Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 10-18-2012, 02:34 PM   #1
weaselbean
Default Velocity 90 aluminum tail rod guides?
I have been looking all over. Does any one know of any aluminum tail rod guides that will fit and work on the velocity 90? I seen a video of Lukas Riva flying one with aluminum rod guides so I know they are out there? Just where? I know the Align N tail boom is a larger diameter than the Velocity 90 so far. The T-Rex 700 rod guides, I have eliminated. My Velocity rod guides are brittle and strip easily. I have put CA and washers in the screw holes to no help Any help or info would be great?
"Quit crying about your airplane and fly it already!"
weaselbean is offline        Reply With Quote
Old 10-19-2012, 11:22 AM   #2
weaselbean
No body knows? OK guy's at least look here is the video look at the tail rod guides. They look like aluminum to me?
OK I think he is using these? http://www.experiencerc.com/store/ly...-c-p-5938.html I measured my tail boom OD diameter and got around 21MM so I think these will work as the Velocity 50 boom has the same OD as the 90? Wish me luck!
Old 10-20-2012, 06:10 AM   #3
p00rboi
I'm pretty sure those are the ones for the 50. They were used out of necessity due to the original ones breaking too easy. The new one are much thicker and more robust. The only issue you may encounter is the 90's push rod rides further away from the boom than the 50's. As you can see in the video it is doable.
p00rboi is offline        Reply With Quote
Old 10-20-2012, 11:45 AM   #4
weaselbean
OK thanks for the heads up my rod guides are very brittle. I had four on the first hard flight I broke the one closest to the tail rotor. My new concern is with the V2 tail if the have made a more robust tail boom it might have a larger OD than the original? If it is as you say than the new boom will come with new rod guides SWEET!
Old 10-20-2012, 04:11 PM   #5
p00rboi
There are newer v1 tail push rod supports out that are made from thicker more durable material. The new v2 tail boom has a larger diameter and comes with redesigned push rod supports.
Old 10-21-2012, 10:33 AM   #6
weaselbean
Awesome! I can't waite to get them both. I put 6 hard flights on her yesterday at a local fun fly. The 1ST flight my muffler came loose. The 2ND flight I lost one of my tail boom support bolts. LOL, Of course I took the muffler bolts cleaned them then re-lock tightened them. I replaced the lost boom support bolt and lock tightened the crap out if it. Then the rest of the day was nothing but some sweet fun flying. It's kinda weird these things came loose my Velocity looks very smooth and vibration free in the air. It's also one of the quietest helicopter drive trains I have ever heard. I'm loving it! It flys like a guided missile it goes right where I want it to go with no hesitation. I'm keeping it!
