Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 01-10-2013, 08:55 PM   #241
Supermartin
Default Battery life
So what's the run time using the stock 150mah battety? And how efficient is the bl motor compared to the stock? 30% more efficient?
Supermartin is offline        Reply With Quote
Old 01-11-2013, 10:40 AM   #242
daveapplemotors
Default run time
I tried a fairly new warmed 150mah E-Flite in my wild nano at 90% governed yesterday. No punch after about one minute.
But in my small living and dining rooms at 64% governed I get 4 minutes working it as hard as I can without inverting. I never hit LVC in 4 minutes indoors. My MSRs are for sale, now.
Dylan recommended 240mah Hyperions because they are light, have the right connector and give solid power for 4 minutes outdoors on 90%. I like them.
Efficiency from what I have read:
Brushes motor = 70-80% efficient
Brushless = 90-91% and higher
If your brushed motor was 70% and you changed to a BL at 91% then you would gain 21% efficiency and the gain would be an increase of about 30% from what you had.
I haven't crashed yet today. But, I haven't flown yet. And there is always tomorrow.
daveapplemotors is offline        Reply With Quote
Old 01-11-2013, 06:32 PM   #243
Supermartin
Thanks a lot daveapplemotors! Recently I changed the stock fuse of my nano cpx to the one used on the nine eagle bravo, which gives it a more scale look However, the new fuse added up to 7g of more weight! I can feel that the extra weight puts more strain on the stock motor and also shortens the flight time to under 3 min (I don't do 3D anyways). Also considering that the stock motor burns out after 50-100 flights, I think I might have to go brushless.
Do you guys think that the brushless will help in my case? Also a very beginner question: what's the life expectancy of a brushless motor? Indefinitely, I imagine??
Thanks!
Old 02-23-2013, 09:06 PM   #244
tmacrc
Default BLHeli NANO tail ini file
Looking for the ini file to flash an XP3A for a brushless tail on the Nano CPX
tmacrc is online now        Reply With Quote
Old 03-11-2013, 06:43 AM   #245
soonglim
Default Is DBL worthwhile on Nano?
I've tried a DBL brushless on the Nano, and I didn't find it to be any better than with just the brushless main (hp03se 16500kv). I've tried the hp02t and hp03t (with shortened Plantraco props) for the tail, but the brushless tail seem to draw too much current away from the battery for the main and produce a slight bog. With just the brushless main and stock nano tail (stock length by the way), it's much more zippy. I can even fly with the stock battery for 2m30s (mild 3d), and with the 200mah 35C (generic) lipo, I get about 3m30s flight time (doing constant flips, pitch pumps, fast tic tocs, etc.). With a 300mah 35C (generic) lipo, I get an amazing 5m of flight time (doing the same constant flips, pitch pumps, fast tic tocs, etc.) Even with the 200mah lipo, it's got equivalent power as my DBL mCPx (with HP08 main and HP03t tail, running on hyperion 500mah lipos).
I have BLHeli on the Xp3a esc, setup in arm gov mode (governed to 85%), and a v-curve in idle1.
Anyone have similar experiences in the comparison? Or have seen actual benefits of going brushless tail on the nano?
soonglim is offline        Reply With Quote
Old 03-11-2013, 07:00 AM   #246
daveapplemotors
Default BLT brush less tail
I like BLT in the wind.
In still air there is not too much difference although the brushless tail is a bit more precise.
But when the wind blows the HP02 tail motor shines. I saw constant rate pirouettes in a 20MPH wind with BLT. My other wild brushless nano with brushed tail did its first TBO and went down in flames in that wind. Just kidding. Lipos are safe. It flew again 10 seconds later.
And I don't notice too much current draw. I get 4 minutes good power with 240mah Hyperions.
Dylan, Brushless tail is amazing. You are the man!
Old 03-25-2013, 03:55 AM   #247
soonglim
Default DBL nano with HP08 main and HP03T tail !!!
It's inevitable - a Double-Brushless Nano CPx with HP08 main and HP03T tail !!!
Idea started with asking why can't I put an HP05 in the nano and see how much better it would be than the HP03SE. (Turns out HP05 is only slightly better, but the HP08 is several times better).
There was no available frame to make this happen, so I made my own mod from the stock nano frame. I had done a similar thing with my previous mCPx mods. Basically, I created a flat motor mount out of aluminum sheet (about 0.7mm thick), and a vertical support for the 3-in-1 board to attach, which also braces the frame. It's hard to describe or too lengthy in words, but the attached photos says it all. My modified frame fits the HP08 main motor with about 1mm or more clearance on all sides.
To drive the HP08 main, I use an XP3A double-FETed with the good FETs (see http://www.helifreak.com/showpost.ph...5&postcount=45 ). These FETs are amazing... double-fetted XP3A with these is better than the XP12A. The only problem is the XP3A I had didn't have a power-filter cap on it, so I had to solder on one taken from one of my broken XP12A. This filter cap is needed because the HP08 motor can draw a lot of current and cause a voltage drop to cause the 3-in-1 board to think it hit LVC prematurely. I programmed the XP3A with BLHeli, and set to arm gov mode - 85% throttle (90% is even more powerful, but way too fast for me), and a deep V-curve in idle 1. Pit travel is set to 85% (but can be 100% and no bog - but also way too fast for me). Pinion is 9-tooth.
