Old 11-11-2012, 05:24 PM   #1
steeleagle
Default iCharger 106B "Connection Breakdown" error
I keep getting this message when I attempt to charge. Have tried 3S, 2S, and 1S batteries individually and with a parallel charge board with no luck - the message comes up as soon as I press start/enter to start the charge cycle. The manual says it means an interuption between the battery and the charging source during the charge cycle. Any idea how to clear the error?
steeleagle is offline        Reply With Quote
Old 11-11-2012, 07:47 PM   #2
propxprt
Maybe try a different power supply or battery?
propxprt is online now        Reply With Quote
Old 11-12-2012, 01:08 PM   #3
steeleagle
Good suggestion. Tried it but no joy! Trying to get hold of tech support at Progressive RC.
Old 12-02-2012, 12:27 PM   #4
turko
Default connection breakdown
I had a similar thing happen and it turns out my charge lead had a short in it, bought a new lead and problem solved.
Blade 450 heli,Mks 92'scyclic, Eflite g210 gyro,ds76t, Dx6i
turko is offline        Reply With Quote
Old 12-09-2012, 11:38 PM   #5
Jaguar_5
Did you ever get this figured out?
If not just let me know!
LAHeli - Mikado - Henseleit - FASST
Powered by ProgressiveRC & Spyder Batteries
Jaguar_5 is offline        Reply With Quote
Old 02-14-2013, 08:52 AM   #6
steeleagle
No I didn't get it sorted out. Progressive RC replaced the unit but the second one did the same thing. I think it is getting a spike when I turn on the power supply - I have it hooked up in the sequence shown in the manual. Any ideas?
Old 02-14-2013, 07:20 PM   #7
cyclo
Your power supply most likely has an issue.
Compass: Atom 5.5 AR7200BX MKS DS9660A+/BLS980 YGE 90HV Gryphon Quasar | Atom 500 AR7200BX SAVÖX 1250MG/1290MG Castle ICE 75
Blade: 450X (2) | mCPX | mQX | Hoverthings: FLIP FPV (building),
Fat Shark Attitude SD
TXs: DX8, DX5e | Sim: Phoenix 4
cyclo is online now        Reply With Quote
