| Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics |
I have a gt5 I never setup at all. Is it easy to? Is it reliable?
Not as easy as an AR7200BX !
I guess its a case of the more you fiddle with it, the easier it becomes. I ditched my GT5.1 in favor of an AR7200BX unit and was flying within 30 mins ! This by no means says the GT5 is rubbish .. its just not as easy to setup as other units. I also found the finger slide, double tap, on the side not sensitive enough for me ! Reliable ? ..... imo, yes, a wee bit better than certain other units ! Nigel
Nigel. SR, 300X, TRex 500E Pro with DFC, ..... and a few Planks and Tanks ! |
Should I make use of it? I have a 700 I'm going to put a beast x on since I already have one, and my 600e doesn't have a unit yet but I do have the GT5.
Yes of course..... never waste anything !
Nigel
GT5 is an awesome flybarless system. Not easy setup and take more time to tunning, you should read manual carefully (manual for GT5.1) step by step.
Goodluck |
#6 |
#7 |
Anyone using this on a Nitro? Seems like Thunder Tiger should be especially good at engineering a FBL unit for nitros.....
Gaui X5 FBL w Beast! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. yesssssss! "The Big T" TRex600N OS 50 hyper Velocity N1 FBL O.S.50Tarot ZYX DS610s servos Dragonus II Pro, TT Mini Titan V1, Tarot-EXI 450,MCPX' |
#8 |
#9 |
its good fbl system,, fly great... but no support of whatever, when GT5 fist come out they said its upgrade able firmware,, (fail safe ... et) but no whatever.. now GT5.1 they said the same thing ..???
I love my GT5 (v1) but i am not going to get another one. other FBL system like beatX and Vbar they got update like on monthly basic... make it better and better... but Thundertiger
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#10 | |
Once setup it flies great and is reliable, but you wont have the peace of mind knowing that you have a failsafe feature.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / T-Rex 450 Sport - 3GX - Tarot head / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 / |
#11 |
Im guessing no failsafe means if you loose signal the FBL unit wont level the blades and zero the pitch?
DX 7, EXI 450 FBL GT-5, HK 250 FB Quark, Nano Brushless 16500KV 125mm boom To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. (!) |
#12 | |
#13 | |
Well I guess I'll strike this nice gyro off my list then. It sure is pretty though, dogonit.
#14 |
Failsafe is only an issue if you don't use a reciever, even then failsafe is a croc of s4it! How often do you lose signal? I have not even seen it myself and loss of power will render failsafe useless!
Forget failsafe, it is for plankers and makes no difference to a helicoptor!
CustomHeliParts/KDE TRex 700N ThunderTiger X50 FBL Ely.Q Vision 90 Ely.Q Vision 50 |
#15 | |
I had an issue with the Vibe alert on my DX8 TX which caused a loss of signal, and when that happened the motor power was cut, which I had selected as the failsafe action.
#16 | |
Oh great! I'll just continue to use my RX then. I'm wanting to try the TT GT-5.1 one on my 450. That or a Microbeast, the Microbeast just looks bulky on a 450.
#17 |
I bout a used one off of a guy on here and it is junk, when I dubble tap the pad nothing happens, it I keep tapping and tapping then it might but by that time it has moved to a diffrent place up or down and I got no where, if it wasn"t for that it might not be to bad.
#18 |
Don't worry Mike, it's not junk! You will develop a feel for the double tap in no time!
#19 |
I don't have any issues at all with double tapping.
Team Thunder Tiger Europe 4RC.nl, Edge rotorblades, Scorpion systems To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#20 |
I have a Gt-5 on the way. I found it used here on Helifreak. Also ordered a FBL Head as well. I'm looking forward to trying it.
I've been so happy with my Futaba GY 520/S9257 I hated to part with it. I wouldn't have fooled with FBL but my FB head has a good bit of slop in it especially on the main shaft. I hope the tail is as good as the GY 520. That's the best tail I've ever had.
