My frame compared to original: More 3d pictures: Some pictures: ![]() ![]() Specs: Frame: Custom made 12S Align Trex 500 Gyro: BeastX Motor: Scorpion 4025 20T - 630kv 2,7kW - 3.5kW ESC: YGE60HV BEC: Hercules WRL-HBECHC Battery: 2 x Wolts 6S 1300mAh 35C or 2 x GensAce 1800mAh 50C Cyclic servos: 3 x DS510 Tail servo: DS650 Blades: Align 3G Weight: 2090g with 1300mAh batteries HS range 2800rpm to 3400rpm normally YGE governed IU1 3000rpm IU2 3200rpm. 3300rpm ungoverned on the video at 7:05 I have been having great time with it! Will post some more videos later...
T-Rex 500 HV FBL - Brain - http://helifreak.com/showthread.php?t=469088 T-Rex 450 Pro FBL - BeastX - Night Gear Spektrum DX8 - Phoenix R/C |
unbelievable!!!!
Great job, do you have a day job? I am in awe, don't know what to say. Craig
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. T-Rex 600N | T-Rex 500 ESP | T-Rex 500 GF | T-Rex 250 (Love this little bird) | 15 year old Shuttle ZXX |
Fantastic, lovely design.... You have access to the CNC equipment yourself?
You should sell these to be honest, the frame looks beautiful.
Blade mCP X - Brushless, XP-7A, HP05S Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i Align AH-1 Cobra (T-Rex 500) Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188 |
Well, I'm impressed!
Compass Atom 500, DJI 450 Flame Wheel, mCPX Brushless, Nano CPX, T-28 Trojan, "Crash Proof" Hawk Sky, DX8, overinflated sense of self worth! |
how much for a frame set?
Trex 500 ESP DFC FBL BLADE 130X GOBLIN 630 CC 120HV, Scorp 4225 610Kv, Outrage servos, Skookum SK720BE on order |
#6 |
Very impressive!
☆☆☆T-REX 700 DFC v3, AR7200BX, ICE2 160HV,DC-UP MARK II ☆☆☆MKS HBL950 & MKS HBL980, GRYPHON EXTREME REGULATOR ☆☆☆POWERED BY THUNDER POWER LIPO'S |
#7 |
Man, that is awesom where can I get one.
#8 |
Great! You use the same motor as I do in my 12s 600. What an awesome powerhouse for a 500 size helicopter
#9 |
Thank you for your comments!
I do have a small cnc which I used to make it.. ![]() ![]() I would love to make it to others too but it takes a lot of time for me to cut the frames and I just don't have the time right now. I asked some local companies for quotes but they are asking too much. ( over 250 dollars ) If you really want one, send me PM and I will check if it could be possible. This frame uses 500E / ELF ( not PRO ) parts like main blocks, 2 motor blocks ( one as vertical stiffener ) and front tail assembly and you also need 2 sets of trex 550 frame mounting blocks ( H55019 ) and 2 sets of 250 feathering shafts for the velcro mounts ( H25015 ) I also used 600pro screw set ( H60216 ) I wanted to use as much stock parts as possible but without compromising the outcome so only things I made are the cf frames and front cyclic servo mounts. ![]() ![]()
#10 |
I must say you've inspired me somewhat...
I might look to make my own custom frame for my 600 Pro to address the cyclic servo positioning. Project for next year maybe.
#11 |
X7 style servo holders might do it?
#12 |
Have you considered that whe you double the weight you increase the load per square sm. on the blades, and all in all the load on the main rotor?
Vasil ![]() |
#13 |
Kinda combined a align 500 and a logo nice!
#14 |
We have two of these at work, I'm in managment and don't run the machine but if I could get your die line I can cut one out for myself.
Craig
#15 |
Excellent Job!!
Sent from my SpaceShipOne |
#16 | |
And for sure I am loading it more and giving hard time to it but it seems to like it Btw, to all who sent me PM about it, I will try to answer all questions here on this tread soon...
#17 |
What a monster man! Excellent job! I'm def. jealous.
#18 |
Brain on it now... test flight up next
#19 |
Nice! Where did you get this metal mounting plate for the FBL system? We are awaiting vids.
Vasil ![]()
T-rex 500ESP 3G (waiting for Ikon) CC Ice 75 Spektrum DX7 Pulse batteries To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#20 |
Great work Juuso
I have seen this heli on our field and it's really impressive in terms of quality and performance. -Samppa
2x Kasama Srimok 90 FB & FBL | MA Stratus BW | Hirobo Turbulence D3 EX | Henseleit TDR 2011 HK4530 5+4 1.5YY SJo Power | JR Vibe 50 | MSH Protos | Futaba FGS 8 http://www.helifleet.com/SJo1 Last edited by SJo1; 11-13-2012 at 12:59 PM.. Reason: typos |
