Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters and Electronics
KDS Helicopters and Electronics KDS Helicopters and Electronics Discussion
Old 11-08-2012, 05:15 PM   #1
x5heli
Default What size KDS Innova 550 FBL-S4 swashplate leveler?
Hi,
What's the size of KDS Innova 550 FBL-S4 swashplate leveler size and where i get it?
x5heli is offline        Reply With Quote
Old 11-08-2012, 11:06 PM   #2
x5heli
No one help me? What's the size swashplate leveler Tool for kds innova 550e s4 v2
Old 11-09-2012, 02:44 PM   #3
Adventurer
Just watch out for the shaft diameter. The V2 uses an 11mm shaft instead of the 10mm that the V1, Trex 550 and Trex 600 use.
I don't have a clue where you could get a swash leveller to fit an 11mm shaft.
Craig
If you're not living on the edge, then you're taking up too much space
Adventurer is online now        Reply With Quote
Old 11-09-2012, 07:57 PM   #4
x5heli
I measur it's 10mm which is bigger then x5 shaft now i need new swashplate leveler. So the kds 550 v2 its 120degree swashplate? Or 140
Old 11-30-2012, 04:16 AM   #5
Familyman67
@Adventurer - you sure 'bout that ? I thought you can just exchange the V1 vs. the V2 head. I mean you do need a different shaft,since it needs to be shorter as I assume, but if the V2 shaft is +1mm in diameter, then you would also need a new swashplate, new bearings, new maingear, new belt-driver gear, etc. etc. to do the upgrade.
Well I have a V2 headed my way and will be able to measure some time next week.
Active: nano CPx / mCPx BL / 130X / 300X / KDS 550 V2 / UM F27Q Stryker / DX8
retired: CX Scout / mCX2 / B-SR / mSRx / 120SR / mCPx V2 / DX6i
Familyman67 is offline        Reply With Quote
