| NX4 Discussion and support of the Gaui NX4 Nitro Helicopter |
Just a simple question witch governor you run on your nx4
Revmax ? Align governor ? For this one , what % you run on radio Gaui governor ? Other |
Using align gov with its sensor and magnets. JR radio set to "GOV" and three numbers are:
Norm : 80 Idle up 1: 110 Idle up 2.120 For now. Yours may vary depending on your throttle linkage setup.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Vbar governor with Align sensor. Still playing with the gain settings and tuning vbar and engine.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Rush 700 * Trex 700N x 2 * Trex 600Pro * Gaui NX4 - V-Bar on all AMA #934662 |
#4 | |
I've a futaba t7c and in the gov menu i can only go to 100 max , how i can put 120 ?? |
I've a problem its the second time my magnet pull out the fan !!! And now i can't use anymore the original fan in plastic .
I found one , the trex 600 fan in aluminium it´s exactly the sale size !!! I hope the magnet don't pull out !!! In this one I will make a picture tomorrow of the plastic fan . |
#6 |
Really the trex 600 metal fan fits!! I have one of those sitting around.
#7 |
#8 |
Awesome and funny ... That is the exact look of my build... Gaui heli with align towel
#9 |
I'm running a Curtis youngblood ATG with a spektrum backplate sensor. Same setup as my 600 nitro pro!
600N Pro OS 50 Hyper, GY611, 600E Pro All stock, Spartan Quark, NX4 OS 37, BeastX, HK250 DFC, Tarot ZYX-S, UMX Beast, X525 Quad with camera gimbal, HK control board, Spektrum DX7, Pheonix Sim v4.0 AMA# 97405 |
#10 |
#11 |
Using the vbar gov on mine as well, still tweaking though. Had my magnets come out on the last flights so just installed new ones last night. Ended up drilling all the way through the fan on the one side
![]() Managed to back fill the hole with epoxy but not sure if it will work or not...should. Since we are waiting on parts, if my fan is fubar, does the align one pictured above fit? It looks like it does but wondering if it clears the cover once its on as well.
Team Synergy VP Racing Fuels Team Scorpion |
#12 |
The fan align alu fit perfectly .
#13 | |
#14 |
Any chance you could provide a pic? I hate magnets and would prefer a backplate sensor.
#15 |
I can take one tonight when I get home from work.
#16 |
![]() Here's the backplate sensor. I had to adjust the mounting holes, sensor adjustment hole, and trim the plastic the sticks out towards the bottom plate.
#17 |
Where did you get that os 37 backplate mine has grooves and i hate to modify them with dremmell I might have to anyways i ordered parts from tower hobby
#18 |
If its different then stock then I have no idea what is on it. I bought the motor used over a year ago for my trex 500n. Is yours the gaui version that came with the kit and maybe its different?
#19 |
#20 |
I'm running the sk540 internal gov & it is working really well but that fan sucks mine is warped to all hell what a pita looks like i'll have to upgrade to a metal one after all.
Gaui NX4 FBL (SK-540) Gaui X4 II FBL (Gaui Mini V 5.3 Pro) TT X50 N FBL (GT5) T-Rex 700N FBL OS GT15 HZ (SK-540) |
