Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 11-15-2012, 05:49 PM   #1
racin06
Default 12S Powered 87" Sbach 300 w/Video
Below is the video of the second flight...nothing special...an inverted CG check, a few low passes and a couple of full throttle climbs. I really like the Hacker Q80-8M and it sounds awesome!
Setup:
- Hacker Q80-8M Motor
- Mejzlik 24 x 10 Carbon Prop
- Castle Creations Phoenix ICE2 160A HV ESC
- Hitec HS-5585MH HV Servos x 4 (2 x Ailerons, 2 x Elevator)
- Hitec HS-7954SH HV Servo (Rudder)
- LiFeSource 6.6v 2100mAh 10C Receiver Battery
- Spektrum AR8000 Receiver
- Pulse 2 x 6S 5000mAh 35C Lipo Batteries (12S 5000mAh)
- Spektrum DX8 Transmitter
- AUW: 18.79 lbs.
Static Full Throttle Data:
Current - 119.49 Amps
Voltage - 45.04 Volts
Power - 5,382.10 Watts
Power-To-Weight Ratio - 286.43 watts/lb.
racin06 is offline        Reply With Quote
Old 11-21-2012, 11:26 AM   #2
TCipolla
Nice! What kit is that?
Tim
TCipolla is offline        Reply With Quote
Old 11-28-2012, 09:26 PM   #3
racin06
Thanks. Sorry for the late reply. The kit is from Aerobeez: http://www.aerobeez.com/87-30-Scale-...ne-Orange.html
