#41 |
I got featured on RCTodayShow
Thanks! btw, it uses 500E tail gears ( 4.68 ratio ) so head speed can be lower.. I just like it high..
T-Rex 500 HV FBL - Brain - http://helifreak.com/showthread.php?t=469088 T-Rex 450 Pro FBL - BeastX - Night Gear Spektrum DX8 - Phoenix R/C |
#42 |
I'd be intersted in a frame set, keep us posted. Very nice work.
Lee Griffiths Lynx Heli Innovations Team Pilot |
#43 |
You should be in contact with Align to see if yall can hash out a deal where they can make this into a production model. These things would be selling of the roof if the would.
Rumors are started by haters, spread by fools and accepted by idiots. |
#44 |
Why would you let align make all the money when you can just sel the frames yourself
Trex-450 sport .....Trex 500 Raptor Titan 50 ys 56.ds610+650 gy520 T-rex 600 pro fbl scorpion 4035-560 CC hv 80 beastx ds610+650 all on 10s |
#45 |
I was just trying to come up with different ideas to get the frame set. I'm quite certain Align and the builder could come up with some agreement to have his design mass produced and he receive royalties from them. You see the interest that has been garnered by this design just in this thread. Imagine what it would be if it were wide spoken and people had the ability to buy them. This could easily start a new trend in heli's.
#46 |
Align will just take what they like and use it regardless...
Blade mCP X - Brushless, XP-7A, HP05S Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i Align AH-1 Cobra (T-Rex 500) Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188 |
#47 |
Just saw this thread, that's unbelievable!
I guess that could make for a nice stretched version, maye 470mm blades?
Ben Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251 DX8, RF6 |
#48 |
My HF Map location Join Date: Jan 2013
Location: Massachusetts... the state of not to few Mosquitoes
love the idea....how did you like the 500 as a 44.4V powered? it looks likes it flys really good.
sent via UAV Last edited by idontknowanything!; 02-25-2013 at 08:25 PM.. |
#49 |
I can't find the motor he used in this bird. Is it customed wound or something? Couldn't find any motor that would work for a 10s or 12s 500. Unless I'm missing something.
#50 | |
http://www.scorpionsystem.com/catalo...025-630-12N8P/
Warp 360 - Brain | 7HV - Brain |
#51 | |
Also, what was the 3d software used to draw the frame ? nbells
Nigel. SR, 300X, TRex 500E Pro with DFC, ..... and a few Planks and Tanks ! |
#52 | |
I use Ironcad. It is not the best for this kind of stuff but I like it. I will post more info about making the parts for others soon..
T-Rex 500 HV FBL - Brain - http://helifreak.com/showthread.php?t=469088 T-Rex 450 Pro FBL - BeastX - Night Gear Spektrum DX8 - Phoenix R/C Last edited by jkkmobile; 02-19-2013 at 06:22 AM.. |
#53 |
Really nice design and idea, although not very efficient. But something new is always wanted and interesting.
Your frame design looks very similar to modified PRO frame. I also have CNC, made couple Aloy parts for my 500, but never thought making whole new frame. Old one looked kinda workhorse and can take much stress. Thank you for new ideas, if I will be lack of power, I sure think about something like yours. Cheers ! ![]()
Trex 500DFC, Scorpion HK4015-1450kV, YEP 100A, ZYX+DS520. HK 500GT, Scorpion HK3026-1210kV, Align 75A, GY401+S9254. CopterX 250DFC, ZYX+DS420. Solo 100D 3G |
#54 |
Why do you say not efficient?
#55 |
I don't see the inefficiency as well! He is only using 2 X 6S 1300mAh 35C. Funny thing is he could use 10c packs with this setup because the amp draw at 45v would be incredibly low.
Micah Hills |
#56 |
Not very efficient, because 6s setup is enough for crazy power. I have HK4015-11250kv and my bird flies like on drugs. This 12s setup has more power (but do you really need that power) ? If yeas, in which situations or maneuvers ? And due to weight and 600 class motor flying times is low
Other thing is cost, which in this hobby is last thing to concern in, so cost better leave alone
#57 |
This is the same as a 450 running on 6cells. The weight should be the same as a regular 500. He is just using more cells, but less mah. The motor is not a 600, but a special wound motor for 12cells. The packs as I stated before could be much cheaper for two than one quality 3000 6cell. The speed control could be a 40amp HV with no problems.
Micah Hills |
#58 |
My motor is for 600 size helis: http://www.scorpionsystem.com/catalo...025-630-12N8P/
..and due that, like DerClown said, it is not that efficient.. but this heli was not designed to be efficient, it was designed to be super powerful. 1300mAH 10C packs or 40A ESC would have no chance with this motor. On hard 3D beating my 1300mAH batteries lasted only 2 minutes and came out too hot to touch.. and exploded at 50 cycles ( both Turnigy and Wölts ) Nowadays I am flying with 1800mAh 50C GensAces and getting 3:40 minutes @ 3200rpm and 4:30 to 5 minutes flying 3000rpm ( depending how much beating it gets ) those batteries have been great, no heat issues and over 100 cycles allready. If I would have gone with a smaller motor it would have been efficient and wouldn't need high specs batteries or ESC.. but i wanted the POWER!
#59 |
I want one just because I absolutely love the layout of the frames and the placement of the electronics, etc. What are some of the options for motor / ESC / batteries for guys who just want to run normal headspeed (2500 / 2700) range.
Also, any news on making this available as an upgrade kit with all the parts included?
[ 300x | Robird ] [ Protôs | Stretched, Low Head, BeastX, YGE60, HS-5245MG, BLS980, Scorpion 880kv ] [ Gaui NX4 | Stretched, SAB 465's, SK540, Savox 1250/1257/DS520, OS37/Hatori ] [ Gaui X5 12S | Ikon, HW70HV, DS610, BLS251, Quantum 4125-560 ] |
#60 |
Jkk
How did you make those servo mounts? I'm still learning all about CNC machining, but I've only done as much as 2D/2.5D so far and not anything that required multiple setups to machine different axis. Just curious how you went about machining it then repositioning to machine the holes etc.
