Go Back   HeliFreak > R/C Helicopter Support > Beam Avantgarde 600
Beam Avantgarde 600 Beam Avantgarde 600 Support Forum
Old 11-11-2012, 07:08 PM   #1
timmytron
Default Beam Avantgarde - Colin Smith - Freestyle Flight
Filmed and edited this yesterday whilst out at the flying field. We've just about got this puppy nicely dialed after adjusting the gains a bit in the V-bar unit and changing the pinion tooth count (we had wayyyy too much headspeed). The preference with this machine is to run a more conservative headspeed in the realm of 2100-2200 or so for a more smoother flying style. It can still do POP and LOCK as required though!
What do you boys think?
Running gear is:
- Nexus HV Cyclics
- Futaba BLS251 Tail servo
- Kontronik 80HV ESC (using on board BEC)
- 2x 6s Galaxy 40c/80c batteries 3000mAh
- Mikado Mini V-bar Blueline
- Gryphon 615mm FBL Blades
- Scorpion 4025-550kv motor
Team Old Mate - He's a good bloke
timmytron is offline        Reply With Quote
Old 11-20-2012, 06:56 PM   #2
Dally7
Dally7 is offline        Reply With Quote
Old 11-20-2012, 07:09 PM   #3
NSFlyer12
Nice flying and nice looking heli!
T-Rex 500 DFC, T-Rex 600 DFC, T-Rex 450 Pro, Blade 130X, Spektrum DX8
NSFlyer12 is offline        Reply With Quote
Old 11-21-2012, 05:14 AM   #4
lowey79
Nice flying man,
How does it balance with those 3000's in it?
lowey79 is offline        Reply With Quote
Old 11-21-2012, 02:39 PM   #5
NicolaiStaer
What pinion do you use?
Nice flight..
NicolaiStaer is offline        Reply With Quote
Old 12-10-2012, 04:05 PM   #6
col
Originally Posted by lowey79 View Post
Nice flying man,
Hi, balances ok, a tiny bit nose heavy which is actually good for fff, but even in a hover it dosnt matter and piros flat and true, they do physicallyfit very well.
col is offline        Reply With Quote
Old 12-10-2012, 04:06 PM   #7
col
Nice flight..
Hi Nic, 12 tooth pinion with the Kontronic Jive gov feature.
Was using a 16 tooth in the vid with the gov curve set to 40 flatt to try and lower the hs.
Now using a 12 tooth and at 78 flat curve its spot on
