| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
#61 |
Hey,
Am I mistaken or did you recently loose all your helis due to CC ESCs burn down? Soko
ONE TOOL for ALL SIZES and ALL BRANDS "Unique features" | "Awesome setup tool" | "its simply awesome" www.soko-heli-tools.com |
#62 | |
I not only lost the helis. But both complete sets of my Mks servos, and it took out one of my SK720s. I wasn't a happy camper. Plus, and this is even worse. I custom built a heli for a close friend who lives over in Bankok. I had the heli in its third maiden hover just tuning in the Sk720 SL and poof! The CC Ice50 burst into flames. It came down in a fireball. So, I had to rebuild it and send a completely new heli out to him out of my own pocket. Fun stuff! I was already building it for free as it was. Not to whine here. I came real close to bagging the hobby for a while. |
#63 | |
Guessing they won't be getting any second chances with you then ??
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep |
#64 | |
I also went through three HV40s on another project until they finally got one to me that phased properly at the speed I needed. Those also caused two prototype motor losses as they burned up on the bench! Still well under their advertised phasing specs. That one (HV40) I need for my 12s 450 work with a prototype scorp they built for me. But if any other Esc manufacturer could come up with an esc that phased on a 12 stator motor at 49000 rpm I would jump all over it. As it was, I found a flaw not only in Castle's processor but also in their software! As I was able to use one of their cheaper Phoenix HV30s and run the same motor wide open without any problems. Before this Clint at Castle had quit returning emails. Also some of his advice was pretty poor and caused a 70 amp spike that roasted another motor. He blamed the results on me until I proved it was the esc's phasing limitations that caused the stutter and spike. Not to mention his advice to turn off the esc's safety net. They switched reps on me three times during the process. When I showed them the hole in their newest software release. I got a quiet thank you. And a new esc that worked. I had dozens of logs showing those motors hitting a wall at half their rpm ratings. And the Castle controller stuttering and spiking the motor with 15 times the running current. Yeah, my fault you say? And then earlier when their reps made two references to me that this was all my fault, and no one else was having these problems when I had helis dropping from the sky engulfed in flames? That suddenly quieted once I posted up about them, and dozens hopped on with the same issues. Funny how that happened. 6 weeks later they started dropping that line and supplanting another newer style esc instead. Again, coincidence? Me thinks not! Imagine what Scorpion Motorworks thought of me also having to reorder the second burnt up motor as a consequence of this? It almost cost me my sponsorship. Thanks Castle! Again, funny how that motor ran perfectly with another controller. So yes, (done with my OT rant now) I am stuck with at least one for the time being. All the other replacements I sold off. And I would kill to be in the active working community again and be able to afford much higher quality esc's. Those days when I made 70+k a year are long gone. But, at least I will be still building helis. And with Soko's help. And his brilliant kit, they will come out even more precisely setup. |
#65 |
added this to my kit for my Mini Protos which is a total pain in the ass to set the head up on.
Brilliant
Synergy E5-S KDE 600XF MKS HV YGE Vbar : Compass 6HV Quantum 4125 MKS HV YGE Vbar SAB G500 Savox 4050 KST/MKS HV YGE HC3SX Compass Warp Scorpion 2520 MKS YGE SK540 : 130X MCPX BL Nano 14SG DX8 |
#66 |
Soko, what a well thought out kit! Simple and elegant. Anyone can use this and get tracking dead on! And by dead on, I do mean dead on if your mechanical setup work is right and things aren't sloppy.
Not only is the stepped disc a novel idea as it addresses most the known grips. But even with the oddballs I found I can simply use normal blade grip spacers to get a perfect fit. And your Soko electronic measuring tool is about as well thought out as anything I think I will ever see! You even got the cute storage bag down perfect! Well done! I am using this to set up a current 250 (with Vbar) I am finishing up for a guy, then I am reworking my Sk720'd Warp360 since I decided to add turnbuckles on their fbl links to get the tracking dead on. Their stock versions kinda suck as you can only get tracking within a half end link turn. This tool allows a guy to dial it in without any tracking error down to 1/10th of a degree. Then it is on to a Goblin I have built for another guy when Sk finally gets the black out. Sadly if they wait too much longer the guy I am building for might just tag something else on it. But the Soko kit is a perfect fit for that system also! Doesn't get any better than this! I think I love this thing! And it isn't the giant Pia to use as my RcLogger as you can do this blades off! Which makes bench work so much better when not having to mount and fight the big blades swinging around while setting up the head on larger helis. LMH |
#67 |
Is everyone enjoying the soko? I am looking at going with the rclogger and just came across this. A little more expensive but looks well thought out.
#68 |
If you want it perfect you need the Soko tool
#69 |
Lovin it, very easy to use. I've setup my 3 helis and a few for my friends, I don't regret the purchase even though I have an older rc logger.
Compass 7HV SK720 Compass 6HV SK720 Compass 500 SK720 Blade MCPx V2 |
#70 |
Hey guys!
Just want to let you know about our Youtube channel here. We uploaded our first instructions videos so check it out If you like them why don't like us on our facebook page as well Here is the first part of the video embedded! Have fun! Soko
#71 | |
Ching-Ho Cheng Hirobo Quark - Aluminium rotor head and swashplate upgrade T-Rex 450 Pro, zyx-s, T-Rex 250 SE, BeastX, DFC head, Warp 360, Scorpion 1360KV |
#72 |
Hey guys,
Just want to let you know about the completion of the setup videos with the Soko Kit Keep on flyin' Soko
#73 |
Hey guys!
Just wanted to let you know about our new Soko Kit instructions v2.2. Besides a lot of other features it now includes a step by step guide to measure your tail pitch - of course for all sizes and brands of helis. We also added some new pages on our website so go and check it out. Soko
#74 |
Was there no mention of leveling the swash at high and low stick after leveling at zero pitch?
Raz |
#75 |
Hey,
Have a look at section 4.4. "Setup of swash plate at full pitch". This section exists since day one... Soko
#76 |
I see, thanks. Nice product.
Question, I currently own MiniV, 3GX and Skookum FBL units. I don't recall the instructions suggesting the sensors be reset while the helicopter is perfectly leveled. Is there such an option and/or a need? I'm assuming the primary purpose for absolute vertical alignment of the main shaft is for your tool to do it's job, correct? Raz |
#77 |
Hey Raz,
I know there're quite a lot pages - but thats a big point everyone likes about it. Its even for the newbie no problem to setup his/her heli with the Soko Kit. About reset of sensor see bold sentence "If your gyro/FBL system has a self-level feature, it’s a good idea to recalibrate the sensors." on page 18 and 21 The Soko Kit itself doesn't need the absolute vertical alignment... its more or less a need of the correct procedure to setup your heli. You can use the Soko Kit like any other pitch gauge as well! Soko
