Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 10-18-2012, 01:06 AM   #1
rz1a
Default Thoughts on gt5?
I have a gt5 I never setup at all. Is it easy to? Is it reliable?
rz1a is offline        Reply With Quote
Old 10-18-2012, 03:14 AM   #2
nbells
Not as easy as an AR7200BX !
I guess its a case of the more you fiddle with it, the easier it becomes.
I ditched my GT5.1 in favor of an AR7200BX unit and was flying within 30 mins !
This by no means says the GT5 is rubbish .. its just not as easy to setup as other units.
I also found the finger slide, double tap, on the side not sensitive enough for me !
Reliable ? ..... imo, yes, a wee bit better than certain other units !
Nigel
Nigel.
A few little tiddlers ..SR, 300X, TRex 500E Pro with DFC, Trex 700DFC..... and quite a few Planks and Tanks !
nbells is offline        Reply With Quote
Old 10-18-2012, 08:57 AM   #3
rz1a
Should I make use of it? I have a 700 I'm going to put a beast x on since I already have one, and my 600e doesn't have a unit yet but I do have the GT5.
Old 10-18-2012, 01:12 PM   #4
nbells
Originally Posted by rz1a View Post
Should I make use of it? .
Yes of course..... never waste anything !
Nigel
Nigel.
Old 10-21-2012, 10:17 PM   #5
dophuc
Default an awesome flybarless system
GT5 is an awesome flybarless system. Not easy setup and take more time to tunning, you should read manual carefully (manual for GT5.1) step by step.
Goodluck
dophuc is offline        Reply With Quote
Old 10-23-2012, 11:19 AM   #6
karlp
Goodluck
What he said
Once you understand it there is no better.
karlp is offline        Reply With Quote
Old 10-25-2012, 12:20 PM   #7
Himilou
Anyone using this on a Nitro? Seems like Thunder Tiger should be especially good at engineering a FBL unit for nitros.....
Gaui X5 FBL w BeastX! yesssssss!
"The Big T" TRex600N OS 50 +Flybar!
Synergy N5 O.S.55 Spartan Vortex
Himilou is offline        Reply With Quote
Old 10-25-2012, 08:43 PM   #8
rz1a
I'm gonna try mine on an electric but would have gone on my 600n if I didn't have a vbar.
Old 10-26-2012, 01:21 PM   #9
lowflyer101
its good fbl system,, fly great... but no support of whatever, when GT5 fist come out they said its upgrade able firmware,, (fail safe ... et) but no whatever.. now GT5.1 they said the same thing ..???
I love my GT5 (v1) but i am not going to get another one. other FBL system like beatX and Vbar they got update like on monthly basic... make it better and better... but Thundertiger (
lowflyer101 is offline        Reply With Quote
Old 11-03-2012, 08:13 AM   #10
1004ron
Once setup it flies great and is reliable, but you wont have the peace of mind knowing that you have a failsafe feature.
Originally Posted by 1004ron View Post
Out of all my FBL controllers, the flight characteristics of the GT5 V1 is about the best.
I really like the GT5, but would not buy another TT product because of the poor support and development - they must have know about the lack of failsafe and remained silent The setup is more complex.
I like having Rate Mode, which every other FBL controller has - not a deal breaker, put it's on the list of dislikes.
SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 /
1004ron is offline        Reply With Quote
Old 11-03-2012, 09:50 AM   #11
Bladecpnitro
Im guessing no failsafe means if you loose signal the FBL unit wont level the blades and zero the pitch?
Taranis X9D+ - Trex 550E-TT- 12S Scorpion 4025-650 - MicroBeast - 450 Pro - 4S - Scorpion 2221-10 - GauiX3 is here! If its fixed don't break it!
Bladecpnitro is offline        Reply With Quote
Old 11-03-2012, 01:04 PM   #12
lowflyer101
fail safe till turn off the motor when signal lost... with no failsafe the motor will go on and it kinda dangerou,, , when you lost while climb up,, then it will climb up till it land in moon
Old 11-03-2012, 10:47 PM   #13
Bladecpnitro
Well I guess I'll strike this nice gyro off my list then. It sure is pretty though, dogonit.
Old 11-04-2012, 02:38 AM   #14
NitroAl
Failsafe is only an issue if you don't use a reciever, even then failsafe is a croc of s4it! How often do you lose signal? I have not even seen it myself and loss of power will render failsafe useless!
Forget failsafe, it is for plankers and makes no difference to a helicoptor!
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
Old 11-04-2012, 05:57 PM   #15
1004ron
The risk of the RX losing signal is low, however is does happen and when it does we should make sure that it's as safe as we can make it.
I had an issue with the Vibe alert on my DX8 TX which caused a loss of signal, and when that happened the motor power was cut, which I had selected as the failsafe action.
Old 11-12-2012, 06:36 AM   #16
Bladecpnitro
Oh great! I'll just continue to use my RX then. I'm wanting to try the TT GT-5.1 one on my 450. That or a Microbeast, the Microbeast just looks bulky on a 450.
Old 11-14-2012, 01:59 PM   #17
MikeSmith
I bout a used one off of a guy on here and it is junk, when I dubble tap the pad nothing happens, it I keep tapping and tapping then it might but by that time it has moved to a diffrent place up or down and I got no where, if it wasn"t for that it might not be to bad.
MikeSmith is offline        Reply With Quote
Old 11-15-2012, 02:22 AM   #18
NitroAl
Don't worry Mike, it's not junk! You will develop a feel for the double tap in no time!
Ely.Q Vision 90
Ely.Q Vision 50
Old 11-15-2012, 05:57 AM   #19
Laurens
I don't have any issues at all with double tapping.
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote
Old 11-16-2012, 04:48 PM   #20
Bladecpnitro
I have a Gt-5 on the way. I found it used here on Helifreak. Also ordered a FBL Head as well. I'm looking forward to trying it.
I've been so happy with my Futaba GY 520/S9257 I hated to part with it. I wouldn't have fooled with FBL but my FB head has a good bit of slop in it especially on the main shaft.
I hope the tail is as good as the GY 520. That's the best tail I've ever had.
