Go Back   HeliFreak > R/C Helicopter Support > Outrage RC
Outrage RC Outrage RC - and XP Li-Po Factory Support Forum
Old 10-30-2012, 08:42 AM   #1
Triple-D TJ
Default Outrage & New Gear Set
I'm going to stirr the pot on this topic..
What is so special about the new gear set that it is worth $35??? Ask youself this when buying this Retrofit Kit... I could buy the old gears for less separatly, why am I paying more for a package deal, when I should be giving a discount for all of my heartaches!!!
$ 8.49 - Outrage Shaft Spline Set (The new style) http://www.experiencerc.com/store/r5...ne-p-3491.html
$ 3.99 - Outrage Tail Rotor Shaft Set. http://grandrc.com/Nitro-Helis-&-Par...duct_info.html
$ 10.99 - OUTRAGE Torque Tube Front Drive Set http://grandrc.com/Nitro-Helis-&-Par...duct_info.html
$ 23.47 - Total..
Outrage, Where is the other $12.00 going to??
NITRO WHIPPY / E-WHIPPY / FUSION50 / 2 - VELO50N2 / Synergy N5C / TREX 450PRO / TREX 250 / 130X
Triple-D TJ is offline        Reply With Quote
Old 10-30-2012, 08:48 AM   #2
fastflyer20
Packaging
fastflyer20 is offline        Reply With Quote
Old 10-30-2012, 02:38 PM   #3
Slyster
R&D?
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is online now        Reply With Quote
Old 10-30-2012, 04:25 PM   #4
Triple-D TJ
I agree, Outrage should pay us for our R&D work! Should I expect the Royalties then??
Old 11-05-2012, 03:49 AM   #5
im4711
great to see that you designed the new gear.
However I do not think its just the design work that makes it more costly. Different contractors maybe involved that may just cost more.
im4711 is online now        Reply With Quote
Old 11-12-2012, 09:38 AM   #6
Triple-D TJ
Comon, $12 per set.. Thats a 31% cost increase over the last junk offered.
Please note, I have about 50-75 Flights on a black set.. Most gear failures I’ve experienced were result of a crashes. Chipped a few teeth in flight, but I'm only ranting simply because I'm cheap.. For $12, you can still acquire a 4pk of the old ones if one looks hard enough.
Old 11-12-2012, 03:05 PM   #7
im4711
Have you seen the new gear sets? If you have had them in your hands you may understand that they are larger and better quality.
Anyhow - no one complains if you do not buy them. i still run the black gear on the V50 N1 and N2. Nothing wring with it yet. Still since the Fusion has more torque I decided to go for the new sets in those.
Its your choice.
Old 11-13-2012, 09:48 AM   #8
Triple-D TJ
Its your choice.
Yeah I've personally seen the new gear set, they look great and I'm sure they perform well. Just holding out on buying new ones as I have 16 sets of white tail gears.. lol I bought 4 - 4packs because they were cheap!
I recently picked up a used fusion 50 where I'll likely run the new gears with my set up.
