though I'm not at full throttle in normal mode and the esc gets really hot sometimes and fine other times.) as the MCPx 3in1? I don't know if this means anything in term of ppm brushless signal, but I used a voltimeter to measure the voltage for the Nano and only gets neg(-) voltage increases with throttle movement but the increase in voltage vs. throttle is reveresed. If I measure for pos (+) voltage at the signal, I don't get any voltage no matter what thottle position I'm at. Whereas, with the MCPx, I get pos(+) voltage increase with throttle increase. To sum it all up, I'm trying to look for a signal location, pos (+) or neg. (-) on the Nano CPx in which the voltage increases with the throttle increases and test it out hopefully with better results. Thanks and sorry to question the original signal location if this is only a me problem and my lack of knowlegability in this area. |
#33 |
I havent noticed any difference at all compared to the way an esc works on the mcpx.
Ppm cant drive a fet, its a pwm signal.
Dylan ~ www.AstroidDesigns.com |
#34 |
Sorry duplicated post!
![]() Last edited by The.K; 10-13-2012 at 10:22 AM.. |
#35 |
any significant improvement on the thrust? how is the tail holding up with the BL conversation?
the stock nano thrust to weight ratio seems to be pretty low, about 49/29=1.68!? is it worth to do the BL conversation for mild 3D? as far as i can remember: the mCP X's stock thrust was around 90g for a gross weight of 45g, if im not wrong. this was improved to 110g for 43g with the C05 BL conversation, and the stock tail was holding much better. thanks for the help. |
#36 | ||
If Dylan didnt post his conversion i'd still be stuck in the brushed nano dark ages![]() Quote:
I will do another thrust test later with both a 7T and 8T pinion and new stock and a 180mAh nano batteries. Here is my latest vid of a stock and a 7T brushless nano. BTW Do not buy Maddog 180mAh 25c batteries they are crap |
#37 |
Hey thanks for the reply indoorheli and btw nice flying, you're flippin' even the stock one pretty much on the spot
![]() 1. did the BL conversation affect your durability (blade crack and spindle bend in crashes)? 2. may i ask what your setup is (Motor,ESC,converter and tail length)? since the mCP X was much more fragile after the BL conversation i measured my stock mCP X's thrust again today, and got these results: !it has about 50 flights on and the 300mAh Nano-Tech packs are not the freshest! gross weight: 48.2g (coz of, longer full CF boom and some reinforcements on the LG & canopy pins and the 300mAh Nano-Tech) fully charged 4.209V: peak measured neg. thrust (for a little less than 1sec): 86g -> 1.78 average measured neg. thrust (for about 3-4secs): 78g -> 1.62 half charged 3.861V: peak measured neg. thrust (for a little less than 1sec): 84g -> 1.74 average measured neg. thrust (for about 2-3secs): 74g -> 1.54 3. was your 51g an average over like a couple of secs or only a short peak value? 4. some people unplug their tail or give a rudder command to the left to have more power on the main motor for thrust measuring, did you do that for the 51g? 5. since it seems that the mCP ([78to86]/48.2g=1.62to1.78) has kinda the same amount of power than the nCP (51g/29g=1.75) outta the box!? which confuses me a lot! i've heard about the better tail authority, but will it hold on 3sec full pitch? 6. May i ask you about your opinion on buying a nano, even though i have a mCP which i'm not that happy with its performance and durability also stability (in normal pyros it always runs away to the back, even from a perfect hower point and a correct CG)? 7. is it necessary to do the BL on the nano for mild 3D like indoor flips, funnels and rainbows (no constant alt tic tocs)? sorry for the long post and the amount of questions and thanks a lot for the help, i do appreciate it very much. ![]() Cheers Nick |
#38 |
Here you go
1) I have still crashed pretty hard and I have not noticed an increased damage rate. 2) I am using a hp03s with a modified mount and a xp3A esc with BLHeli code and the stock tail. Though I would suggest waiting for Dylans modified hp03 as it will be easier to install. 3) 51g stock thrust was about 4-5 seconds at full charge 4) No I measure as stock would fly with tail left plugged in 5) While the numbers of the mcpx and nano seem to be comparable the big difference is full power doesn’t strain the system like the mcpx main motor did. Soon as I got rid of my mcpx main and went brushless my tail became stronger. I did not notice the same on the nano and the tail authority was solid anyhow unless my battery is crap or I have vibrations somewhere. 6) IMHO the nano is the best indoor heli I have ever flown for capabilities and durability 7) Stock it has no problem doing basic 3d and I am sure a real pilot can rock it and even do sharp tic tocs. My timing isn’t the best so I need more power to do certain maneuvers. But for rainbow’s, flips and funnels it can easily do all of that stock |
#39 | |
#40 |
Will the mcpx tail fit in the nano frame and work? and where did you get those canopies????
