Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 10-05-2012, 02:04 PM   #1
bossee
Default 18 MZ software version 2.2.0 released
Hi,
New 18 MZ software version 2.2.0 released today October 5:
http://www.futabarc.com/software-updates.html
- Home 2 screen telemetry display function redefined
The Home 2 screen telemetry display function has been refined to display more information. In addition to the current measured value, the display also indicates the minimum and maximum values.
- Audible telemetry information
In addition to the on-screen telemetry data information, the T18MZ now has the ability to audibly indicate the aircraft status.
- Variometer melody function
When using a variometer, the T18MZ offers the option of incorporating a tonal indication of the aircraft's rate of ascent or descent.
- GPS display function
This function allows some GPS units to be compatible with Futaba's GPS unit (SBS-01G).
- Telemetry display units setting
The telemetry display units can now be set to metric system or Imperial system.
- Timer function with vibration alerts
This update to the T18MZ incorporates vibration alerts that notify the modeler when the programmed time limits have been reached. This function also allows the timers to be controlled via the home screen.
- Touch panel lock function
To prevent any unwanted or undesired transmitter input, this update incorporates touch panel locking functions.
The Start Up Lock function, if active, will automatically lock when the power is turned on.
The Automatic Lock function will lock the transmitter when the backlight timing has elapsed.
- S.BUS servo setting screen
It is now possible to check servo operation at the S.BUS servo setting screen.
- Data reset screen
This update allows the user to separately reset the information for user menus and telemetry data, if desired. For example, it is now possible to reset the telemetry information without impacting the other model programming.
- Camera function shutter switch
This update allows the user to assign a switch/position to control the camera function of the T18MZ.
- Maximum engine revolution display by each condition
It is now possible to display maximum engine revolutions by each condition.
Explanation when using two or more the same kind of sensors.
bossee is offline        Reply With Quote
