Go Back   HeliFreak > R/C Helicopter Support > 800 Class Helicopters
800 Class Helicopters 800 Class Helicopters
Old 11-09-2012, 03:23 PM   #1
K2Freak
Default 750MX 450...
Hi,
Is anyone having good luck getting power out of this motor? I have certainly read that they are not as powerful as we would like, but mine is getting nowhere near the rated capacity. I have about 11 degrees of collective and it flies very adequately, but not really what I had hoped from "Align's great new motor."
Running Align 800 blades on CHP DL 700 stretches that weigh 10.5 lbs. For reference, my Xera 4030 470 is getting noticeably more power than the Align which is rated higher. Nothing is getting hot or acting weird on either bird.
HW120HV, Gens Ace 3800 @ 12S
PWM: 8
Timing: 7.5 and 15 tested
Timing at 15 was better than 7.5, but I hesitate to go higher. I'm thinking I will try PWM = 12 and see if anything improves.
Anyone have suggestions?
T-Rex 800E CHP DL / VBar / YGE 160HV / X-era 4030 470kv / MKS DS660A+ & DS760 / Align 780mm / Gryphon Quasar / KDE performance tail
K2Freak is offline        Reply With Quote
Old 11-11-2012, 10:48 AM   #2
K2Freak
12 kHz PWM and 18.75 degrees of timing woke it up a bit more. Still didn't really get warm (nothing did), but it did somewhat better against full pitch bogging. I had also added half a degree of positive since the last test.
I have to say that all in all it's working pretty well now.
Old 11-11-2012, 03:43 PM   #3
hidaven
I was thinking about a motor rewind to solid core. My guess is that a 14s setup with a 395kv motor would be perfect for this heli. Only reason I hesitate is that I'm not sure the gear train would handle it although align just released a heavy duty black replacement main gear. Tail, TT, anti rotation gears are a question mark......
hidaven is offline        Reply With Quote
Old 11-11-2012, 04:17 PM   #4
K2Freak
The new higher ratio helical set are running great for me. I haven't blown any gears out at all since I got the CNC helical main.
Old 11-11-2012, 08:07 PM   #5
hidaven
Are you running any other upgrade gears other than the new align black main gear? Also, what rpm are you at? I wanna run in gov. Mode.
Old 11-12-2012, 10:04 AM   #6
K2Freak
1500, 1700, 1800 VBar governed.
I have stock gears; i.e. CNC helical 112 Align (white), helical auto and umbrella, 11T Align helical pinion.
Old 11-16-2012, 08:31 AM   #7
jrod155
Never go below 15 on a hobby wing, that's how they burn,
The real power is at 22.5 timing,
Check the hobby wing forum
Compass 7HV, El Brute, Ice2 120HV, TracX fbl
Compass Atom 500, Ice 100, TracX fbl
TX: Futaba 7C w/ Fr-Sky DHT, Soon to be Taranis
Old Models: X2, X5, TREX(250, 450, 600ESP), WARP 360, 6HV, 450X, bl CO5M MCPX, Genius CP
jrod155 is offline        Reply With Quote
Old 11-16-2012, 01:56 PM   #8
soko
Hi guys,
I don't have much experience with motor tweaking via ESC settings so I hope you guys can help me out here.
I'm using the Align 750MX (530kV), stock version, on my new Goblin 700 and HW120HV.
So almost the same as you and I hope you're OK with asking me this question in your discussion...
I was wondering about the "correct" Timing & PWM settings for that motor but it seems there is no hard border between right and wrong
asfaik there is no point to go down to 8kHz, 12kHz is default and that are the only options here.
But Timing is 15° default. Should I try 22.5° as jord155 suggested?
How do I know if it is a good or bad value for my motor?
thx guys
Soko
ONE TOOL for ALL SIZES and ALL BRANDS
"Unique features" | "Awesome setup tool" | "its simply awesome"
www.soko-heli-tools.com
soko is offline        Reply With Quote
Old 11-16-2012, 03:14 PM   #9
K2Freak
To me it seemed like the Align liked PWM = 12. I had timing at 18.75 and would have tested the next one higher as well. Seemed like it was coming alive as I increased timing. Sold this motor.
I like the Xera 4030 470 better. I have PWM at 12kHz, and have timing at 7.5 degrees. Folks that I trust say to run timing on the lower end with Xera, but I wonder if I'm going to need to increase it to get the best power. At these settings everything ran cool - ESC, batteries, motor, barely warm to the touch after 3 x 6 minute sport flights.
Old 11-26-2012, 03:31 PM   #10
hidaven
Any additional info on the timing or PWM?
Old 11-26-2012, 03:48 PM   #11
soko
I just have a few flight with 12kHz and 15° and no problems so far...
Old 11-27-2012, 07:31 PM   #12
hidaven
hows the power? any bogging?
Old 11-27-2012, 07:50 PM   #13
soko
I think the power is enough. I have some (other) troubles with the Goblin so I can't really tell
