Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 10-07-2012, 04:22 PM   #1
KouDy
Default Clutch liner
How to recognize that it's time to change clutch liner (PV0532-1)?
When i have heli idling on the ground it makes some metal-like noise. Hard to describe but it's very loud and definitely shouldn't be there. As i go into flight it just gets even worse but since heli is moving it doesn't feel it's loud (but in fact is louder than during idle). It's some metal like sound, clinging or rubbing.
I checked and clutch liner in the bell is all polished into mirror. I don't think it should be like that...
Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
Old 10-09-2012, 03:34 PM   #2
johnbs8
engine bearing?
Titan X50B : YS56sr GP Pipe, Tracx600 FBL, AR7200BX, Ds610 X4, DS650, Pushglo and compass 615mm FBL
Titan X50T : Ys56sr SAB-55 Pipe, Tracx600 FBL, AR7200BX, DS8717 X3, BLS251, Pushglo Radix V2 625mm FBL
johnbs8 is offline        Reply With Quote
Old 10-09-2012, 05:29 PM   #3
KouDy
I am not sure what are you asking. Yes i think it might be any bearing in the engine or starter shaft. While i ordered starter shaft bearings for spare, getting engine bearings is going to be harder. Also... putting engine apart is... Weeell maybe over winter
Old 10-09-2012, 08:21 PM   #4
rcflier1
when the liner goes, it sounds like a bell ringing. i threw 1 in the air, you learn the sound quick. and the power is falling to the blades, yet the engine rpm's are there
rcflier1 is offline        Reply With Quote
