| nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help |
#61 | |
Dylan ~ www.AstroidDesigns.com |
#62 |
My hat is off to guys like you who have pioneered the field for us....... I wasn't having much fun with mine in stock form and tried a second motor to get the same results..... BL was my only option ;-) I was to impatient to wait for the kit so I gave it a shot.......
#63 | |
#64 |
#65 | |
![]() I dont use a longer shaft on the stock hp03s. I just took about 1mm or so from the bell. It still is quite tuff and I have crashed it a lot and it hasnt shown any signs of coming loose or bending. |
#66 |
Ok went through my first motor yesterday time to go Bl, got a question as i have been out of the loop on bl setups !
I wanna do the hpo3s 13500kv with a xp-3a esc,7 tooth looking for mild, do i have to flash esc to get to work, do i need a convertor like my mcpx has. Or u guys flash these esc's to get GOV to work ? hope i dont sound to dumb lol Tanks Tom
Dx7,T-550Ev2,T-450 pro Dfc, 130 X, mcpX BL Brushless Nano RUSH 750 being built To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#67 |
If you flash the xp3a you dont need a converter. Dylan will flash one for you for 5 bucks... I think. Or you can order the usb flash stick from him and flash the esc yourself
#68 |
Cool, thanks indorheli now i get it dah !
Was planning getting my motor from him so i guess ill get it all one shot. How does govern come into play or is everyone just using a flat TC and calling it govern @ what ever their target rpm they want thanks again
#69 | |
#70 |
@thanasi
Listen to sskaug. He wrote the BLHeli firmware that's being used everywhere. Companies like Oversky are creating ESC with his code already flashed in them. The HW convertor that you used for the mCPX brushless conversion works fine...but it's kindda old style in light of the BLHeli firmware. With BLHeli, you get rid of the ESC and it's associated wiring. So lighten the setup. Then you can use the software BLHeli Setup GUI program to set up various parameters to dial your brushless set up in. Including set the governor mode. Kindda like the Big helis. Screenshot of BLHeli Setup 8.0 ![]() |
#71 |
Daryoon cool info i got lots to read, I did do some reading last night on blheli
wow way over my head. Love it , im going to try and wait for dylans kit ha ha thanks for the read
#72 | |
I think, sooner or later, I will join the nano club
Unfortunately, I get very little feedback in general. May be that this is a good sign ... But it is not easy to make advancements and improvements.
For the most recent Revision of BlHeli Setup see my blog. |
#73 |
@thanasi
It's way over many of our heads. However, it's easy to simply use it. LOL The programming toolsticks are cheap now. You can buy the ESC already flashed and the toolstick, all from one place. Dylan from Astroid-Designs has all the parts needed. |
#74 | |
If I want to update a flashed ESC to 8 it works fine, if I want to flash a new ESC I get a write protected error and have to go into expert mode and erase chip first, than it will take a flash no problem. Tried to attach Log file but Helifreak wont let me Dylan |
#75 |
For log files, since they are all text. Simply use Pastebin. Then put the link here. That's my suggestion.
#76 |
Log file was .tlg but you can save it as txt.
#77 |
I need a little help. I'm using a XP-3A BLHeli 8.0 and a HP03S 16600 8T pinion. Let the questioning begin!
![]() 1: How many poles does the motor have? I took an educated guess and counted 9 poles. 2: When I spool up at zero pitch it reaches full speed then bogs heavily with any pitch. I've tried 95% and 100% governed throttle both get the same bogging. What could be the issue? ::edit:: low battery ![]() 3: When I soldered the motor to the esc, it spins backwards so I just reversed the motor direction in BlHeliSetup. is that going to affect the performance? Thanks for your time. you guys are awesome!
Good Luck To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by KlaimXI; 10-17-2012 at 09:46 PM.. |
#78 | |
16600kv likes a 7 tooth (6 tooth would be good too if it was available), hyperion 180 or 240's and 24 gauge wire from the esc to battery. Even the best 150-160 mah UM cell has a hard time with the 16600kv with a 7 tooth. 95-100% throttle is not governed, try 75% flat and work your way up until the tail holds good during pitch pumps. Start with p and I gains at 2.00. Doesnt matter if you have the motor reversed in software, whatever it takes to make it spin the right way. 8 tooth, weak batteries and small wires are most likely your issues. Dylan
#79 | ||
Thanks Dylan,
The reason might be the Lockbyte, which is different set for different BESC's in factory state. Could You please a "Read Memory" at the expert page at Start:0x1DFF and Length:1 before You erase the chip? Quote:
EDIT: I released a new revision 8.0.0.2. I changed the handling of partially locked BESC with reading the lockbyte first. Please check out...
For the most recent Revision of BlHeli Setup see my blog. Last edited by 4712; 10-18-2012 at 10:38 AM.. |
#80 | |
I use a homemade special format (saves the whole treeview with all attributes) and picked the *.tlg extension.
