| Realtime Video and FPV Discussions of receiving video in realtime from the aircraft |
Hi,
I just finish building a quad and done a few flights with it and I love it, now I also ordered some FPV goggle and a camera with video tx/rx. I run 4s lipo on my quad, and now I just read in the video tx spec that it need a 12v input, I want to know what others do to 4s setup with 12v video tx... not sure whats best. Some solutions I though about are: 1) add a 3s lipo for video tx only, downside is that it will add some unneeded weight to the quad (only 3s I have are 2200mah from my trex450) 2) get a LM7812 voltage regulator transistor at the electronic shop and install it to get a cheap step-down 12v voltage regulator for powering the video tx not sure if there is other options available, waiting for suggestions |
Get a very small battery (400-900mah depending on video time you want). A 7812 only shells out 1A which might be a problem with powerful video transmitters...
Lynx Heli Team Pilot Prôtos CF, 130X and many others. CarbonCore H6 950mm Wookong-M All on DX18! |
hey mate, i'll be running 4s soon also, just waiting for this:
http://www.ebay.com.au/itm/130783481...ht_2445wt_1163 It'll supply clean power to your tx, and you can adjust it to suit your power needs. Much lighter than another battery |
#4 | |
I've just ordered one, thanks to you Hopefully it'll get here around the same time as my fpv gear |
