| Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion |
Lets see those 700Xxtreme pics and vids. I see that Mikado has started shipping out kits, and a few lucky guys have them in hand already. I wont have enough saved to buy my kit until the end of winter. So I need to live through you guys for a few months..
Vergnugenstabi [adj.]pleasure/stability The enjoyment and feeling you get when flying a vbar. [farg-new-gen-stab-e] CF Logo 600SE.. Robert A. Team HAIYIN |
Here are some unboxing pics
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Electronics rough mounting started ![]() Glamour shot! LOL ![]()
Steve To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. #1 - Logo 600SX-THOR 10s 4400, YGE 90HV, Scorpion 4035-560kv on 12T pinion, BLS451/251 #2 - Logo 700-THOR 12s 5000, YGE 160HV VBar Gov, Scorp. 4525-520kv, BLS451/256 Last edited by sgrim80; 11-07-2012 at 08:49 AM.. |
I shall start off with the pictures then!
Jesse |
Logo 500 - Vbar5.3ProYGE90HV402011006sTP5000 Logo 700 - Vbar5.3ProYGE160HV452552012sTP5000 |
frank, flown it yet? How long did the build take you and any concerns?
#6 |
Haven't fly yet until this weekend, still under setting up the Vbar gov. I have built for 2 nights long and found some concerns:-
- It's a bit difficult to put the 4mm pin throw the tail gear. - The tail boom come with only 1 end holes pre-drilled, for the mainframe side need to be drilled (some steel chips will come off inside the torque tube and need to be remove after then) - Need to be careful about steel chips from the pre-fabricated mainframe which come from I think chassis mounting bolts. Loving the tail gear box and rotor so much and as well as the motor mount also...very nice. ![]() Franky
#7 |
Logo 500 - Vbar5.3ProYGE90HV402011006sTP5000 Logo 700 - Vbar5.3ProYGE160HV452552012sTP5000 Last edited by frankyay; 11-03-2012 at 08:46 PM.. |
#8 |
#9 |
Really nice! What are your first flight impressions? Does it feel heavy?
Mathias Mikado Logo 700 Xxtreme | Blade 130 X | JR XG8 & Spektrum DX8 |
#10 |
"??Does it feel heavy??"
I think his answer will be necessarily subjective based on what's he's used to flying The Logo 700 is a well balanced, well designed, well proven, and one tough heli mechanically. It also flies like a dream, and is well behaved. BUT...if you're accustomed to the feel of very light helis with super high head speeds (say like a Goblin and the way they are often set-up), the Logo 700 will by any subjective measure, feel "heavy". It doesn't look like it is suffering from any lack of performance (again, a subjective point of view). But a Goblin it's not (thank goodness) (-: Dave
Kyle Dahl Sponsored by: Mikado, JR, Voltz/Thor, Scorpion, Edge Blades. |
#11 |
The 1st flight impression is "XXTREME STABLE"
After some fine tune for my new bird, I agreed what Kyle said Logo 700 is a well balanced, well designed coz the response of cyclic and also the power is much enough. I used to fly 690 blade for my CF frame 600SE before in 2050rpm (3rd party blade grip), but I noted my new bird can cater much higher cyclic pitch and of coz even in higher rpm as well. I will try to keep on my flying report but unfortunately, my flying skills like a mess... Cheers Franky
Logo 500 - Vbar5.3ProYGE90HV402011006sTP5000 Logo 700 - Vbar5.3ProYGE160HV452552012sTP5000 Last edited by frankyay; 11-08-2012 at 08:01 AM.. |
#12 |
#13 |
Just noticed the little fan behind your motor. Is that standard or something you added?
JR X9503 2.4 [H] -- Mikado Logo 600 -- Hirobo Lepton EX custom FBL -- MA Furion 450 custom FBL To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#14 |
it's not a standard gear, just a cooling fan after each flights
#15 |
guys,
i have a problem on my yge 160gv with vbar silverline. 1) do i need to do the throttle calibration on my tx? do i connect the yge rx cable to vabr or to my rx? i'm using sbus. 2) The motor spool up only when my throttle is around 70%. Do i need to do some setting on vabr gov 2 settings? Pls advise.. Thanks a lot. |
#16 | |
Watch this video.
Steve To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. #1 - Logo 600SX-THOR 10s 4400, YGE 90HV, Scorpion 4035-560kv on 12T pinion, BLS451/251 #2 - Logo 700-THOR 12s 5000, YGE 160HV VBar Gov, Scorp. 4525-520kv, BLS451/256 |
#17 | |
#18 |
#19 |
Just flew mine today for the first time. Got it Thursday evening and had it built by Friday morning (4 am! I was too excited to leave it alone). It flies just amazing. Took it easy on the flight just to get a feel for it. Never set up a vbar governor before and yge is new to me. It was a HUGE (I mean really HUGE) hit at the field. I'm using MKS 950/980HBL servos and spektrum dsmx satellite receivers.
#20 |
Hope to have a video posted in a few hours. As for how it feels, mine actually felt very light on the sticks. I set 9 degrees on the cyclic and 65 on the acceleration for the tail. I also set mine up for precise and 40 on the pitch pump. Realize I only have two flights on it so far so ill probably adjust those settings. It's just so precise! It stops where you want it. Effortless!! I fly a Goblin, too. But also have a Compass 7HV and two 700e's. So far the logo was more exciting than all of them. Just my opinion...
