Old 10-12-2012, 07:04 PM   #1
nof55
Default cp11 and zyx s FBL
I know I've read it in some thead on here but can't seem to find it. Can someone tell me how the wires go with cp11 on zyx FBL setup or point me to the correct thread. thx
blade 400 , Blade450 +co-pilot2, 450 fusion, CX3, MCX2, Blade 400 zyx fbl cp2, Arducopter hexa , Dx6i ,Dx8
nof55 is offline        Reply With Quote
Old 10-13-2012, 11:13 AM   #2
nightflyr
The basic setup goes as follows...
Rx>>>>>>CPII>>>>>FBL>>>>>Servos.
Most non-stabilized FBL controller will wire up this way
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000
Assorted
Mix Fixed Wing.
AMA # 972083
Old 10-17-2012, 06:52 AM   #3
ece31316
@Nightflyr, Just some clarification, i'm also planning to install my cpII with the ZYX fbl, bt as i read the ZYX manual, it requires the transmitter to setup in non-mixing mode, will the output from cp2 suits the ZYX well?
ece31316 is offline        Reply With Quote
Old 10-17-2012, 07:42 AM   #4
nightflyr
Not a problem S1 or H1 setup for FBL is SOP.
The FBL controller does the mixing.
Assorted
Mix Fixed Wing.
AMA # 972083
Old 10-17-2012, 07:26 PM   #5
nof55
OK night, S1 is one servo rite, racking my brain what H1 is?
Old 10-17-2012, 09:21 PM   #6
ece31316
Now I know.. THanks nyt!
Old 12-01-2012, 11:28 PM   #7
nof55
sorry about resurrecting old thread but I finally have time to get at this again, and still need help.So I have my on/off for my cp11 on my gain channel(dx6i),but black wire from zyx is suppose to plug in there, Is there a way to make this work or do I have to forget about having on/off?
Old 12-02-2012, 04:03 AM   #8
sutty
Since you need all the channels from your DX6i to control the heli, without a 7th channel to switch it, your installation is not optimal. This having been said, there is a way to set it up such that it will work, even if it isn't optimal.
Instead of sending your tail gain from the Tx you send it from the CPII itself. There is a section of the CPII manual dedicated to how this is performed. The section title is called "If helicopter channels are limited". Using this method you set your gain value during the CPII set-up which is then output directly to your FBL controller on the 4th channel, SV04.
The channel that would normally have sent gain to your FBL controller, via the Rx, is now freed up to enable switching of the CPII unit.
Of course if you do output the gain from the CPII, the only way to adjust it is during CPII set-up, so you cannot have it linked to flight modes, or adjust it from the Tx in any way. That having been said I don't think you can link gain to flight modes with the DX6i anyway, and very often, once you get your gain set right, it will stay that way for good. I haven't changed my gain on any of my helis all year, so in reality, whilst I described it as not optimal, it would be no real drawback to me.
Cheers
Sutty
Regards, Sutty
FBL Trex550e VX1, FBL Trex600ESP µB, Parkzone P51D
sutty is offline        Reply With Quote
Old 12-02-2012, 09:25 AM   #9
jdd1
Hi Guys,
You can adjust the gyro gain in the preferences menu if you choose to use SV04 on CPII to control the gyro gain. It is not necessary to go through Quick Setup again.
Jack
Jack Doherty
FMA Beta Tester
CoPilot II HD
PowerLab 8
jdd1 is offline        Reply With Quote
Old 12-02-2012, 11:05 AM   #10
nof55
thanks I should have reread cp11 manual. Sometimes I make it out to be more complicated than it is. Anyways thanks for the help.
