Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 10-07-2012, 09:22 PM   #1
Adam F
Default x50 flybarless head has play
I have about 15 flights on the raptor x50 (with the TT flybarless head ) . I notice that the head has some play , its up and down and when you hold the blade grips and move them out and in I get some play . The play is very slight and has not caused a problem but was just wondering if anyone has experience this . Do i fly it so ? If I have to fix it, how do I ? I love flying this heli so much ,really hope its not a big problem .Thanks in advance .
Adam F is offline        Reply With Quote
Old 10-07-2012, 09:40 PM   #2
Bob O
The X50B I had this spring/summer developed some slop over the course of a few months. I used the factory FBL conversion head. This slop basically amounted to some wiggle of the blade grips. It wasn't a lot and didn't seem to affect flight, in fact the X50 was one of the best flying helis I've had.
As far as fixing it, I wonder if the head could be shimmed. If you can find a shim of the proper size, you might be able to place it between the head damper and spindle spacer. Just a thought.
Here are a couple of shims that might work for you.
http://www.nankinhobby.com/product-p/82-821003.htm
http://www.nankinhobby.com/product-p/82-841201.htm
Let us know what you end up doing. Hope this helps.
SPARTANRC - Forum Support
Warp360
Bob O is online now        Reply With Quote
Old 10-08-2012, 06:52 AM   #3
Adam F
Thanks for the quick reply , I will look in to the shim but kind of hesitant to interfere with it because it fly real good . I let you know what I decide .
Old 10-08-2012, 11:39 AM   #4
Elgyn
My flybar'd head was sloppy from day one.
TT titan x50 / TT mini titan / JR Vigor CV... ...vbar'd / 700 airwolf streched JR Voyager mechanics / JR Venture CP
Elgyn is offline        Reply With Quote
Old 10-08-2012, 01:45 PM   #5
KouDy
You can maybe use method i used in my guide for building : http://www.helifreak.com/showpost.ph...7&postcount=13
It's about in the middle of post #13 when i ask you to check for the play.
I have flybarred machine but there is no mechanical difference in FB FBL in this.
Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
Old 10-08-2012, 06:46 PM   #6
Adam F
Thanks Koudy , I will take a look at your post . thanks for the help. .
I just love this heli
Old 10-09-2012, 12:52 PM   #7
Langelus
I assume it's the same FBL as I have on my X50E? If that's the case it seems all X50's have a little slop in the bladegrips (too little preload on the thrustbearings)
I read in some other forum that Nick Maxwell had commented about it and said its fine but you can put additional shims to make it tight.
Langelus is online now        Reply With Quote
Old 11-07-2012, 12:36 AM   #8
esmoglo
+1 on this "My flybar'd head was sloppy from day one"
Angelo
esmoglo is offline        Reply With Quote
Old 06-10-2013, 02:32 PM   #9
Turttle
Some play is expected but this much is out of controll.Cant run light blades half to run heavy china made blades to compensate.My other helis dont have close to this much after many flights and this head only has about 10 on it my maverick fly bar head had zero slop before upgrading to fbl?
Think I will dissasemble the mavrick and see whats interchangable
Northern California RC Unlimited RC Flyers.
www.ashcreekrcflyers.com
Turttle is offline        Reply With Quote
Old 06-14-2013, 10:36 PM   #10
legacy115833
building my kit tonight and the head is sold as a rock and silky smooth. about as perfect as it gets.
Go BIG or go home
Happy landings
legacy115833 is offline        Reply With Quote
Old 06-18-2013, 03:09 PM   #11
Turttle
I got around to dismantling the head to see what was going on and really dont see anything as far as its put togeather correctly.The head and dampers are fine and there is no slop or play in and out so dont need to be shimmed.The grip bearings are glued in tight so the only thing it can be is sloppy blade grip bearings.Its so bad on mine that when I threw on some edge blades tracking is all over not getting a clean and tight swirl where you can see the blades give that opposite direction look it got the blurry look like there bouncing around.Im sure its causing havok on my allready way to sensative poopy 3gx.
