| Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion |
#21 |
Love the tail fins. If/when I get one, I plan to do something similar.
JR X9503 2.4 [H] -- Mikado Logo 600 -- Hirobo Lepton EX custom FBL -- MA Furion 450 custom FBL To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#22 |
Thanks! I guess I don't know why more people don't do this. I just used colored vinyl tape from RC country (comes on a 4'x4" sheet) and used an exacto to trim it out. To me it gives the Heli size. The tail just seems to get lost visually. I do this with all my helis (13 and counting). I also tape the skids for orientation purposes. I have old eyes and its hard for me to see if the Heli is leaning left or right. This way if I'm inverted going left to right and I see yellow under orange, I need left aileron to level out. Works really well. Anyways....
#23 |
Maidened my Logo XXtreme 700 today. Taking it easy on the first flight, but am liking it very much! The heli feels quite light in the air. Still need to determine how long I can fly with 5000mAh lipos, so shortish flight now to be safe.
1850 and 2050 head speed. |
#24 |
Doesn't seem like you're taking it easy to me. Great flying!
Looking forward to get mine as well.
Mathias Mikado Logo 700 Xxtreme | Blade 130 X | JR XG8 & Spektrum DX8 |
#25 |
Logo 700
#26 | |
Banshee # 30 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Logo 500 .Logo 600SX . Logo 700 .Logo 800 Goblin 700 |
#27 |
That in no way was taking it easy, really nice flying bro.
Vergnugenstabi [adj.]pleasure/stability The enjoyment and feeling you get when flying a vbar. [farg-new-gen-stab-e] CF Logo 600SE.. Robert A. Team HAIYIN |
#28 |
#29 |
Setup:
Motor: Scorpion HK 4525-520 Ultimate XXtreme Edition w/17T pinion ESC: YGE 160 HV XXtreme Edition Stabilization system: Mikado VStabi V5.3 Silverline Pro Rotor blades: Edge 713 og 105 mm Main batteries: 2 x Haiyin Scorpion Competition Power Pack 6S 65C 5000 mAh in series (12S) RX batteries: Hyperion G3 EX 2S 45C 1600 mAh Cyclic servos: 3 x MKS HBL950HV Tail servo: 1 x MKS HBL980HV Radio: JR XG8 Receiver: RG831B
#30 |
Mine showed up yesterday!!!!
Not the greatest pics ... but I still had to share Makes my Trex 500 look tiny!! The kit is going together soo easily..... mikado missed packing a washer for the tail rotor thrust bearings .... The local Aussie dealers were great and are sending me a whole new set of thrust bearings to get me in the air |
#31 |
Here is mine.
Silverline VBAR 5.3 PRO : TDRs - LOGO 700 XXTREME 600SX 600SE - Whiplash - FAIFA SRIMOK |
#32 |
Nice looking fleet there! You running a Castle BEC on the L700?
Eric To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Logo 600 / Logo 700 |
#33 |
WOW Tommy Bear, thats a friken stack of money in helis there, simply wow!
#34 |
That Kong Power battery takes me back! Are they still around?
Steve To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. #1 - Logo 600SX-THOR 10s 4400, YGE 90HV, Scorpion 4035-560kv on 12T pinion, BLS451/251 #2 - Logo 700-THOR 12s 5000, YGE 160HV VBar Gov, Scorp. 4525-520kv, BLS451/256 |
#35 |
Hi yes, I run the Pro Bec on all my helis in my fleet.
#36 |
Most pics I have seen of the L700 people have placed the v-bar sensor to the rear of the equipment plate, why???
I was planning on placing my sensor right up the front of the plate as close to the cg as possible ..... will also make it easier to access the usb port on the main unit. Any issues doing it this way?? |
#37 |
I had the access to USB port issue since the 700 frame is narrower than the 600 carbon fiber frame. I had to raise my Vbar control unit by placing it on top of my TM1000 telemetry controller. That way I was able to access the USB port and leave my sensor to the rear of the tray.
You would have to deal with routing all the servo wiring around the gyro sensor if you move your sensor to the front of the tray. There's also the issue if you offset the gyro either left or right off center (rear of tray) you need to be aware that the canopy may touch the sensor. Keeping it centered and slightly aft of the edge of the tray is ideal. Luis
Logo 700 XXtreme, SAB Goblin 700, SAB 770: Logo 600SE Carbon Fiber Frame 12S: Pyro 700-45, Kontronik 120 Heli Jive, 11T Pinion, Full Size V-Bar 5.3, 693/105 Blades Align 550E: Pyro 600-12, CC100, 17T Pinion, Full Size V-Bar 5.3, 553/86 Blades |
#38 |
Just got to really fly my newly built 700 XXTreme. She flies awesome. Here are a few video clips. One is with the Edge 753 and the other with the 713 Edge SE blades. I recorded the videos, my friend Raymond flies way better than me...
Check out my color scheme Luis
#39 |
Here are some pictures of my Logo's:
Luis
#40 |
A tandem flight the Kyle Dahl and I did this past weekend at the Orlando Heli Blowout! Was a lot of fun!
Hope you enjoy! Jesse |
