Old 11-15-2012, 08:02 PM   #21
Ty89m
Thanks everyone. Have XT60's and a Hakko solder station on the way. Wish me luck, first time soldering!
Mini Prôtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready
Mini Prôtos 6S - DS92A+/DS95i, SK540, YGE60
Ty89m is offline        Reply With Quote
Old 11-16-2012, 08:30 AM   #22
CrashAddict
Default Hakko
THat thing is a nice piece. The color and shape are offputting but it works very well. Good luck with the soldering. The battery wires ome pretinned from the factory and rarely do they fit in 3.5mm bullets, I had to cut the tinning off, well at least on the four I have done.
CrashAddict is offline        Reply With Quote
Old 11-16-2012, 07:04 PM   #23
soniczen
Originally Posted by CrashAddict View Post
XT60's look to be ok but I don't like the fact that you have exposed wiring on the back.
Heat shrink. just remember to put it on before soldering the leads. And move it up close to the battery so that it doesn't shrink from heat while soldering.
Mini Protos, 6S, Mini V-Bar, YGE 60, 3000rpm, 350mm
550e v2, 6S, Fullsize V-Bar Pro 5.3, CC ICE 100, CC BEC Pro, 2200rpm, 550mm
Logo 550sx, 6S, Ikon, CC EDGE 100, CC BEC Pro, 2200rpm, 550mm
soniczen is offline        Reply With Quote
Old 12-08-2012, 03:37 PM   #24
CrashAddict
Wait, which HAKKO did you buy? If it was an FX-888, go get something else lol. I have one of those but I use it to fix fiddly bits on PC boards. It hasn't the power for EC3's. I just tried it. You would need the patience of a Saint. Unless there is something wrong with mine. Seriously, does anyone have issues with the FX888 and EC3's? My Weller WLC-100 has more than enough power for these EC3's & 5's.
Old 12-08-2012, 04:17 PM   #25
Ty89m
Hmm, yes, FX-888, Seemed to work fine for my XT-60's, even manged to solder 10 gauge battery wires to XT60's without TOO much trouble, a bit of a pain, but got the job done... Hopefully my joints on the batts hold up
Old 12-08-2012, 11:36 PM   #26
desertstalker
Wrong tip? You want a largish chisel tip for connectors, rather different to the fine point I would use for electronics stuff.
-DX8
Old 12-08-2012, 11:52 PM   #27
CrashAddict
The tips I have on the irons are similar. Small chisels. The Hakko gets hot, it just cools off faster than the Weller. Im used to Instant constant heat. The Hakko was a little delicate. Could be something wrong with it though.. Dunno, works fine for finer work.
Old 12-10-2012, 07:40 AM   #28
Thalios
Originally Posted by rossk View Post
EC3 on 450-
EC5 on 500+
+1. That's what I did.
Lynx Heli Team Pilot
Prôtos CF, 130X and many others.
CarbonCore H6 650mm Wookong-M
All on DX18!
Thalios is offline        Reply With Quote
