Go Back   HeliFreak > R/C Electronics Support > Robird G31
Robird G31 RobirdUSA Factory Support Forum
Old 11-11-2012, 01:07 PM   #61
ifheli
I finally had some time to get out and do some flying over the weekend. I believe I have reached my final settings for the tail on four helis. I have two MT w/ 350 blades and two B400 w/ 350 blades all running 6S. I captured some screen shows of settings....
Name:	3GY-blue-MT-KST115 servo.jpg
ID:	365314   Click image for larger version
Name:	3GY-black-MT-KST115 servo.jpg
ID:	365315   Click image for larger version
Name:	3GY-blue-B400-MKS95i servo.jpg
ID:	365316   Click image for larger version
Name:	BlackWidow -B400-9257servo.jpg
Keith
ifheli is offline        Reply With Quote
Old 11-16-2012, 10:20 AM   #62
SDedic214
Default New G31 Users Manual
We've just completed a new users manual for the G31. This manual covers the PC set-up process, setting up the governor and also provides details on the different settings in the Performance tab.
The manual is for the upcoming 0.98D version of the software (which will be released soon) but the rest is basically the same for the 0.98V version.
The manual is located at www.robird.net/g31 and can be downloaded from there.
Let us know what you think!
Also, we'll be announcing the U.S. website for the Robird distributor very soon - keep watching here for news.
SDedic214 is offline        Reply With Quote
Old 11-16-2012, 10:30 AM   #63
LawnDartHeli
Very cool, thanks!
sent from my phone using circus midgets
Tarot / Align 500e DFC (x2)
---Robird G31---
LawnDartHeli is online now        Reply With Quote
Old 11-16-2012, 11:03 AM   #64
tony521
Great, thank you so much.
Atom500(FBL).,Trex450 sport (FBL).
Tony .
tony521 is offline        Reply With Quote
Old 11-16-2012, 06:18 PM   #65
ifheli
This is good news.
Keith
Old 11-17-2012, 03:03 PM   #66
Himilou
Nice like the manual. Now answers the question I was going to ask....
Gaui X5 FBL w Beast!
yesssssss!
"The Big T" TRex600N OS 50 hyper
Velocity N1 FBL O.S.50Tarot ZYX DS610s servos
Dragonus II Pro, TT Mini Titan V1, Tarot-EXI 450,MCPX'
Himilou is offline        Reply With Quote
Old 11-17-2012, 06:36 PM   #67
LawnDartHeli
Originally Posted by SDedic214 View Post
Here are some general servo arm lengths to consider when setting up your Robird G31:
250 cyclic: 10.5mm tail: 5mm
450 cyclic: 12.5mm tail: 8mm
500 cyclic: 18mm tail: 10mm
550 cyclic: 21mm tail: 13mm
700 cyclic: 11 to 12mm tail: 13 to 15mm
(Note: For 700 size helis the above distances are for push/pull systems)
Note: These are GENERAL guidelines and you should always refer to your helis assembly manual first.
It's gonna be impossible for me to get 18mm on the elevator servo. It will hit the tail boom block at full sweep.
---Robird G31---
Old 11-17-2012, 06:52 PM   #68
tony521
those measurements are good for the trex pro, but for the sport and se v2 models they are different. the best thing to get is a swash leveler after getting the servo arms as to 90 degress as possible, then use sub trim to level out .
Tony .
Old 11-17-2012, 07:06 PM   #69
LawnDartHeli
Those measurements are for center of servo horn-to-ball..right? It says 18mm for 500 size, not a problem on the aile/pitch as they are in the side..but at that length the elevator will looks like it will contact the tail boom block. Level swash@ 90/ zero pitch won't be an issue.
---Robird G31---
Old 11-17-2012, 07:10 PM   #70
LawnDartHeli
18mm is a reach, but another guy has his 500 set around 18.5mm. So it should work..I guess I'll see. Im sure grip ball distance from center of feathering shaft will play a big part in how much sweep it really needs..
---Robird G31---
Old 11-17-2012, 10:31 PM   #71
Lighty
What are you guys setting the Motor ESC/Throttle for an electric? I'm using the YEP 45 speedy.
cheers
6HV + VBAR FULL 5.3 PRO
Compass 7HV ULTIMATE VBAR 5.3 PRO Gens 5300 / Revo 4400 60C WARP 360 / Turnigy LIPOS Balances GREAT!
Lighty is offline        Reply With Quote
Old 11-17-2012, 11:11 PM   #72
SDedic214
Use the Analog setting.
Old 11-27-2012, 08:34 PM   #73
LawnDartHeli
Just checking in. I haven't abandon this thread, just waiting on all my stuff to arrive. Should be end if week. Then Ill get some more build info up.
---Robird G31---
Old 11-28-2012, 10:44 AM   #74
SDedic214
I don't recommend using the Sub-Trim function in your transmitter to get the 90 degrees because the gyro will read these as input commands from the pilot and it will try to correct them.
Instead, go to the CollPit tab and use the LeftNeutral, CenterNeutral and RightNeutral functions to set your servo horn positions to 90 degrees.
Old 11-28-2012, 06:01 PM   #75
tony521
Glad , you saw that error, that is what i meant. Use the collpit tab. Sorry, my mistake.
Tony .
Old 11-29-2012, 09:36 AM   #76
SDedic214
No worries my friend, we're all here to help.
Old 11-29-2012, 06:33 PM   #77
LawnDartHeli
Woohoo! Time to get busy!!
---Robird G31---
Old 11-29-2012, 07:04 PM   #78
tony521
about time you got yours.
Tony .
Old 11-29-2012, 07:07 PM   #79
LawnDartHeli
Dave's had it for a while, he was waiting on the rest of my parts from Tarot before he shipped. New Tarot 500 dfc head is pretty freakin nice!
---Robird G31---
Old 11-29-2012, 07:11 PM   #80
tony521
Ok, good luck on the setup.
Tony .
