| Brand Specific Charger and Battery Support Brand Specific Charger and Battery Support |
Wow! Check out the new iCharger. Fourty amps and 1400 Watts per channel. I'll never need another charger.
Nice! Looks very interesting. I like the screen
WOW. 70A output.... or 40A per side. ![]()
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
Nice, I may have to get one....hmmmm
Outrage Fusion 50 on 12s, BeastX, Savox 1258TG, ICE80HV, Outrage 4125-560kV Align 450Pro DFC, 2221-8, Mini V-bar Pro McpX...soon to be reborn brushless. AMA# 1005200 |
Grok this is pretty big news! you should post it in the main forum.
It is big news.
honestly I think the case should be black tho...
#6 |
I don't wanna double post. Someone else will share I'm sure.
#7 |
I'll make a post
#8 |
Thanks, Slyster.
#9 |
I just did the math and it will require 44v to get it's full power output of 2800watts. My charger case with two Dell PowerEdge 900watt PS's is heavy enough. I cant imagine needing two more. Not to mention two dedicated 110v circuits to run the four power supplies, or a pair of 2000 watt gennys.
The more I think about it the less I like it. If I lived at an R/C country club maybe, or if I had a site on my own property, but I would not use this as a portable. They should have done a 4010 single at half the price.
Compass 6hv & 7hv. MSH Protos. RCer Dragonus Pro & Elite. MS Hornet Custom. Robbe Eolo. MCPX. |
#10 |
If they keep with past practices, they'll release a 406DUO sometime next year.
Sent from my Galaxy Nexus using Tapatalk 2 |
#11 |
#12 |
looks neat, how come people want black items?Black is a hot color. I think the grey looks nice.
,B450 w.HS65MG,ZYX Tarrot Head FBL, Billowy Batterys ,MCPX BLack dragon oversky 10a, Blade CP pro BL |
#13 |
you could possible operate this unit on a 24-30v supply using 2x the amperage and still get peak performance if the unit is setup to handle it that way
I know on my pl-8 I can run 1 13.9v 100amp supply and charge 6 6s batteries just like I do with the 24v supply but the fan on the charger runs all the time because it pulling the amperage needed to do it. Not recommend to run that way but it does its a beast but I like it. thing is you could just about buy 2 pl-6 chargers and do the same thing on 24v for what that costs. Did anyone thing about that But it does up to a 10s sell, very nice
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
#14 |
But it isnt, Specs say max 65A input current so a 30V supply nets you less than 1950W output.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#15 | |
That will only give you 834WATTS out. Most all high output chargers will only give you 1/2 output when powered with 12V. |
#16 |
Anyone have anything new about this charger?
Looks like the arrival date on ProgressiveRC has been moved back to 12/10.
Compass Atom 500, DJI 450 Flame Wheel, mCPX Brushless, Nano CPX, T-28 Trojan, "Crash Proof" Hawk Sky, DX8, overinflated sense of self worth! |
#17 | |
LAHeli - Mikado - Henseleit - FASST
Powered by ProgressiveRC & Spyder Batteries |
#18 |
#19 |
This is interesting, it has a servo tester built in, I had not read about that before.
#20 |
They are finally here! Don't even have them all unboxed yet
