Old 10-30-2012, 05:28 PM   #1
Old Dog
Default MA X Cell 60 set up Question
Got back into Helis after 15 years or so. Back in the day I was using a JR 10 x and still own it, But I now use a DX 8 with my planes, Anybody got a set up they would like to share for a DX 7 or 8 Been playing with a few small electrics to get my fingers back but wanna blow the dust off some real classics. I have 1 Graphite SE , 1 Stacked frame 60 and 1 bent frame 60 all ready to go just need to set them up on this 8. Any help would be great Jeff
Old Dog is offline        Reply With Quote
Old 10-31-2012, 12:58 AM   #2
Rudy
I don't have the settings. However I would just plug everything in then.
1. Get all the servos going in the correct direction.
2. Center the trims and the sticks and set your servo arms for 90 degrees.
3. Level the swash, center it and set blades for zero degrees of pitch at mid stick
4. Check that you have at least +10 to -10 degrees of pitch at top and bottom,
5. Check your tail and gyro for correct direction.
6. set gyro gain at midpoint
7. Set your pitch curve
8. Set your throttle linkage and travel.
9. set a throttle curve for normal mode.
10. Fire it up and see what you have.
That is what I would do.
Rudy - Currently in ??? It depends on the day of the week where I am
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote
