Go Back   HeliFreak > R/C Helicopters > RC Helicopter Flight School
RC Helicopter Flight School Instructional Flying Tips, Tricks, Videos, and Q&A
Old 11-09-2012, 10:17 PM   #1
newhelliguy
Default Banking in turns
This is so obvious it is embarrassing but I have always had trouble figuring out what aileron input to steepen / shallow the bank in the turn while flying all the way around a circle.
I figured out a rule that has helped me tremendously.
No matter if the sticks are coordinated or not, the direction you initially push the aileron will always steepen the bank and the opposite will shallow the bank.
This works in all turns upright and inverted.
I said it was obvious, but I had never broke it down and thought it out.
It has really helped me
20 something various Helis, Msr through 90's.
How many helis do you need? Just one more.
Sk720 equipped
newhelliguy is offline        Reply With Quote
Old 11-09-2012, 10:43 PM   #2
NSFlyer12
Took me some time to get this as well but once I did, it started to become natural to make the proper stick adjustments.
T-Rex 500 DFC, T-Rex 600 DFC, T-Rex 450 DFC, PITA Blade 130X, Spektrum DX8
NSFlyer12 is offline        Reply With Quote
Old 11-13-2012, 02:26 PM   #3
alexd1
I have a problem making backwards flight natural. I'm assuming all orientation flight becomes natural over time.
alexd1 is offline        Reply With Quote
Old 11-13-2012, 07:53 PM   #4
neverland
its hard to believe when your learning, but all 4 main orientations will become pretty natural eventually. you should feel nearly as good in all of them.
neverland is offline        Reply With Quote
Old 11-24-2012, 08:40 AM   #5
03svtsnakevert
Just remember when she is coming at you in a bank and you want to neutralize or shallow it...move the stick to the low side of the rotor blades
03svtsnakevert is offline        Reply With Quote
Old 11-24-2012, 10:39 PM   #6
Steve Graham
This is what we teach people learning to fly planes. It's simple and it works but I hesitate to teach it for more than very basic heli orientation because you will have to "unlearn" it when you start flying backwards. A more consistent approach is to recognize that whenever the tail is pointed at the pilot the roll is normal and when the nose is "in" or towards the pilot the roll is reversed. There are a couple different ways to put this to use. One is that when you're tail in you steer, with aileron, the part of the model that is the highest. This works regardless of roll angle, upright, inverted or either side up. Nose in it's just the opposite. Steer the part of the heli that is the lowest. This is by no means the only "correct" way to view aileron control but it has worked for me and will prove consistent as you progress.
To reinforce what the OP stated you can use a technique called "self talk". Assuming a right stick displacement as you roll into the turn say silently, or even aloud, RIGHT. This reinforces in your grey matter that you went right and left will be the move for recovery or bailout of the maneuver. Of course things start to get a little busy as you get into piroing turns and transitions but thats kind of another discussion.
Steve Graham
TREX 700N FBL...................GAUI X5 FBL...................TREX 450 PRO V2
Alees Rush 750 Still in the womb.
Steve Graham is offline        Reply With Quote
Old 12-11-2012, 02:08 AM   #7
brianapp
If you need to think that much you are bound to crash unless you are on a buddy box. Go very slow so you don't really need any bank and just use a little to get used to seeing it and putting in the right input, if it goes the wrong way just do the opposite and get it back to neutral and stopped. Use the sim. Do it over and over and over..... in the sim until you can zip it around without thinking. Learning in the sim does not directly translate to real life but the reflexes and muscle memory will be there. I practice new maneuvers countless times in the sim. When I then try it for real it is shaky and ugly but when I do make a mistake I correct for it without even thinking. The reflexes you drill in the sim will be there.
brianapp is offline        Reply With Quote
Old 12-12-2012, 09:50 PM   #8
newhelliguy
Yea if you have to think it is too late but you have to start somewhere. This rule works forward and backward, upright and inverted and it is a starting point to help until you can train your muscle memory on the sim
Sk720 equipped
Old 12-12-2012, 11:30 PM   #9
bmc76
For a while I found myself struggling hard with backwards flight and nose in hovering, often getting disoriented. I had to wrap my brain around the fact that the heli responds in exactly the same way no matter which orientation it is, in relation to itself rather than the pilot.
Example is the nose always goes down by pushing up on the right stick, it always dips to it's right side when pushing right on the right stick etc. I think I got so stuck on moving the stick in x direction to make the heli move where I wanted it to in relation to me I overlooked the simplicity of the physics.
To help I covered the entire left side of the canopy, skids, and tail fin with blue painters tape, that way I could easily tell my left from right. When I made mistakes, it registered much quicker why I made the mistake. May not be the best advice for everyone but for me it was better than trying to remember if left or right would make the heli go where I wanted it to.
T-Rex 250 Pro DFC with Beastx / ZYX-S Powered 130x with HP08- XP-12a / 300x with Don's Wicked / 450x / DX8 / Real Flight 6.5
bmc76 is online now        Reply With Quote
Old 12-14-2012, 04:41 AM   #10
ozsteel
Curtis Youngblood wrote some time ago...
Pull the right stick (mode 2) back...the nose moves toward the rotor. Push it forward, the nose moves away from the rotor...always, any orientation.
If the heli is upright...on the left stick (rudder)...move it to the right the heli rotates clockwise...left, anti-clockwise...always. Upside down...the opposite.
Aileron works in the same direction whether you are upright or inverted, backward or forward.
FUTABA 18MZH Mode 2
Mikado Logo 500 3D and Logo 400 VBar
Hirobo SDX Dominik and SDX FBL
Kasama Srimok 90N with cyber head (in work)
ozsteel is offline        Reply With Quote
