Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 11-14-2012, 08:37 PM   #41
corrosionate
Ok, so HobbyPartz was unable to help me out with getting the 1400mah Gens Ace packs. I guess I don't know what to do now. I guess I'll go with the 1200mah packs. Maybe I'd take a chance on trying the Chrome 1300 packs, but they are out of stock on the higher C packs. I also thought maybe I'd get double the quantity of the Gens Ace 1350 3s packs and use a series adapter or solder them together in 6s configuration, but two of the last 3 of this pack I ordered came with a puffed cell right out of the box. IDK, maybe I'll wait a bit and see if anything else pans out.
Align: 250, 450 Pro v2, 550 v1, Chaos: 600
MSH: Mini Protos 6s stretch, Protos 500 plastic
Compass: Warp 360
B:130x, 300x, 450 FBL
corrosionate is online now        Reply With Quote
Old 11-14-2012, 08:45 PM   #42
Rob43
I have no concerns using the 35C Chrome packs. Since Chrome seem to be a high grade value choice, I am confident they will deliver. That is what many of our beta testers are using with no issues at all. The Chrome battery build quality is quite good too.
= R
b43 =
Team Compass Support
Rob43 is online now        Reply With Quote
Old 11-14-2012, 09:34 PM   #43
corrosionate
Sounds good enough for me to give them a try. I guess I'm just shy when it comes to trying new brands of lipo because I've wasted hundreds of dollars on lipos that only lasted me 10 cycles or less. So when I find a brand that works, I tend to stick with it. If these are working well for the testers, it should be good enough for me.
I just ordered one Chrome 35C 1300mah, and one Gens Ace 1200mah 40C pack. At least now I know I should have two packs to use when i finish the build. I'd like to pick up a couple more packs, but maybe I'll see if I can get any black friday deals on additional packs, or wait to see which one I like better. Maybe I'll try a Thor pack as well.
Thanx!
Compass: Warp 360
Old 11-15-2012, 05:41 AM   #44
Luigi_tuga
I've been using turnigy's with good sucess except with one kind of pack: the nanotecs 25c in traditional 3s form.
I have 2 35C, 4 25C, and two nanos 45C.
The nanos have maybe 2,5 months, the others have 5 months of VERY regular use. They could be in better shape if i didn't used the CC gov for about a month, now with the yep gov it's nice.
Will buy maybe 2 more for the higher rpm flights on the warp.
Warp 360 , Tarot 480
T500Fbl AP
MCPX bl PZ StrykerQ DX8
Luigi_tuga is offline        Reply With Quote
Old 11-15-2012, 08:46 AM   #45
corrosionate
I tried turnigy nano tech 6s packs for my protos and my trex 550, i think theyre all 30 or 35c and they all puff like crazy, so i quit using them. The ones on the protos would come down scolding hot. I switched to gens ace and they come down cool with no puffing. I see a lot of folks having good luck with them, but somehing about them didnt work for me.
Sent from my iPhone using Tapatalk. Please excuse spelling and/or grammar issues. My thumbs are huge from all this RC flying.
Compass: Warp 360
Old 11-15-2012, 11:13 AM   #46
Luigi_tuga
No problem on the 45 C's, with a 6s setup current is way low...
The two 25C have 2/3 cells that gone wild, they discharge evenly till 3.8 thean after that they fall like crazy.
When charging wo balancing, they reach 4.35...
Not using them any more.
T500Fbl AP
Old 11-15-2012, 11:23 AM   #47
Gawl
I won't use another turnigy battery after my experience with their 3s packs. I take very good care of my lipos and these started puffing right after the 3rd cycle.
I'll stick to GA and Chromes, never had any issues with these brands.
Team Synergy
VP Racing Fuels
Team Scorpion
Gawl is offline        Reply With Quote
Old 11-15-2012, 05:39 PM   #48
DVUSHELI
Default Quick question...
New to the whole idea of 6S 450's. I take it due to having more cells, 1200-1400 is going to be able to still give a 4 minute flight time? My 2650 3S 450 gets about 4:50.
Can someone briefly explain please? Thanks.
