| FMA/Revolectrix Product Support FMA/Revolectrix Factory Product Support |
Hi
I configure my DX6i to be able to set the copilot 2 ON and OFF by using the gyro channel as describe in the instructions. My question is: now with that set-up I did program the selection switch for the gyro to be the FLAP/GYRO toggle switch. I had the choice between that one and the GEAR/FLIGHT MODE in the DX6i menu, but I use the GEAR/FLIGHT MODE switch for my IU mode. The thing is that I don't find the FLAP/GYRO switch at a easy location to be toggle ON or OFF without my finger leaving one of the two stick. A good location for an easy toggling would be the RUDDER DUAL RATE switch. Is there anyway I can use that switch to control the Copilot ON-OFF mode? Thanks
SYMA S-107 / BLADE Nano / BLADE McpX V2 / 3 BLADE 450 3D / ALIGN T-REX 500 ESP / DX6i / DX8 |
this might help?
http://www.helifreak.com/showthread....dx6i+gear+gyro
1 HT FPV Quad ,naza, fatshark "You can always tell a pilot,but not much" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#3 | |
Maybe I miss explain myself.. I'm french so let say it that way. I have control on my co-pilot using the flap-gyro switch because I set it this way instead of using the gear-f.mode switch. I was just wondering if there is another way that the on-off copilot be activated with the Rudder-d/r switch instead.
