Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 10-26-2012, 02:30 PM   #1
ScotY
Default Warp carrying case
Just wondering if anyone knows if the Warp will fit in a Trex 450 carrying case? I have one that I am not using and the internal dimensions are 27" x 11.5" and about 5.5" deep. If I remove all the Trex-shaped foam, do you think the Warp will fit? It wouldn't be a big deal if blades and/or canopy have to be removed to make it fit.
Thanks!
ScotY is offline        Reply With Quote
Old 10-31-2012, 10:28 AM   #2
s0laris
the boom will prob be longer like my g5 was
Outrage 550, Goblin 630, 700, warp 360, Dual BL Mcpx, 130x
**When you start to be in complete control reflexes are not a requirement.**
s0laris is online now        Reply With Quote
Old 12-22-2012, 08:44 AM   #3
Coco66
Did anybody find a good case for the Warp?
Would a Blade 450X case work with some foam modding?
2 X Blade mCP X v2 ♦ night fly Blade mQX ♦ LadyMQX hybrid ♦ Blade 450X w/telemetry and Loc8tor ♦ Blade Nano CP X ♦ Compass Warp 360 w/AR7200BX, (2nd) Koby 40, DS92A+, DS95i, telemetry and Loc8tor ♦ Spektrum DX8/DX6i
Coco66 is offline        Reply With Quote
Old 12-22-2012, 09:11 AM   #4
ccnada
I could not find an Aluminum case that would hold the warp with the canopy. But I did find this bag and ended up ordering it.
http://helidirect.com/revogear-helib...ss-p-28337.hdx
If you don't mind removing the canopy, this aluminum case looks really nice. And cheaper!
http://www.hobbypartz.com/exialhecacap.html
When I did some research on this case, I think the inside length measurement was just a tad short with canopy.
X5, DX7se
My son Enzo's - X5, mcpxBL, DX7se
ccnada is offline        Reply With Quote
Old 12-22-2012, 09:56 AM   #5
brent.downey
I have a non branded 450 size case for my Blade 450X.
The warp fits perfect without the canopy but...
With canopy, it will fit with the sponge removed and leaves about an inch on either end for clearance. This is no good so... with the sponge in, it just isn't going to fit.
You will need to cut a small slit in the back for the tail fin and about an inch in the front for the canopy.
When I'm totally finished my build I will do this.
Some pics...
ID:	376092   Click image for larger version
brent.downey is offline        Reply With Quote
Old 12-22-2012, 10:16 AM   #6
Coco66
Some pics...
Can I ask you for a favour? Could you measure the interior dimensions (without foam of course)? That'd be great!
Old 12-22-2012, 11:02 AM   #7
brent.downey
no probs
271/4" X 9" X 71/2"
Old 12-22-2012, 11:24 AM   #8
Shogun71
Jeff just uses a cardboard box....
RCHeliCanada.com
Field & Support Rep
Shogun71 is online now        Reply With Quote
Old 12-22-2012, 12:28 PM   #9
Luigi_tuga
It's the new line of heli carrying cases, 100% eco friendly
Warp 360 , Tarot 480
T500Fbl AP
MCPX bl PZ StrykerQ DX8
Luigi_tuga is online now        Reply With Quote
Old 12-22-2012, 12:35 PM   #10
radu7
I have one of the cases from HobbyPartz and without foam it measures 675mm (L)x225mm (W)x215mm (H) and the lid give an extra 27mm of height when closed. So I don't think the Warp would fit with the canopy on even with the foam removed. Canopy off would work. JCL mentioned he found a rifle case at Academy sports that worked so that could be an option too. Like Shogun says, cardboard boxes work, just put some foam in the bottom and you're done! If you're looking for something really nice I bet Diviner could construct a 'Team Flux' case that we'd all be tripping over ourselves to get our hands on.
Seeing how many people are looking for an actual case for their Warp I would think Compass could have some made and would probably have as hard of a time keeping on the shelf and the Warp kits themselves.
radu7 is offline        Reply With Quote
Old 12-22-2012, 01:16 PM   #11
Coco66
If Diviner, other than time travel, can provide teleportation of the case to Italy, I'm in!
Jokes apart... please please somebody do a nice shiny case for the nice shiny Warp!
Old 12-22-2012, 06:14 PM   #12
JCLs
Here is mine. Is a Plano 36-in Tactical gun case i got for $60 at local Academy store. They go for $110 and up online. This a really high quality case!
http://www.academy.com/webapp/wcs/st...+Case+&Ntk=All
On the iPad again,
JCL
JCLs is online now        Reply With Quote
Old 12-22-2012, 07:22 PM   #13
radu7
On the iPad again,
JCL
That looks even better than I had imagined. Great find!
Old 12-22-2012, 07:30 PM   #14
ccnada
Wow JCL, that is a really nice case!
X5, DX7se
Old 12-22-2012, 07:57 PM   #15
GimpyGolden
How do you cut the foam so clean, especially the depth?
Scott
RC
HeliCanada.com
-Rep
Compass 7Hv - Synergy E5 - Logo 600
Next: 6Hv Ultimate
GimpyGolden is online now        Reply With Quote
Old 12-22-2012, 08:18 PM   #16
Diviner
I was thinking the same thing. That looks like it was a precision factory cut made especially for the Warp.
6hv, 6hv, 7hv, X5, T500, Warp, 300x powered by the FLUX CAPACITOR
Diviner is online now        Reply With Quote
Old 12-22-2012, 09:42 PM   #17
ScotY
I've never tried it but heard that you can use a carving knife. So after you carve your Xmas turkey, you can go ahead and cut some foam.
I googled that case and it said it's got pick and pluck foam.
Old 12-22-2012, 09:47 PM   #18
battmo
The electric carving knife works really well.
6HV
Atom 500
MCPX
battmo is offline        Reply With Quote
Old 12-22-2012, 09:53 PM   #19
JCLs
It is already partially cut. Small cubes that are tacked together on all sides. There are 3 layers of the cubes. I made outline and pulled unneeded cubes. Pulled all three layers as there is still a full top and bottom layer. Have place for 3 batteries but no batteries in checked luggage which is where this is going tomorrow. Have spare blades and then some hardware and basic tools in the pouch. Have a little 6 amp charger which is fine for these 1300 mha batteries. My wife has carry on that has the radio and I have two batteries. Ready to go.
Merry Christmas all,
On the iPad again,
JCL
Old 12-22-2012, 09:59 PM   #20
JCLs
Yep "pick and pluck foam" is proper term. I used marker to outline and had at it.
On the iPad again,
JCL
