| Robird G31 RobirdUSA Factory Support Forum |
#41 |
The instructions are shown in poor broken english in step 3....
Keith |
#42 |
Ahh, I was wondering why the swash kept going to the extreme limits, that makes sense now
Gaui X5 FBL w Beast! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. yesssssss! "The Big T" TRex600N OS 50 hyper Velocity N1 FBL O.S.50Tarot ZYX DS610s servos Dragonus II Pro, TT Mini Titan V1, Tarot-EXI 450,MCPX' |
#43 |
has any one else had this problem followed instructions plug ed the SRX into the srx 1 port tryed DSMX and DSM2 sats none of them will light up any ideas!!!
#44 |
Have you already bound your satellites using a normal receiver?
Don Newman MAAC #82859 Align 250 Pro DFC, Tarot 450, EXI 500, Chaos 600 |
#45 |
I have tryed 3 differant sats none of them will light up
#46 |
Do you have the FBL only plugged into USB or do you have it powered separately?
#47 |
I did what you said bound it with another receiver as it was new and never bound the strange thing is i tuned on the transmitter with the heli i bound it with and it lit up but i cannot bind it with this one
very confusing do you hafto use a bind plug with this unit because it says nothing in the instructions at all |
#48 |
From what I have read, the G31 is not capable of binding the satellites. They must be bound using a normal receiver first and then plugged into the SRX cable.
Even though the G31 itself can be powered through USB, you must also provide power to output bus for the satellite. The power through USB will not power it up. You can either use a standalone BEC or through one integrated into an ESC or you can use a NiMH battery pack. It must also be providing power to the correct power bus for either the SRX1 or SRX2 connection you are using.
#49 |
You basically are going to have to supply power to the g31 through 2 different ports for Sbus I power the servo side \ g31 through the Srx adapter with power originating at the rx unit. The tail is powered by connecting the other lead of my rx life battery to Srx 2 directly. Not sure if you can supply power through the DSM port on the SRX adapter though.
You might want to see if you can supply power by connecting the normal servo side plug of the adapter to your power source
#50 |
Hi Yea done all that I am using a separate NIMH battery to power the unit through the motor esc terminal , I am using the SRx1/All terminal for the remote with the SRX unit supplied I checked the power where the sat plugs in and i am getting 3.1v on the orange and grey wires so power isn't the problem I have 6 beastx units its not that i haven't done this befor i think i may have a faulty unit i have sen't them an email so i may hafto wait to hear from them Cheers!
#51 |
If anyone who has theirs fully functioning would be kind enough to do a diagram and post it? May help make more sense? A full Rx diagram, single and dual sat would be awesome.
I'd do mine but it hasn't shipped yet. sent from my phone using circus midgets
Tarot / Align 500e DFC (x2) ---Robird G31--- |
#52 |
Have you read the manual - there are pictures for all of these in the manual
#53 | |
Ill be using a Rx+sat, powering via bec. I assume I can just manage all that the same way I done with the zyx (ie: pulling the + lead from the esc plug and replacing it with the + from my bec), shouldnt run into any power issues with the Robird? I know it has 3 separate power buses, but I assume they will all just draw from the jumper wire from the Rx..and no need for a separate power source like with the sat only config? sent from my phone using circus midgets
#54 |
tunner777,
In setup guide in step0 Receiver what did you select under receiver, PWM, SBUS, DSM1024, or DSM2048? If useing Spektrum Sat. Rx. you should select DSM1024 or DSM2048
Keith |
#55 |
I thought I would upload the directions for the Black Widow version of the G31. The pictures in the instruction is of the older software.....
Keith |
#56 |
#57 | |
#58 |
Hi I selected DSM2048 I managed to get it working by copying the model i bound it to then changing all the functions back to what they should be set it all up now i can't get the ESC to fire up so i can test it when i connect power the esc gives the first part of the tone 3 chimes but it will not arm the motor get over one snag back to another tried going into set up mode but just 3 chimes will not even do that stumped again
#59 |
Keith, thank you so much for that file, i have now added it to my favorites list. Now i have a quick check link to go for any issues.
Atom500(FBL).,Trex450 sport (FBL). To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Tony . |
#60 |
WE GOT STICKY'D!!
![]() ![]() Thank you Bob O and thank you to all that's helped out! Now lets keep the good info flowin', we got a real good start!!
