| Futaba Radios and Electronics Futaba Radios, Gyros, Servos, Etc. |
#61 | |
steve any clue then the next batch is scheduled??? i gather i misted the first batch??? |
#62 | |
I can't say for sure about the first batch. Looks like we did expedite more than I thought we would, but I don't have access to real time information. Steve |
#63 |
Thanks Steve!!!! Puting the order in!!!!! This will be my first Futaba radio have been JR and speketrum for a long time? I needed a change and this new radio looks like winner???
#64 |
i am suprised that the 14 sg is $200 cheaper than the 12fg. am i missing something or is the 14sg inferior in some way to the 12fg, build quality or something like that.
TREX 500 Futaba 7c 9650s and 9257 tail 401 gyro thunder power 6s 2600, thunder power 610 Blade CP pro Kitesurfing when it's windy, flying rc helis when it's not! |
#65 |
Would there be easy pay for this item?
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol The heli virus has infected me and i hope that there is NO CURE! |
#66 |
Just a couple of questions.
Do the 5 point throttle & pitch curves have any advantage over the 7 point ones in my 10C? And could you use a LiPo battery on it like I do on the 10C? If the answers are positive I could be treating myself to a new Tx
---------------------------------------------------------------------------------------------------------------------------- Trex 250, Trex 500, Trex 600 NSP, Trex 600 EFL Pro, Trex 700, Beast X, Futaba Need a bigger house
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#67 |
Five-point curves are a downgrade from the seven-point curves in your 10C. However, if you don't need the extra curve detail that more points provides, it won't really matter. I only fly governed electrics, so all of my pitch and throttle curves are straight lines. (And if the software is as much like the 8FG software as it sounds like, you should be able to turn off any points that you don't need; I've done that on my 8FG, leaving my pitch and throttle curves with only two points each.)
You should be able to use a LiPo battery, assuming that you can find one that will fit. Make sure that you get a 2S battery, not the 3S battery that many older transmitters use. |
#68 |
This is just my personal feedback, but I always liked the 5 points over the 7 better anyway.
At least for the pitch curve it really gives you a nice simple center point from 0-50, or 50-100. With the 7 point, its kinda a hash of a number in between which I know basically works but is really in the end the same movement as the 5 but just more work. Yeah its government work I know but work none the less. |
#69 | |
The Capi - HF Support
SAB Heli Canada / RotorQuest/Compass Team KBDD Spreading capibara awareness since 2006 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#70 |
#71 |
I don't recall the exact method to disable them, but its something like scrolling over the X value and pressing down and holding the wheel. When it disables it it puts a "-" through the X and Y values for that point.
#72 |
I use a 2S lipo that was meant to fit the 8FG. Perfect!
#73 | |
Steve |
#74 |
So the least one can do is 2 points? Big improvement for flat Th curves but only 1 would be great!
Marcos Banshee #27, 2x TDR, Diabolo, JR Sylphide E12, Voodoo 600, Voodoo 400, Avant Aurora 90N, Rave 450, Gaui X2 |
#75 |
Not sure if you need 2 or 1 will work, never tried.
#76 |
If you have to be placed on the right value the 0% and 100% don't have one on their right, so they are not removable.
#77 |
Shame about the 5 point curves as I like to have a pitch change around the mid stick point. I don't know if you can move the points on the horizantal axis, that would help
I could do something with expo but it wouldn't quite be the same. A friend of mine says you can't buddy the 14SG with the 8FG, anyone know?
#78 |
Yes you should be able, "almost" any Futaba radio with each other. I regularly buddy from my 8FG to a 7H. The 14SG is practically an 8FG, it would be very weird if you couldn't.
#79 |
It would seem strange if the transmitters weren't compatible I guess its early days & rumours are bound to circulate.
For now the 5 point curves has put me off unfortunately unless there is an upgrade for 7 points in the pipeline, I know it sounds daft but it's just the way I like to set my heli's up. A mate of mine sets his up the same way & has taken the 14sg off his Christmas list as well.
#80 |
