| Warp 360 Compass Warp 360 Model Helicopter Discussion |
Hello Guys,
this is the complete version of the WARP 360 manual. This time I did the manual by myself with some support from Keven, Jürgen, Dave and Dana and it was a very hard job to do it. I hope you guys like it - its more or less a book! http://www.mttec.de/mediafiles//manu..._manual_V1.pdf Greetings Sebastian
Team Compass Model - Kontronik - Rapicon - MTTEC - KBDD - MKS |
thanks
Trex 500 : Atom FBL head AR7200BX | Atom 6HV : vbar 5,3 pro | Goblin 700 : vbar 5,3 pro | Goblin 500 : vbar 5,3 pro |
OUTSTANDING SEBASTIAN!
Looks like we are getting close now!
KBDD-Team Pilot Team Compass / ProStar Hobby Gens Ace Field Representative Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50 |
Suhweeet!!!
ADDED: That is one NICE manual........ ![]()
Warp 360 Spartan Vortex VX1 |
Nice job! I can't wait to start my build!
Scott
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Spartan Vortex VX1 Inside Team A Main Hobbies/ProTek Field Rep. |
#6 |
Best compass manual ever!
Sent from Android via Trap a talk 2 |
#7 |
A manual to match this design! hats Off!!
Henseleit TDR 2011,GT-5. BLS451/251, Pyro 700-52, Jive80HV, Radix 710FBL, Radix 110 tails Compass Warp 360, GT5, MKS 92/8910, Edge 60 tails. Phoenix R/C, Futaba T14MZ |
#8 |
Hey Don I'm loving the 6HV you sold me. You going back to compass? And yes this is the best manuel I have seen from compass thus far! I have pre orderd and await the build!
Nankinhobby.com Field Rep Compass Support Compass Atom 500 FBL Compass Atom 6HV FBL Compass Warp 360 Gaui NX4 Check out my YouTube channel: thedaveyht3 |
#9 |
Greets Dave!! I have been keeping tabs of some of your activities and watching your movies! You have improved by bounds and I am truly happy the 6HV found its way to you and you have really put it to work!
The Warp is a IMHO the absolute best 450 design and a move from Compass that I wished for over two years ago http://www.helifreak.com/showthread....ight=donskills. Glad they "saw the light" and changed their minds! The warp is the only 450 design I care to give a go as I tried a 450 pro on 6S a while but all the slop and screwing around just to get a few flights made me sick. So did the constant destruction of tail blades and umbrella gears!! I will be getting a Warp as a beater most definitely!
#10 |
Can't wait to get my hands on the Warp 360, it looks very promising and as allready said, this is by far the best Compass manual ever
Grtz, Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team __________________________________________________ _____ ATOM 500 FBL (BeastX) / ATOM 6 HV FBL (BeastX) / 7HV FBL (BeastX) / Henseleit TD R |
#11 |
Guys I have a question about page 13 of this manual. Is anyone concerned about this part? diffrences here will affect a huge diffrence in axial play!""Push the rotorhub (1) onto the main shaft (2) and fix it with the jesus bolt (4) through the hole in the main shaft. Axial play of the main blade grips on the rotor hub is normal and caused by the design with a radius and no step. A step would weaken the hub. The slope might not be the same on both sides, because of the tolerances on the radius. Very small I understand why it was designed with the radius instead of the step, and I am glad they did it that way. I understand why the radius design can allow a bit more play, and I see that it says a bit of play is normal, but could there be any adverse effects (such as excessive wear on the bearings or the hub)? I'm not saying there will be, just offering up some food for thought. I flew my trex 250 with lots of axial play when I put the Tarot head on it and it worked fine, because centrifugal force keeps the grips in the right place for flight, but could it be a concern on this bigger heli with thrust bearings instead of regular bearings like the 250 tarot head has? Any beta testers have a rough estimate of how much play can be expected? Would there be any value in putting an O-ring on the hub before we put the blade grips on to allow some wiggle yet keep outward pressure on the grips to reduce the play a bit? Am I getting worked up over nothing? Regardless, I can't wait for my kit to arrive, and I am inclined to trust their design, as I haven't heard/read anything significantly bad about compass heli's yet, and it's obviously working fine for the testers.
Align: 250, 450 Pro v2, 550 v1, Chaos: 600 MSH: Mini Protos 6s stretch, Protos 500 plastic Compass: Warp 360 B:130x, 300x, 450 FBL |
#12 |
I believe this is a non-issue.
As far as I can see, this is the very same design other Helis use on the tail hub (e.g. TDR). Any *axial* play will not matter at all and become irrelevant once the rotor is spinning. Cheers, Daniel |
#13 |
Ya probaly. I was probably reading too much into it. It was their last sentence with the exclamation point at the end that got me over-thinking it.
I think the only difference between this and all the tail hubs ive seen is the radius part rather than a step. The step gives the bearing something solid to stop against where this would be more of a wedge that may not stop the bearing as firmly.... Anyway, im sure its fine and that the designer thought of this way before i did and decided that it is not a significant issue. As long as the bearings fit snugly in the other axis i guess thats what really matters. Sent from my iPhone using Tapatalk. Please excuse spelling and/or grammar issues. My thumbs are huge from all this RC flying.
#14 |
Shouldn't be a concern at all. The grips will be pulled outwards and any axial play, where the bearing is sitting on the hub, etc. makes no difference. The bearings really are riding on the bolt and washer that secures the grip...hub inner surface radius should not make contact.
What concerns me more is the press fit pins for the tail slider links. I'm not a fan of that arrangement. Would be 1000% nicer if they supplied a pin with e-clips to secure it. As I understand it, the bigger Compass helicopters use a press fit pin also...unfortunately. |
#15 |
Yes, the 6HV I had used the press fit pins. While not thrilled with that design, they never failed me.
#16 |
That press pin design will also be new for me. Time will tell if i like it...
Warp 360 , Tarot 480 T500Fbl AP MCPX bl PZ StrykerQ DX8 |
#17 |
Yeah when i got my protos and saw that it used press fit pins i was worried. They havent budged at all since the build though. I guess theyre fine too.
#18 |
Is page 7 supposed to be blank the one with the technical specifications because to me that's the most important page on the build. Once the helicopters built it's the only thing I ever look at. Would really like to know the technical specs Especially for the motor.
#19 |
Nope, this is page 7:
#20 |
amazing work on the manual, thanks so much.
printed mine today at work and bound it great manual, best yet.
Models:Compass 6HV Synergy E7 Warp 360 Radio: Futaba 8FG |