Trex250 Super Combo/ EXI 250 Super combo with Align F3C fuse/ HK450V2 FBL w/ BEAST X/ EXI 500 FBL w/ BEASTX/ COMPASS 7HV w/ AR7200BX/ MKS HV Servos/ YEP120HV/ Turnigy SK3 Helidrive
KBDD on everything
DVUSHELI is offline        Reply With Quote
Old 11-15-2012, 05:51 PM   #49
DVUSHELI
Nevermind. Did some quick research and found out why. Lower kv motor, more flight time, better performance due to higher efficiency. COOL!!!
KBDD on everything
Old 11-15-2012, 05:57 PM   #50
Luigi_tuga
Flying with gov on this birds with large blades will give you lots of flight time.
This flight on my 450 stretch wit align 450 mx took 11.5 min.
I just couldn't believe on my tx timer!!
T500Fbl AP
Old 11-15-2012, 06:05 PM   #51
DVUSHELI
HOLY CRAP!!!! Dammit, I said my 7HV would be my last heli unless I smash my 450 to pieces, which I did, and I would get this, but not so damn soon My poor credit card.
KBDD on everything
Old 11-23-2012, 05:49 PM   #52
ahunter852
Hey guys for lower headspeeds and longer flight times on the warp 360 what would you recommend GA 1200, or GA 1400? (I'd like to stick with GA because there easily accessible for me). Would GA 1400 be to heavy?
Thanks any info would be greatly appreciated.
Alex
ahunter852 is online now        Reply With Quote
Old 11-23-2012, 07:43 PM   #53
kalleh
The manual has the recommended pack weight range listed. The Thor 1350mAh 35C's I ordered are in the lower part of that range.
130X stock | T-Rex 450PRO v2, AR7200BX | T-Rex 500PRO DFC, HC3-SX | Warp 360, HC3-SX | AMA member
kalleh is offline        Reply With Quote
Old 11-24-2012, 01:20 AM   #54
ahunter852
Originally Posted by joseca View Post
chec photo
weight 250g and 254g
dimension 105x32x34
Germany
http://www.gensace.com/epages/genspo...-40C-1400-6S1P
Uploaded with ImageShack.us
These better fit! just ordered 6 of them!
Old 11-24-2012, 09:11 AM   #55
r1sportbike
For CG purposes, I would stick with a more square pack like the Chrome 6s packs. It will be hard to get correct cg with a long pack and still be able to mount the canopy.
_____________________________________________
Team Compass
Experiencce R/C
Thunderpower Batteries
r1sportbike is offline        Reply With Quote
Old 11-26-2012, 03:22 PM   #56
ScotY
That's what I was wondering about. Seems most pics I've seen have the short, stubby packs mounted far forward. But those are on the lighter side so wondering if a slightly larger/heavier long thin style battery will balance. I'd prefer a little more capacity if possible.
ScotY is offline        Reply With Quote
Old 11-27-2012, 05:25 PM   #57
Luvmyhelis
Worst case scenario, just add a small counterbalance weight on the boom.
I have done this on more than one of my stretched versions. I prefer larger packs myself, and have already measured and weighed all my current 6s packs. I have them from numerous 1300s, 2250s, 2650s, and up. I have even run dual 1300 6s packs on my larger 420mm stretched 450s with inside canopy fitment. I see no real reason why a larger pack wont work here.
Luvmyhelis is offline        Reply With Quote
Old 11-27-2012, 11:36 PM   #58
ahunter852
actully the my LHS couldnt order the GA 1400 unless he orders a minimum of 30 peices, and hes not really willing to do so.
just wandering if any knows of any online shops that stock these. is it banned to send lipos internationally? ( i keep seeing this stuff somehwere)
Old 11-27-2012, 11:46 PM   #59
itsmillertime0
We should try to get a group buy together for the Gen Ace packs. I'll take 6.
Team Newb
Walkera Mini cp - hp06v2, hp02t, custom fet esc's, 550's
Blade 130X - hp08s, lots of bling; Blade 130X - ta955, xp12a
Compass Warp 360 - CC ice lite 50, MKS DS92A+, iKon
itsmillertime0 is offline        Reply With Quote
Old 11-27-2012, 11:49 PM   #60
ahunter852
That's what I'm trying to do here, but I have no idea about shipping lipos from Asia to America or overseas
