Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 11-16-2012, 04:46 PM   #1
philou3110
Default Witch governor
Just a simple question witch governor you run on your nx4
Revmax ?
Align governor ? For this one , what % you run on radio
Gaui governor ?
Other
philou3110 is offline        Reply With Quote
Old 11-16-2012, 06:01 PM   #2
tauscnc
Using align gov with its sensor and magnets. JR radio set to "GOV" and three numbers are:
Norm : 80
Idle up 1: 110
Idle up 2.120
For now. Yours may vary depending on your throttle linkage setup.
www.cuttingedgecnc.com
tauscnc is offline        Reply With Quote
Old 11-16-2012, 08:07 PM   #3
caralmar
Vbar governor with Align sensor. Still playing with the gain settings and tuning vbar and engine.
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all
AMA #934662
caralmar is online now        Reply With Quote
Old 11-17-2012, 12:43 AM   #4
philou3110
Norm : 80
Idle up 1: 110
Idle up 2.120
Thank
I've a futaba t7c and in the gov menu i can only go to 100 max , how i can put 120 ??
Old 11-17-2012, 04:55 PM   #5
philou3110
I've a problem its the second time my magnet pull out the fan !!! And now i can't use anymore the original fan in plastic .
I found one , the trex 600 fan in aluminium it´s exactly the sale size !!! I hope the magnet don't pull out !!! In this one
I will make a picture tomorrow of the plastic fan .
Old 11-17-2012, 07:22 PM   #6
tauscnc
Really the trex 600 metal fan fits!! I have one of those sitting around.
Old 11-18-2012, 12:08 PM   #7
philou3110
Yes it's the same
I think this fan is better , lighter
Old 11-18-2012, 02:24 PM   #8
tauscnc
Awesome and funny ... That is the exact look of my build... Gaui heli with align towel
Old 11-20-2012, 06:17 PM   #9
Bengsch85
I'm running a Curtis youngblood ATG with a spektrum backplate sensor. Same setup as my 600 nitro pro!
700N YS.91 600N Pro OS 50 Hyper, GY611, 600E Pro All stock, Spartan Quark, NX4 OS 37, BeastX, HK250 DFC, Tarot ZYX-S, UMX Beast, X525 Quad with camera gimbal, HK control board, Spektrum DX7, Pheonix Sim v4.0
AMA# 97405
Bengsch85 is offline        Reply With Quote
Old 11-20-2012, 11:42 PM   #10
philou3110
How did you do for the spektrum backplate .
Because i try but the sensor is to big for the 37 ....
Did you drill some metal on the engine ??
Old 11-21-2012, 06:37 AM   #11
Gawl
Using the vbar gov on mine as well, still tweaking though. Had my magnets come out on the last flights so just installed new ones last night. Ended up drilling all the way through the fan on the one side
Managed to back fill the hole with epoxy but not sure if it will work or not...should. Since we are waiting on parts, if my fan is fubar, does the align one pictured above fit? It looks like it does but wondering if it clears the cover once its on as well.
Team Synergy
VP Racing Fuels
Team Scorpion
Gawl is offline        Reply With Quote
Old 11-21-2012, 09:12 AM   #12
philou3110
The fan align alu fit perfectly .
Old 11-21-2012, 11:59 AM   #13
Bengsch85
I modified the plastic mount to make it fit. Nothing was done to the backplate. I've had issues with magnet type sensors in the past and prefer backplate sensors now so I found a way to make it work!
AMA# 97405
Old 11-21-2012, 12:35 PM   #14
Gawl
Any chance you could provide a pic? I hate magnets and would prefer a backplate sensor.
Team Synergy
VP Racing Fuels
Team Scorpion
Old 11-21-2012, 01:41 PM   #15
Bengsch85
I can take one tonight when I get home from work.
AMA# 97405
Old 11-25-2012, 09:30 PM   #16
Bengsch85
Here's the backplate sensor. I had to adjust the mounting holes, sensor adjustment hole, and trim the plastic the sticks out towards the bottom plate.
AMA# 97405
Old 12-15-2012, 04:45 PM   #17
aceguintu
Where did you get that os 37 backplate mine has grooves and i hate to modify them with dremmell I might have to anyways i ordered parts from tower hobby
aceguintu is offline        Reply With Quote
Old 12-15-2012, 11:24 PM   #18
Bengsch85
If its different then stock then I have no idea what is on it. I bought the motor used over a year ago for my trex 500n. Is yours the gaui version that came with the kit and maybe its different?
AMA# 97405
Old 12-16-2012, 01:31 AM   #19
aceguintu
yeah i guess so
Old 12-16-2012, 04:57 AM   #20
ranma103
I'm running the sk540 internal gov & it is working really well but that fan sucks mine is warped to all hell what a pita looks like i'll have to upgrade to a metal one after all.
Gaui NX4 FBL (SK-540)
Gaui X4 II FBL (Gaui Mini V 5.3 Pro)
TT X50 N FBL (GT5)
T-Rex 700N FBL OS GT15 HZ (SK-540)
ranma103 is offline        Reply With Quote