To drive the HP03T tail, I use an un-modified XP3A but flashed with BLHeli tail setup. The tail boom is elongated by 10mm to 118mm, just so I have good clearance to avoid the main blade striking the RRC props. It actually flys pretty solid with stock length boom, but I have to cut the RRC props to a good length (~52mm total length), but flight time seem to decrease about 1min. With the slightly extended boom with the full length RRC prop, flight time was 4min to 4min 30sec (on hyperion 500mah 25c lipos) doing constant pitch pumps, fast tic tocs, rolls, flips, etc.
The power of this HP08/HP03T DBL nano is just amazing! I think this can be even better if someone (Rakon Heli, or MicroHeli, or better yet, Astroid Designs - if you see this) provide a mod kit with a CNC carbon fiber motor mount plate like in my mod and attach it to a Delrin vertical brace for the 3-in-1 board to attach to. Since I had to cut and drill the holes by hand, it's not very accurate, and while gear mesh is ok, it can be much better. When I rotate the blades by hand, there is some tightness because of the gear mesh. (Compared to the MicroHeli frame I have for my mCPx with the same HP08 motor, it just keep spinning).
Even with such power, the durability is amazing. After many crashes in the field, the only thing that broke was stripped gears - probably because I had made a metal main shaft for the mod. The metal main shaft was made from some old toy heli shaft by the way, and I used a collar from the Walkera v120d02 main shaft. To remedy the stripped gear issue, double up two gears that were already stripped (one of the photos attached shows this). Note the metal main shaft added about 2 grams to the total weight, but with the power of the HP08, it's neglible. So durable, after a crash, just pick it up and fly again.
Again, Astroid Designs, MicroHeli, and RakonHeli if you see this, it would be great if you could provide such a frame or frame mod for the nano. And a metal main shaft.
Update: Just added a YouTube video of a test-flight
ID:	406331   Click image for larger version
ID:	406332   Click image for larger version
ID:	406333   Click image for larger version
ID:	406334   Click image for larger version
ID:	406336   Click image for larger version
ID:	406337   Click image for larger version
ID:	406338   Click image for larger version
ID:	406339   Click image for larger version
ID:	406341   Click image for larger version
ID:	406342   Click image for larger version
ID:	406343   Click image for larger version
ID:	406344   Click image for larger version
ID:	406346   Click image for larger version
ID:	406348   Click image for larger version
ID:	406349   Click image for larger version
ID:	406350   Click image for larger version
ID:	406353   Click image for larger version
ID:	406354   Click image for larger version
Old 03-29-2013, 05:08 AM   #248
donaldsneffe
Hi,
wow - very cool stuff.
I also would appreciate a frame mod like yours available by Astroid or...
I am struggeling hard with my custom frame mods, too.
You are sure? 2 mm?
It looks similar to the collar from the Walkera 4b120 (I used).
Walter
donaldsneffe is offline        Reply With Quote
Old 03-29-2013, 09:54 AM   #249
soonglim
Originally Posted by donaldsneffe View Post
Hi,
You are sure? 2 mm?
The collar I used were from a set with the tail shaft collar for the Walkera v120d02 (same as their 4G6, and probably same as your 4b120). The tail collar was what I needed only from the set for my v120d02S since the v120d02S had 2.5mm main shaft, so it didn't fit there. But luckily I could use the main collar for my nano now.
Old 04-03-2013, 01:56 PM   #250
JEBSi
soonglim, Microheli makes a metal main shaft and Lynx makes a heavy duty compressed carbon main shaft with a metal collar. Rakonheli also has a metal frame compatable with the BL motor with all the features that you want. I have one and like it. You can set the gear mesh perfectly and use different size landing gear. I like your landing gear a lot and the vertical brace is a nice idea, but that has to be the heaviest Nano on record.
Get high on a Chopper! Do it inverted!
JEBSi is offline        Reply With Quote
Old 04-04-2013, 12:47 AM   #251
soonglim
That's right, it's one heavy nano, but still 10 to 15grams lighter than an equivalent DBL mCPx and in a much smaller form-factor. However, the weight is mostly from the motor and battery - it's like a flying motor and battery .
Yes, I saw the Microheli shaft later on WowHobbies and it looks to be about 1g lighter than my home made one. But I made mine slightly longer so I can double up on the main gear. I also prefer the metal main shaft over the carbon fiber. The metal one is more crash resistant. The cf one feels rubbery on rotating it after a crash or two - hence the metal one gives better transfer of torque on those sudden throttle pumps.
I also saw the RakonHeli frame, but it's only made for ring mounted motors. Needs a flat mount for the HP08 motor. In fact, Microheli could easily modify their Advance X frame for their mCPx for the nano just by extending the length to accommodate the larger nano gear, shortening the height for the shorter main shaft, replacing the main bearings with 2x5mm bearings, and using a "T" shaped 3-in-1 main board mount, then it would be the best frame for the nano to do the same brushless mods as the mCPx. I'm loving the small nano format. I can still fly it inside the house even with the HP08 souped up mod (at a lowered governed throttle - 75%). In more capable hands, one can probably still do 3-D in their living room with it.
Old 04-10-2013, 10:08 AM   #252
JEBSi
Definitely a piece of work. I didn't notice how big the motor is. That thing has got some incredible pop on the pitch pumps. Very cool stuff!
Old 04-24-2013, 03:03 PM   #253
JEBSi
I was looking at the rakon frame and it does have holes for adjusting the motor mesh which I think might be able to accept a flat mount motor. Get rid of this piece:
http://www.rakonheli.com/rkh/index.p...emart&Itemid=1
Then screw the flat mount motor to the frame or screw the new motor to the ring mount and get a longer motor shaft and screws?
We all need CNC machines!
