Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 01-02-2013, 03:21 PM   #41
stocksy27
Originally Posted by Stolla View Post
Well I didn't say not rated for 14s I said kv too fast for l 700 there are not enough pinion Options to my knowledge
Pyro 850 much lower kv. The max rpm Is a guideline only and more for bearing longevity than anything else also its a small motor better suited for 12s as to get kv low enough for 14 s it needs more windings, since space is limited the only solution would be higher pole count to lower kv and then your yge won't work anymore as its switching frequency limited to 132000 on 2 pole
well ive not heard anything positive about running 14s :-( and you seem to know lot more than me lol, so ill stick with 12s 5000 thanks
btw running Kosmik 200
stocksy27 is online now        Reply With Quote
Old 01-05-2013, 02:04 PM   #42
dart
Talking
I got the opportunity to try out the Scorpion HKIII-4530 450kv RigidHeli.com edition with 17T pinion and 14S 4200mAh 60C Desire Power on my XXtreme 700.
I did a test flight on 2000RPM and the result:
The cool thing is that this motor is a drop in replacement for the Mikado 4525. Just plug in some 14S lipos and have fun!
Plenty of power, even when you just do stupid full pitch punch-outs (13 degrees)
dart is offline        Reply With Quote
Old 01-05-2013, 05:22 PM   #43
NTM
Looks very solid !
What did you put back into the packs after that flight ?
Too bad that you can't simply add that motor to cart, and have it on the way. I'd buy one now if you could...
I hope one of the manufacturers is paying attention, there is a need for a 10 pole, 45 series, 450kv motor with an 8mm shaft. Since the pyro 800-48 won't work with the yge 160hv.
NTM is offline        Reply With Quote
Old 01-05-2013, 05:38 PM   #44
dart
I put back 2750mAh after this flight. Peak at 6.1kW.
A little birdy told me that this custom motor will be up for order soonish.
Old 01-05-2013, 05:43 PM   #45
Luisito
Originally Posted by NTM View Post
Looks very solid !
Just bought that combination and got it in the mail today. What's wrong with the 800-48 and YGE 160?
Luis
Logo 700 XXtreme, SAB Goblin 700, SAB 770: Logo 600SE Carbon Fiber Frame 12S: Pyro 700-45, Kontronik 120 Heli Jive, 11T Pinion, Full Size V-Bar 5.3, 693/105 Blades Align 550E: Pyro 600-12, CC100, 17T Pinion, Full Size V-Bar 5.3, 553/86 Blades
Luisito is offline        Reply With Quote
Old 01-05-2013, 06:04 PM   #46
kjoer
The setup from the video indeed looks impressive, practically unboggable whilst staying cool.
Best head over to this thread and read all of it: http://www.helifreak.com/showthread.php?t=485160
http://www.xs4all.nl/~rzavelli/rc_heli.txt
kjoer is offline        Reply With Quote
Old 01-05-2013, 06:50 PM   #47
OICU812
dart it takes lots to impress me, THAT is impressive power.
OICU812 is offline        Reply With Quote
Old 01-05-2013, 09:10 PM   #48
NTM
Luis
The yge went through a firmware update somewhere in the last while, it's switching rate is now capped at 132,000 as opposed to their advertised 250,000 cycles on 2 pole.
This means 14 pole motors can only be run to a certain rpm, too low for the 480kv and 14s.
10 pole motors like the scorpions and their rewinds are good to go though.
Old 01-05-2013, 09:15 PM   #49
rcmarty
Nice flying !
I liked the cool swirling funnels at 3:50
I also really liked the canopy , those colors are awesome.
We have more than our share of crappy overcast grey skies.
