Old 11-12-2012, 06:35 AM   #1
chrishelimaniac
Default Align 3GX / Spektrum DX8 Gov Question
Hi guys
I'm trying to set up the governor on my T-Rex 700N w/3GX and Spektrum DX8.
Problem: The gov led on the 3GX is red (gov OFF), no matter what I try.
Here is my setup:
- the gov sensor is plugged in the corresponding port on 3GX
- gov led is red and switches off/on when passing a magnet
- remote governor mode is on channel Aux2
- normal mode 0%, Idle Up 1 70%, Idle Up 2 80%.
What am I missing?
Thanks for your help!
Happy flying,
Chris
chrishelimaniac is offline        Reply With Quote
Old 11-12-2012, 08:38 AM   #2
JoeW
Using a sat receiver I assume?
AUX2= gyro gain
AUX1 (gear) = gov
TRex 250 DFC | TRex 250 DFC (Scale)
2 @ TRex 450 DFC | TRex 450 Pro 3G (Scale)
TRex 550 DFC
DX8 + Telemetery on all
JoeW is online now        Reply With Quote
Old 11-12-2012, 10:42 AM   #3
bad007
Gov is on gear channel. Use mixing. Link up to view the head speed the values will provide
the rpms with each position
Align 450Pro 3GX, Align 500 3G
Align 550 3g, Velocity 50 Vbar
bad007 is offline        Reply With Quote
Old 11-12-2012, 01:11 PM   #4
chrishelimaniac
Thumbs up Problem solved
Hi guys
Thanks for your help.
I had a R8000 (+attached SAT receiver) connected to the 3GX in order to make use of DSMX (vs. DSM2) technology. This config wouldn't allow me to control the gov function, no matter what channel used.
I now switched to 2 SAT receivers directly connected to the 3GX, which makes for a very clean/uncluttered setup (though DSM2 only). With GYRO GAIN on Ch 7 and GOV on CH 5 all works fine now.
Thanks for the inputs guys!
Happy landings!
Chris
Old 11-12-2012, 04:57 PM   #5
bad007
Here's another set or my vbar, one mixing for both FM 1&2 abd then another for just 2 and that one adds to the first for just FM2. Losts of ways to configure