So many times at the field i can't see the heli but that four orange and yellow are going to change that
I'm getting excited to go flying , but going to have to wait
Off to shovel some snow
Martin
Logo XXtreme 8917 / 256HV
Logo XXtreme 700 8917 / 256HV
Logo 600 : bls451/ 9256 , V-bar , QUK tail , Edge 623FBL , Scorpion 4035-500
Logo 600se : bls 451/251, QUK tail , Edge 693/105 , Scorp 5020-450 for sale
rcmarty is offline        Reply With Quote
Old 01-05-2013, 11:03 PM   #50
Luisito
Do you have a link to these new specs?
Heli Direct still shows the specs to be 240,000. I haven't tried it yet since now I'm skeptical. I'd hate to be stuck with a YGE that won't work with thie Kontronik 800-480.
Old 01-05-2013, 11:16 PM   #51
NTM
MrMel contacted yge to confirm.
Feel free to do the same.
Stolla tried it with his rewound pyro 800, still 14 poles of course, and the esc wouldn't drive the motor past the software limited switching rate.
Old 01-05-2013, 11:26 PM   #52
McCollister911
the helidirect models are version 23
still has the old 240,000 rpm range
McCollister911 is offline        Reply With Quote
Old 01-06-2013, 06:57 AM   #53
Stolla
Ok I have rewind 850 not that it makes a difference. U can run it on 12s with 19t pinion keeping rpm under 18500 it works well don't know how the limit affects headroom as I had to tweak vbar gov settings to get it to work well maybe if we can get larger pinion to keep motor rpm lower will work but really not an optimised solution, better keep 4525 or get kosmik
I will try kosmik soon I get one then post comparative result on 12s before going 14. Please read my post in vstabi .de for detailed explanation why yge or perhaps rather mik wanted the limit
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200
Old 01-06-2013, 08:39 AM   #54
Luisito
Stolla, thanks for the info. Looking forward to your findings with Kosmik...
Old 02-09-2013, 10:26 PM   #55
NTM
So, just a little update with this thread.
I tried the pyro 800-48 with 713 se edges at 2100 rpm. It was lethargic on collective response, disk load is just a bit too heavy. 210 amp peaks.
Also tried the pyro on 753mm edges (250g), that shut the kosmik down due to how quickly the pyro would spike amps. Pyro 800 is a bit too small for 753mm blades and agressive flying. 240 amp peak and then shutdown.
Swapped out the pyro 800-48 for a scorpion 4530-450 "ultimate".
On 713mm se's it was a noticeable improvement due to the added power. 220 amp peaks.
Huge difference on 753mm blades, way more power, and lower peak amp draws compared to pyro. 230 amp peaks.
The 753mm blades are good for lift, but are too heavy, they give the heli a weird "gyro" effect, it just hangs in the air. Also uses alot of power when bouncing back from a governor fluctuation. Hover amp draw is high too.
Found some nhp agressor's at 742mm and 200 grams through minicopter.
They're pretty decent, lower hover amp draw, and I like the initial response of the collective. 215 amp peaks.
Shawn has some ms composit 720mm and 730mm blades on the way to try next. He's running the same 14s setup with a scorpion 4530-450.
Hopefully we can nail down a good size and edge will build some, can't beat the nice cyclic behaviour of the edge se blades. Those in a 730 would be very nice.
So in summary, still not quite there with the blades yet, 730mm is going to be the one I think.
And I highly recommend the scorpion 4530-450, it's got balls !
Old 03-25-2013, 08:34 AM   #56
NickBee
Hey guys!
I'm thinking about pulling the trigger on an HKIII 4530-450 for my Diabolo on 14s. Just a quick question. At this point is there any advantage over the Rigid Heli version over the stock Scorpion version? The Rigid Heli version is about $100 more and takes 2 to 3 weeks. The standard Scorp version is in stock at multiple vendors.
Thanks!!!
Diabolo…HC3SX…Gmauro HKIII-4530-450…KOSMIK 200…MKS HLB950/HLB980
Protos 500 Stretched
…HC3SX…Hyperion 3026-880kv…KOBY 90…MKS DS9670A+/DS-760
mCP X bl
NickBee is offline        Reply With Quote
